Thread Tools Search this Thread Rating: Thread Rating: 11 votes, 5.00 average. Display Modes
Old 10-06-2016, 07:28 PM   #41
DEADF15H
My Ride: 2001 325i Auto
Originally Posted by lllRazorlll View Post
When you close either of the front two doors with the window completely lowered, does it seem to make a noise as if the glass inside the door is loose or something? I always feel that I have to close the door as gently as possible if I swing it shut because if I shut it too hard I may break something inside
I know Razor made this post last year, but it still applies.
In my case, the bolt that goes into the red plastic clip the window sits on worked its way loose. The banging noise was the regulator hitting the door. You have to take the motor off to adjust the window, to access either of those bolts.
I would also suggest anyone replacing their regulator also replace their red clips.
DEADF15H is offline   Reply With Quote
diy, regulator, window
