Old 03-19-2017, 05:04 PM   #1
Wochoa
My Ride: 2003 BMW 325ci
Little Question Regarding Halo's
Hey all, so a couple days ago I posted a question on my DRL's and my Halos.. So fast forward today, I found a local guy with the program to disable my DRL's. It came out good. The only very small issue is that when I turn off the car, it takes a couple of mins for the halos to turn off. I just wanted to know if that is normal, because when I did have my DRL's, my halos would turn off within 10 seconds. Not a big deal, Im just curious why it takes longer to turn off(maybe the wiring setup?).
Wochoa is offline   Reply With Quote
Old 03-19-2017, 05:10 PM   #2
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
They are supposed to turn off in like 5 seconds or so but they will stay on if the car was being driven long/hard. That will result in extra current/hot wires which will still power the angel eyes. Are they wired properly as per the link in my sig below?
Old 03-19-2017, 05:26 PM   #3
Wochoa
Well to begin with, I did about a 40min drive until I came home and shut off the car and realized that they were still on. I also did go over your Angle Eye install guide and my wiring set up is identical to yours.
Old 03-23-2017, 01:44 PM   #4
Hisdem
My Ride: 2004 M3 Convertible
Mine usually go off in about 5-10 seconds, but I've noticed that once in a blue moon they've stayed on for as much as a couple of minutes, just to turn off again normally. I've had them on for two years with no issues now.
Hisdem is offline   Reply With Quote
Old 03-23-2017, 03:32 PM   #5
JJR4884
My Ride: BMW
If your angel eyes are installed using the instructions that Umnitza gives you, the following will happen
If you connected the AE's to the interior foot well
- They will remain on for a little if you don't close and lock your door immediately upon exiting.
- They will dim and shut off within seconds as it follows suit to your interior lights.
- If it stays on longer than above (up to 10 min,) it is because the power wire from your ECU is still in use, usually after a long trip
JJR4884 is offline   Reply With Quote
Old 03-23-2017, 08:56 PM   #6
Wochoa
Well after about a week having the angle eyes on, they started turning off immediately after turning off the car, so the problem went away. I guess they only stayed on the very first time after turning off the DRL.
