Status
Not open for further replies.
Cold weather misfires and CEL
1M views 1K replies 281 participants last post by  AntonB
#1 · (Edited)
So tis the season for the usual car runs rough on start up, misfires, CEL/MIL, stalling. Before you get too deep into this thread, I believe most of the data is relevant to the 325/330 models, or typical the 2.5L M52tu and 3.0L M54 engines also used in the E39 5 series and E85??Z4 series (however, it may be relevant to the 323/328 models as well, but part numbers will probably vary?), please check part number and application carefully before placing parts orders.
First suggestion to help you move in the proper direction is get your CEL/MIL codes read. Log and note the date, mileage and each trouble code. If there is Freeze Frame data, note this as well. Then clear codes, NOTE YOU WILL NEED AN ODBII SCAN TOOL TO CLEAR YOUR CODES, also NOTE IF YOU ARE NOT USING A BMW SPECIFIC SCAN TOOL (PEAKE, GT1, PA SOFT, CARSOFT, ETC.) YOU MAY ONLY GET A PARTIAL PICTURE OF WHAT CODES YOUR CAR MAY HAVE. The idea here is each time your CEL/MIL lights up, try to read, Log and and clear your codes ASAP. This will help you identify what code(s) show up first and will help you narrow your problem before other codes show up and may mislead you.
If you do not have a code reader or scan tool, many auto parts stores (Auto Zone, Advance, Pep Boys, O'Rielly, Fisher, etc.) will allow you to borrow one and usually use it in their parking lot.
As of Jan 2019 we have found OBDFusion and the VeePeak interface combination for either Android or iProducts tends to be rock solid and is one of the most cost effective and powerful OBDII Apps that also allows for Logging data.
If you have a smart phone or tablet, get an OBDII App and interface so you can read the codes along with Live/Realtime or Freeze Frame data then you will know exactly what is going on with the engine fuel management system.
The OBDFusion App and proper VeePeak interface from Amazon are less than $40 for both for iProducts, less than $20 for both for Android.
OBDFusion for Android is $4.99 from the Google Play Store.
For Android this lower cost standard Bluetooth interface in the link below works well, but DO NOT try to use this with iProducts.
https://www.amazon.com/Veepeak-Blue...=1487373393&sr=8-1&keywords=veepeak+bluetooth
OBDFusion, for the iProducts it is $9.99 from the Apple App Store.
For iProducts you NEED a LE Bluetooth adapter which are more expensive. VeePeak now offers a LE Bluetooth interface that is compatible with OBDFusion in the link below. While people have used the Wifi adapter, I would HIGHLY recommend NOT using Wifi with iProducts, brings a lot of baggage and stability issues.
https://www.amazon.com/Veepeak-OBDC...e=UTF8&qid=1504549087&sr=8-2&keywords=veepeak
Buy the interface you need NOW!
Please note that the bulk of this thread has to do with problems on cold start up and during idle situations. There have been a number of cases lately where codes P0171/P0174 are not triggered at idle, but at highway cruise speeds. I suggest you cover the bases with the very common solutions listed below, but if once you have cleared the obvious problems and if you are getting P0171/P0174 at highway cruise speeds only, then you are most likely not dealing with a standard intake or crankcase vacuum/air leak. I will be adding information to this thread in the near future for lean codes at highway cruise speeds[/COLOR]
IMPORTANT INFORMATION
As mentioned above, the bulk of this thread has to do with idle based problems, usually caused by vacuum/air leaks, but we have started to see a few cars that owners have addressed all the obvious vacuum/air leaks and they are still getting mostly Lean codes, many times without DME misfire codes. In a number of these instances the problems only show up during highway cruising situations, the CEL will not trigger during start up or any in town sub 45 MPH driving. But once the car is brought up to highway cruise type speeds, a few cars are still triggering the CEL along with P0171 & P0174. In many of these cases the problem has been with soft failed MAF's that are under reporting the amount of intake air, therefore causing the mixtures to be adjusted lean, then triggering Lean P0171 & P0174. So in some cases you may have a soft failure on a MAF where the engine is misfiring and running poorly and/or in a limp mode without any specific CEL or DME trouble codes.
Some cases we have seen soft failures on fuel pumps and/or fuel filters that either the pressure regulators are not working correctly, even restricted fuel filters with 80-120k miles of fuel passing through them. A few major telltale results of a soft failing fuel pump is running out of fuel while the fuel gauge indicates 1/4 tank and a moaning sound under the drivers floor board or along the driver side rocker panel, this is usually caused by the fuel pressure regulator vibrating due to low fuel volume and inconsistent fuel delivery from the fuel pump. The moaning can often be VERY loud and sounds like a wounded elephant. Some of the soft fail fuel pump failures are causing P0171/P0174 without misfire and may only happen off idle when cruising. Sometimes even causing idle surge and instability without triggering the CEL or codes. Please cover the basics and take care of simple things like spark plugs, fuel filter and engine vacuum caps and hoses before spending a lot of money on other parts. If you do not know the history on your spark plugs, air filter and fuel filter, it is probably time to change them!
FUEL PUMP ISSUES
This is not really part of the simple vacuum leak/hose problems that were originally outlined, but BEWARE there are soft failures on fuel pumps that can lead to intermittent hesitation, rough idle, misfires and stalling.
Suggest you check this link here for more info on fuel pump failures - https://forum.e46fanatics.com/showthread.php?t=929501&highlight=
A PM replacement of the pump, fuel filter and fuel pump relay may be a good idea. Parts cost if you do your homework should be under $200 and take about 1 hour. The best pump prices are from www.bmaparts.com from what we have seen lately. Fuel filter pricing on Amazon is pretty good as well.
Other items to possibly consider, but may not have been identified as actual causes of lean codes are as follows: camshaft timing may be out of spec possibly due to prior cylinder head removal and/or timing chain work, VANOS seals possibly casing camshaft timing to be off, throttle body/TPS issues. These are things to consider and to look into, many of these issues have not been proven to be a cause of the lean codes, however, just additional items to think about. Also keep in mind that pre Cat O2 sensor health is also important for proper reporting of fuel mixtures. And the last thing to think about is engine to body grounding. If for some reason the ground path between the engine and body/DME is questionable, you again may have incorrect reporting of sensor date, therefore possibly causing problems with CEL and DME trouble codes. So look at the charging Voltages and check the engine to body grounds while under the hood. Camshaft position sensors are also known weak points in these cars and they can also soft fail causing incorrect camshaft position feedback, thereby causing the VANOS to not work properly and possibly impact performance enough to cause Lean codes to be triggered.
But in any event, I would start with reading the DME trouble codes and uses these as clues, check all the obvious source so vacuum leaks, replace known problem hoses, gaskets and intake boots, then see where this all leads you. Additionally many maintenance related items should also be addressed before jumping into more costly and difficult sensor replacement.
Most of the problems I mention in this thread trigger one or more of the follow codes, but not limited just to these codes:
P0171 = Fuel Trim, Bank1 System Too Lean
P0174 = Fuel Trim, Bank2 System Too Lean
P1083 = Fuel Control Limit Mixture Too Lean (Bank 1, Sensor 1)
P1085 = Fuel Control Limit Mixture Too Lean (Bank 2, Sensor 1)
P1090 = Pre Catalyst Fuel Trim Too Lean Bank #1
P1091 = Pre Catalyst Fuel Trim Too Lean Bank #2
P0300 = Random/Multiple Cylinder Misfire Detected
P0313 = Misfire Detected Low Fuel Level
P1342 = Misfire During Start Cylinder 1
P1343 = Misfire Cylinder #1 with Fuel Cut-Off
P1344 = Misfire During Start Cylinder 2
P1345 = Misfire Cylinder #2 with Fuel Cut-Off
P1346 = Misfire During Start Cylinder 3
P1347 = Misfire Cylinder #3 with Fuel Cut-Off
P1348 = Misfire During Start Cylinder 4
P1349 = Misfire Cylinder #4 with Fuel Cut-Off
P1350 = Misfire During Start Cylinder 5
P1351 = Misfire Cylinder #5 with Fuel Cut-Off
P1352 = Misfire During Start Cylinder 6
P1353 = Misfire Cylinder #6 with Fuel Cut-Off
P0301 = Cylinder 1 Misfire Detected
P0302 = Cylinder 2 Misfire Detected
P0303 = Cylinder 3 Misfire Detected
P0304 = Cylinder 4 Misfire Detected
P0305 = Cylinder 5 Misfire Detected
P0306 = Cylinder 6 Misfire Detected
P0491 = Secondary Air Injection System Insufficient Flow (Bank 1)
P0492 = Secondary Air Injection System Insufficient Flow (Bank 2)
P0441 = Evaporative Emissions System Incorrect Purge Flow
P0455 = Evaporative Emissions System Leak Detected (Large Leak)
P0456 = Evaporative Emissions System Leak Detected (Very Small Leak)
Below are some of the MOST common problems/solutions. There may be other things that cause similar problems, but these are fairly easy to check visually, cheap and easy repairs. Many owners tend to just want to have a high priced single solutions like MAF, O2 sensors, ICV, Coils, Fuel Pumps, keep in mind that some of these items may be a contributing factor, however, it does not matter how many $100-$200 parts you throw on the car, if you have rubber hoses and gaskets leaking air, all the hard parts in the world will not solve your problems, they may help, but why not check the simple and cheaper things first, then check them off your list before you move forward. Except for the DISA O-ring, most of the other things can be visually inspected and tested very simply without a lot of dis-assembly. You can then rule these items in or out as potential problems within a few minutes if you know exactly what to look for.
Many of these problems are due to intake air leaks and/or crankcase air leaks of some sort, usually due to loose, damaged, broken or deteriorated parts, most likely rubber or plastic. Do not rule out crankcase leaks as the design of the engine keeps the crankcase under a small vacuum most of the time. A crankcase air leak is basically an intake air leak in these cars. The problem could be as simple as a dipstick not fully seated, a bad or loose oil fill car or a bad valve cover gasket or cracked valve cover that does not leak oil but can leak air/vacuum. Also in more extreme cases you can have vacuum leaks at the intake manifold to cylinder head connection. These gaskets have silicon rubber seals that can get heat set in the compressed state and leak only on cold start up situations.
A few ways to find and locate vacuum/air leaks is with a smoke tester (Internet search for more on smoke testers), using additional vacuum hose and using smoke inhaled from a cigarette or cigar, then blowing it into the vacuum hose to fill the intake or other vacuum lines, using a mechanics stethoscope with the transducer removed so you have open hose to you ears to attempt to locate a vacuum leak source while the engine is running, a 4 foot piece of hose to hold up to your ear to listen for vacuum leaks when the engine is running, and last but not least is a can of spray brake cleaner to spray and pinpoint vacuum leaks while the the engine is running. The spray brake cleaner will cause the engine RPM to increase slightly and smooth out when a leak is pinpointed. I have found via experience that very small and hard to find vacuum leaks, like where an intake manifold meets the cylinder head can be found much easily with spray brake cleaner than smoke testing or other methods. Also a note on smoke testing, many people swear by these, however, in practical terms, the smoke tester usually operate on very low pressure, usually 2-5 psi, they are usually only good for locating very obvious leaks that you should be able to find with visual inspection if you know where to look. I find that smoke testing may not show very difficult leaks like silicon gasketed surfaces such as the DISA or intake to cylinder head mating surfaces, this is where sometimes spray brake cleaner works much better. Be careful with spray brake cleaner on painted surfaces, breathing the fumes too much or getting it in your eyes due to splash back or air flow off the engine cooling fan. Use your head and be safe while working under the hood with the engine running, watch out for moving and hot parts, be aware of high Voltage ignition components and spraying flammable chemicals around!
Not in any specific order, but if you own an E46 (Actually almost any 6 cylinder BMW prior to the cut over to the e9x series models in 2005/2006), they are old enough now that these items should be replaced soon anyway. Please verify correct part numbers @ www.realoem.com to make sure you purchase and have the correct part numbers for your vehicle repair.
Here is a good link that has a complete DIY with pictures for most of the items listed below - https://forum.e46fanatics.com/showthread.php?t=643639&highlight=ccv
1. DISA Valve (sometimes referred to as an Adjuster Unit) #7 in this link - http://realoem.com/bmw/showparts.do?model=ET37&mospid=47720&btnr=11_2879&hg=11&fg=40. The DISA has a number of different failure modes, the DISA can have problems anywhere from vacuum leaks to catastrophic failure that may leave butterfly floating loose in the intake plenum and possibly the rear metal pivot pin could fall out and be sucked into once of the cylinders causing pretty severe engine damage.
SPECIAL NOTE ON THE REAR DISA PIN - The rear DISA pin can and will fall out depending on how badly the DISA butterfly plate is worn on the actuator shaft. This metal pin appears to be pressed into the rear of the butterfly and rotates with the butterfly plate. If the butterfly has become cracked or is overly loose on the actuator shaft, this metal pin (about 1/4" in diameter and about 13/16" long) could possibly become loose, fall out of the DISA assembly and work its way into a cylinder and may possibly cause severe engine damage. If you remove the DISA, immediately look for the rear metal butterfly pin and make sure it is still firmly pressed in. If you do not find the pin, check the intake VERY carefully for the pin and remove it if you find it. If you find the pin and it is loose in anyway, please remove the DISA flap and rear metal pin if you need to reinstall the existing, worn out DISA until you can purchase and install a new DISA
The first thing you want do is remove the DISA valve, pretty easy overall, remove the intake air filter box, upper intake boot and a few wire connectors and you are ready to access the DISA, you will need the Torx bit to actually remove the 2 DISA mounting screws. Once the DISA screws are removed, ease the DISA out of the intake, do not force it, there is only 1 angle that the DISA will likely come out and go back into the intake, it is not hard once you find the proper angle.
If the DISA valve slides out of the intake the first 1/4" easy, without much effort, or almost falls out, you will need a new O-ring!
Now that you have the DISA out of the intake, you need to check other functions to make sure you even want to re-use the DISA long term.
Special note for inspecting DISA valve, while you have the DISA out, inspect the DISA for proper operation. The DISA butterfly should be spring loaded in the open position and the butteryfly should not be overly loose or sloppy in the DISA shaft. You can also shake the DISA and it should not be noisy (new DISA will make absolutely no noise or rattle if shaken VERY hard). If you have any noise when shaking the DISA, something is most like worn and/or broken and you should consider a replacement DISA. Also the DISA rear pin can fall out into the engine and the DISA butterfly valve can fall off and get stuck in the intake possibly blocking the airflow to 1 or more cylinders, so it you remove the DISA and see no butterfly flap or rear metal pin, get worried and start looking for spare parts in the intake. If you are lucky the rear metal pin will be in the DISA groove in the intake.
Keep this in mind in case you suspect your car may have already had a replacement DISA, and if you have some strange performance issues, maybe someone left the old butterfly in the intake manifold if it fell off the original DISA??
The DISA is vacuum controlled and the small vacuum actuator on the end of the DISA is what actually moves the butterfly valve along with a control solenoid. Overall the DISA is a very ingenious device. The large body is actually vacuum reservoir. If look closely there is a very small hole near the butterfly valve this is the actual vacuum source. To verify if the vacuum actuator is still working and not leaking, close the DISA butterfly with your hand and then put your thumb over the opening that is opposite side of the electric connector on the solenoid. What should happen is the DISA butterfly will spring back open about 1/4" beyond the DISA frame. If the butterfly pops all the way back to the open position or slowly moves back to the default open position, then the vacuum actuator diaphragm is leaking and the DISA will not function correctly.
While there may be some sources that offer DISA "rebuild" kits, I would stay away from them personally. The butterfly valve and shaft are only part of the DISA, there is also an electrically controlled solenoid, actuator shaft seal and a vacuum diaphragm that actually moves the DISA valve and these parts can and will fail. The shaft/butterfly failure usually happens sometimes after the 100k mile mark, so if you car has the original DISA still, it is most likely ready for a replacement by now anyway. The vacuum diaphragm is more likely to fail than the solenoid and if the vacuum diaphragm fails you will end up with ANOTHER hard to find vacuum leak. There have also been a few reports of DISA vacuum actuators that test fine before the DISA repair kit was installed, but after removing the shaft and butterfly valve, after the vacuum actuator link was tweaked and twisted, the vacuum diaphragm was then cracked and no longer properly held vacuum. This is kind of expected from a decade old flexible rubber diaphragm, so just beware and be forewarned. If you are reading this thread, your car is clearly old enough now that if the butterfly is loose on the shaft or the DISA rattles when you shake it, just do yourself a favor and buy a new DISA and be done with your problem DISA for the next 7-10 years.
If you feel the DISA is physically in good shape and the vacuum diaphragm for the actuator is still in good shape and holds vacuum, then you may just need to replace the primary O-ring, which is not typically serviceable, however, you can get a red silicon replacement on for under $12 online or someone mentioned you might be able to match up something at your local parts store. Recommend a silicon O-ring as it is a bit softer than some of the harder rubber compounds and will tend to seal better with the plastic expansion and contraction over wide temperatures. I would be so inclined to put this replacement on a new DISA anyway as the DISA seal is only good for about 5 years/50k miles, after than you are on borrowed time. If for some reason you remove the DISA to replace the lower intake boot or do other work on the car, REPLACE the O-ring or you will be sorry once it gets below 40F. Trust me.
If you think your DISA should be replaced, following are some of the most common part number, but please check the part number before ordering a replacement for your vehicle. DISA prices online are between $175-$225 depending on the part number and the supplier. Prices change, however, check www.bmwmercedesparts.com for pricing as if this entry they have the 3.0 L DISA for $176.
DISA BMW part number - Please verify these via www.realoem.com to confirm proper application.
325/2.5L engines appear to use BMW Part #11617544806, this appears to have superseded an earlier BMW Part #11617502269
330/3.0L engines appear to use BMW Part #11617544805, this appears to have superseded an earlier BMW Part #11617502275
Both of the 325/330 DISA's have the injected or mold orange silicon main seal. SPECIAL NOTE - The 325 and 330 DISA appear to be very close in size, the main intake hole opening is the same size, however, the 325 DISA will fit into a 330 intake opening, but not the other way around. The 330 DISA is about 1/2" longer overall. Make sure you did not or do not end up with the 325 DISA in a 330 intake. I believe the 330 DISA will bottom out in the 325 intake before the flange meets the intake surface. As a point of reference, the last 7 digits of the DISA part number will be cast into the side of the DISA next to a BMW logo. So a 325 DISA should have either 7502269 for the original part up through 4/04 or 7544806 for the newer version used after 4/04. The 330/3.0L DISA should have either 7502275 for the original part up through 4/04 or 7544805 for the newer version used after 4/04.
Vehicle Tire Automotive wheel system Wheel Automotive tire
Taller (left side) DISA is for 3.0L engines, Shorter (right side) DISA is for 2.5L engines.
323/328 2.3L & 2.8L engines use DISA BMW part number - 11611440049, with the green removable O-ring. I have not confirmed for sure that the 2.3L/2.8L DISA has the part number cast into the side, but if it did, I assume it would have 1440049 after the BMW logo on the side of the DISA? Please verify part number and application.
Please verify part numbers @ www.realoem.com to verify proper part application for your vehicle!
If you feel your DISA is still serviceable, then I definitely suggest replacing the primary O-ring. Again, please measure your DISA and/or make sure when you order a replacement O-ring to specify your engine model as there are differences between the 323/328 & 325/330 series engines.
Note about the O-ring replacement, the 325/330 DISA has an orange molded/injected silicon seal in the groove, the 323/328 engines have a standard replaceable green O-ring. On the 325/330 you need to take a small screw driver and maybe a brass wire brush to scrape the groove clear of the original silicon before installing the new replacement O-ring. Then lube the O-ring with some silicon spray or clean light oil before reinstalling the DISA. The DISA will take some effort to seat it the last 1/4".
I do not suggest using any sort of sealer on the DISA O-ring area. There is an issue where the material needs to expand and contract to seal over temperature and any sort of sealer will not really work for the type of interface where this needs to seal in the inside of the hole in the intake manifold. What will happen is any sort of sealer will likely just make a mess that will need to be cleaned up once a proper O-ring has been installed.
PLEASE MAKE SURE YOU HAVE CLEARLY READ THE DISA SPECIAL NOTE ABOVE ABOUT THE REAR METAL BUTTERFLY PIN, WARNING, THIS PIN CAN FALL OUT ON EXTREMELY WORN DISA'S AND POTENTIAL CAUSE SEVERE ENGINE DAMAGE IF SUCKED INTO A CYLINDER
Sources for DISA O-ring
323/328 M52 Engines - Green removable O-ring
BMW Part #11617504543, this is a serviceable part for these engines.
http://www.ecstuning.com/BMW-E46-328i-M52_2.8L/Search/Disa/ES25713/ -
Your local auto parts suppliers may have something that fits?? Examples - Auto Zone, Advance, Pep Boys, O'Rielly, Fisher, but this may be a wild goose chase and it would probably be better to order the O-ring online so you will get something a bit closer in fit.
For the 325/330 M54 engines, the DISA O-ring is not a serviceable part, you have to remove the orange injected/molded silicon sealer and clean the groove out and install a replacement O-ring.
http://germanautosolutions.com/DISA_O-Rings.html
DISA O-rings for 325/330 engines have the following dimensions.
Some manufactures have an O-ring sizing chart. O-rings referenced as -136, -137, -138, -139 should all work. These sizes are 3/32" thick and range from 2" to 2 3/16" I.D.
Thickness - 3/32" (do not suggest anything thicker)
I.D. - 2" - 2 3/16"
O.D. - 2 3/16" - 2 3/8"
Preferred material - silicon, however, rubber may substitute
Thickness - 2.5 mm (do not suggest anything thicker)
I.D. - 51mm - 55 mm
O.D. - 55mm - 60 mm
DISA O-rings for the 323/328 engines have the following dimensions.This is for DISA's with the green, removable O-ring, not the orange molded seal. I also believe that the green O-ring DISA's are less problematic than the DISA's with the orange molded seal?
Again this is a BMW serviceable part, part number 11617504543.
Thickness - 1/8"
I.D. - 2"
O.D. - 2 1/4"
Thickness - 5.5 mm
I.D. - 51 mm
O.D. - 62 mm
Simple way to verify the proper O-ring thickness without having super expensive measuring systems is the following:
VERY, VERY simple way to measure the O-ring, it will cost you less than $0.10 to measure the O-ring accurately and you will not need to actually "spend" the $0.10.
If you buy an O-ring you want one that is 3/32" thick for the 325/330 applications, NOT 1/8" thick which many ebay sellers are shipping.
You will need 2 dimes to measure the O-ring thickness.
Toss the O-ring on a flat surface like a table, stack 2 dimes in the middle of the O-ring then use something flat like a card or ruler to lay across the O-ring, it should be almost exactly the thickness of the 2 dimes.
The thicker 1/8" O-ring which is the wrong one to use is the thickness of 2 quarters stacked.
Hope this helps people quickly determine if the have the proper thickness O-ring.
YouTube DISA Removal Video - http://www.youtube.com/watch?v=dhw6UpjhPXg contributed by SolidJake from the forum here.
Auto part Leather Fashion accessory
Auto part
Bumper Auto part Automotive lighting Automotive exterior
Vehicle Auto part Car Engine Automotive exterior
Auto part Trunk Vehicle
Auto part Diagram Automotive engine part
Auto part Engine Vehicle Car Fuel line
2. Lower Intake Boot, #6 in the this link - http://realoem.com/bmw/showparts.do?model=ET37&mospid=47720&btnr=13_0905&hg=13&fg=15, cracked or torn, usually at the small elbow connection point due to stress on the boot and the high under hood temperatures. About $20 depending on where you purchase it. Note that to really get at this, it is easier to take the DISA valve out to give you better access. Look very closely at the small flexible tube on the lower elbow as this is usually where the cracks occur. Its almost like you should just replace it anyway if it appears original as the rubber gets hard and cracks. A few notes, the hose clamps on the lower boot are very hard to reach. Many people cut the old boot to gain better access to the hose clamps. A 1/4" drive socket set with flex ratchet and a very long flat blade screw driver (12+") help here. Once hose clamp is loose, rotate then try to use the long screw driver to finish loosening the clamps. Also if you plan on replacing the upper intake boot, cut a slit along the plastic F connector so you do not break the connector trying to remove it from the original upper boot. Use silicon spray when installing the F fitting into the new upper boot.
Tools I use for the lower intake boot hose clamps - https://forum.e46fanatics.com/showpost.php?p=14120561&postcount=147 and I do all the work from under the hood, not under the car!
The parts numbers below are known to be for 325/330 engines, but again before you order parts for your car, please visit www.realoem.com and verify the proper part numbers for your application.
Lower boot, BMW part number - 13541435627 , this is the most common failed boot
Upper boot, BMW part number - 13541705209
F vacuum fitting, BMW part number - 13327503677
Personal protective equipment Auto part Tire Headgear Automotive tire
Fictional character Cg artwork Auto part
Auto part Vehicle Engine Car Fuel line
Tire Automotive tire Rim Auto part Automotive wheel system
Auto part Automotive piston Automotive lighting Automotive engine part Transfer case part
Product Plastic Plumbing fitting Pipe
Product Lens Camera lens Camera accessory Plastic
3. CCV (Crank Case Vent) lower oil drain hose, #4 in this link - http://realoem.com/bmw/showparts.do?model=BW53&mospid=47707&btnr=11_2194&hg=11&fg=15, BMW Part #11157532649 or for cold climate BMW Part #11157532629 which is probably the best option for all cars, it just has more insulation to keep it from freezing as easily if there is a lot of condensation in the oil. Also on Amazon - http://www.amazon.com/11157532649-9..._2?s=automotive&ie=UTF8&qid=1327346039&sr=1-2
Connects between the dipstick tube and the bottom of the CCV. The connection to the bottom of the CCV is a bit tricky to unlatch blind, but it can be performed without taking anything but the air filter box out. I find if you get the end of the hose off the dipstick it makes it easier to rotate the snap fitting on the bottom of the CCV. I use a long (14-16") flat blade screw driver to help push off the CCV oil drain hose from the bottom of the CCV while I squeeze the release bail as it is VERY hard to squeeze the release bail and pull down at the same time from under the hood. It is not easy to get your hand down there, but it is possible. Make sure you hear a sharp click when you reinstall the oil drain hose, otherwise your bail connection is not secure.
There are other hoses connecting the CCV and they may also go bad over time, however, the lower oil drain hose seems to be the most common failure point. Additionally the CCV valve itself and the dipstick tube can also cause problems, however, these may be more to do with oil plugging the drain passages and cause oil leak and even possibly hydro lock the engine if things go really bad. More often in the much colder climates, however, the CCV is an issue all to itself and a search on the board here will offer many stories and solutions. One very good overall CCV thread is this one - https://forum.e46fanatics.com/showthread.php?t=870406
Pictures of a failed lower CCV oil drain/return hose are below. Note the thicker hose is the cold weather part number, this is what I would suggest installing. If you are in a bind, you can use 3/8" fuel line 10 3/8" in length but you may need to use spray silicon or heat the end of the hose to get it onto the CCV drain connector. It is a bit difficult to release the CCV hose connector in the blind, but if you notice it had an oval shape release collar, you pinch the wider part of the collar to make is circular and then it should release straight downward.
Lower CCV Cold Weather Oil Drain Hose, BMW Part Number - 11157532629
Complete ECS Tuning Cold Weather CCV kit (not you may want to also get the updated single wall dipstick and the larger, plastic air distribution manifold and 6 O-rings in addition to this kit?) - http://www.ecstuning.com/BMW-E46-325i-M54_2.5L/Engine/Emission/Oil_Separator/ES260026/
BMW M54 Engine Cold Weather CCV update part numbers
E46 (3 Series) rear-wheel drive only
Part Number Description Quantity
11 61 7 534 237 Oil Separator Repair kit 1
11 43 7 565 437 Dip Stick Guide Tube 1
11 15 7 532 629 Hose 1
E46 (3 Series) all-wheel drive only
11 43 7 565 438 Dip Stick Guide Tube 1
Auto part
Fuel line Hose
Hose Fuel line
Auto part
Auto part Line art
Pipe Water Plumbing Auto part Plumbing fixture
4. SAP (Secondary Air Pump) issues - First you need to make sure the SAP air pump actually runs. There are electrical controls, fuses, connectors that can contribute to a non working SAP air pump. Additionally the actual pump can fail as well, there are bearings that can and will go bad, causing a very noise pump and the bearings could possibly seize as well. I expect theh pump could also fail electrically, but for the most part I have seen/heard pumps with bad bearings that get extremely noisy. Noisy to the point that the pump can be heard 3-4 houses away when the car is started in the morning! So if you have any SAP specific codes, please make sure your SAP pump motor is working before you focus too much on hoses, valves and other items.
Rubber hose between the air pump output and the SAP air control valve, item #2 the following link for earlier cars - http://realoem.com/bmw/showparts.do?model=AR73&mospid=47730&btnr=11_2188&hg=11&fg=50. There appears to be AT LEAST 2 different part numbers depending on the model and year of car, BMW Part #11727555680 appears to use hose clamps on earlier cars, BMW Part # 11727555681 appears it may have quick connects used on later cars or 3.0L engines (330 cars)?? Check the part number of your application on www.realoem.com.
Might not cause stalling or a misfire, but can cause a CEL/MIL to light. These hoses start to break down due to the high heat from the exhaust transferring to the SAP air control value. They can cause problems with the SAP air control valve clogging or getting blocked.
SAP air control valve vacuum lines, items #3 & #4 in this link (Note - not all cars have a vacuum operated SAP air valve)- http://realoem.com/bmw/showparts.do?model=ET37&mospid=47720&btnr=11_2203&hg=11&fg=45 (both hard and soft line along the valve cover where the O2 sensor wires are routed) can leak vacuum and cause rough engine during cold start and possibly CEL as well. The SAP vacuum hoses, mainly the hard plastic pipe, crack due to heat over time and usually cannot be seen. Also the vacuum hose to the SAP air control valve usually do not pull vacuum except for the first 90 seconds on cold start so they often get missed when inspecting for leaking vacuum hoses. Note that not all engines have this SAP check value vacuum hose. I believe?? 3.0L engines/330 cars may not have this vacuum operated check valve (still trying to verify this)??? I believe if your air pump main output hose has the quick connect ends and not standard hose clamps, the SAP check valve is not vacuum controlled??
Also keep in mind there are a few other parts associated with this vacuum control circuit. There is the electric control solenoid valve, a vacuum check valve and a few other short vacuum hoses under the rear of the intake manifold and they are VERY hard to see and access, again, not all engines have this configuration. The electric check valve has been known to get debris in it from deteriorating vacuum lines and hoses. This debris can either block/clog the electric control solenoid valve or it may cause the debris to keep the electric valve from completely closing. If this electric valve gets partially stuck open I am not sure what symptoms will show up. The small plastic check valve and the few associated short vacuum lines can also be a problem. The issue is they are very hard to inspect and access. See picture of the underside of the intake manifold below a better view of what these items look like.
Simple test for the SAP air valve vacuum hose is to disconnect the small vacuum hose at the SAP air valve and connected a vacuum gauge to this connection and make sure there is vacuum applied for approximately 30 seconds or more on cold start up. The vacuum gauge should read approximately 15+ inches of vacuum. If you do not have a vacuum gauge, you should be able to use your finger to block the end of the hose to see of the hose is pulling vacuum on cold start up. If you do not get vacuum, then it is likely there is a problem with the vacuum hoses between the SAP air control valve and the connection under the rear of the intake manifold. Most likely cause is the hose and hardline from the SAP vacuum control solenoid under the intake around the rear of the valve cover and along the side of the valve cover near the O2 sensor wires.
The SAP vacuum control solenoid and a few additional shorts vacuum lines and a small check valve are all buried way underneath the rear of the intake manifold and are very hard to see and access. You really need a good light and a mirror. These short sections of vacuum hose and the small check valve can also be problems and you cannot easily tell if they are a problem, but I would probably replace the vacuum hose between the SAP air control valve and the SAP vacuum control solenoid first before I fought with the parts under the intake.
Note the vacuum line from the SAP vacuum control solenoid to the SAP air control valve only has vacuum applied for the first 30-120 seconds (typically around 90 seconds) on cold start up. So if you car runs fine from 90-120 seconds and beyond, I would think this is a likely source of your problem.Also keep in mind the SAP vacuum control solenoid vents to atmosphere when de-energized (engine off or SAP not running) , so you blow backwards from the SAP air control valve or use a smoke tester you will have leakage on the SAP vacuum control solenoid at the air vent, this is normal.
A few good SAP links to check over -
https://forum.e46fanatics.com/showpost.php?p=17161645&postcount=154
https://forum.e46fanatics.com/showthread.php?t=1041726
https://forum.e46fanatics.com/showthread.php?t=1023149
https://forum.e46fanatics.com/showthread.php?t=965526
https://forum.e46fanatics.com/showthread.php?t=1052605
https://forum.e46fanatics.com/showthread.php?t=1074847
https://forum.e46fanatics.com/showthread.php?t=1074573
https://forum.e46fanatics.com/showthread.php?t=106959
https://forum.e46fanatics.com/showthread.php?t=1078986
https://forum.e46fanatics.com/showthread.php?t=1096889
https://forum.e46fanatics.com/showthread.php?t=1100895
https://forum.e46fanatics.com/showpost.php?p=17091432&postcount=28
https://forum.e46fanatics.com/showpost.php?p=17091517&postcount=29
http://www.bimmerfest.com/forums/showthread.php?t=430048&highlight=secondary+air+system
Late model MAF based SAP system info - https://forum.e46fanatics.com/showthread.php?t=965526&highlight=priceless
http://www.bimmerfest.com/forums/showthread.php?t=898977
https://forum.e46fanatics.com/showthread.php?t=809715
https://forum.e46fanatics.com/showthread.php?t=670441
https://forum.e46fanatics.com/showthread.php?t=921500
Page 6 of this BavAuto Fast Times Newsletter - https://www.bavauto.com/newsletter/2008_n408_newsletter.pdf
In the parts diagram below, item #3 which is the harder plastic vacuum line that runs along the valve cover gets extremely brittle and breaks easily, many times on the bottom where it is not visible. Many people just replace item #3 & both sort sections of item #4 with a single piece of vacuum hose from the SAP air valve to the extremely difficult connection to reach under the intake manifold. Also note there are a few additional short sections of rubber vacuum line that can also cause you problems under the intake, items #7 & #9.
Auto part Automotive lighting Automotive super charger part Automotive engine part Automotive window part
Auto part Automotive fuel system Fuel line Wire Vehicle
Auto part Vehicle Car Engine
from dslboomer
5. Basic vacuum hose leaks from caps, T's, fittings and hoses
Often overlooked at the 3 vacuum nipples located on the underside rear of the intake manifold. These 3 nipples can have a mix of vacuum hoses and/or vacuum caps plugging unused ports. The problem is the vacuum caps crack and can also fall off and cause misfiring and problems with cylinder #5 & #6. This area is hard to access and unless you know exactly what to look for with a mirror and strong flashlight, Smoke Testing may be the best way to verify leaks in this area of the engine.
Here are some useful links with pictures of what the underside of the intake manifold and some of the vacuum caps look like.
https://forum.e46fanatics.com/showthread.php?t=1074573&highlight=intake
https://forum.e46fanatics.com/showpost.php?p=17085769&postcount=36
https://forum.e46fanatics.com/showpost.php?p=17094253&postcount=2
Hand Finger Joint Mouth Auto part
Auto part Fuel line Pipe Engine Muffler
Finger Hand
Sensitive content, not recommended for those under 18
Show Content
Finger Hand Jeans Leather Thumb
6. Check for coolant and oil ingress into the DME connectors. This is becoming a bit more common unfortunately.
https://forum.e46fanatics.com/showthread.php?t=1052977
http://www.bimmerfest.com/forums/showthread.php?p=9977321#post9977321
https://forum.e46fanatics.com/showthread.php?p=16833498&posted=1#post16833498
https://forum.e46fanatics.com/showthread.php?t=870338
7. Check the DME for coil driver chip damage. We are starting to see some of these show up as the cars age.
https://forum.e46fanatics.com/showthread.php?p=17093725&posted=1#post17093725
https://forum.e46fanatics.com/showthread.php?t=1114872
http://www.digikey.com/product-detail/en/infineon-technologies/IRGS14C40LPBF/IRGS14C40LPBF-ND/812253
8. Power brake booster and booster hoses leaking. We are starting to see these problems show up now that every E46 is 10+ years old.
https://forum.e46fanatics.com/showthread.php?t=1057387
Sucking Jet Pump Links
https://forum.e46fanatics.com/showthread.php?t=1061188
https://forum.e46fanatics.com/showthread.php?t=523763
http://www.bimmerfest.com/forums/showthread.php?t=578766
9. Smoke Testing is the way to quickly and easily find intake and crankcase air leaks.
https://www.youtube.com/watch?v=AsgB9eBl58I
https://youtu.be/1sRZ5ves1DM
https://www.youtube.com/watch?v=EhNQiIRsCCk&feature=youtu.be
https://forum.e46fanatics.com/showthread.php?t=1115860
Cheap fluid transfer pump from your local auto parts store or Amazon.
http://www.amazon.com/ABN-Multi-Use...=1-1-spons&keywords=fluid+transfer+pump&psc=1
A few rubber gloves, rubber bands and some cheap mini cigars from our local gas station or convenience store. You can also use a cheap E-cigarette and it may be safer than a lit cigar as well. Not sure if you can use mineral oil in the E-cigarette or if this would be to flammable.
Also get a good, bright LED flashlight to locate the escaping smoke. Look deep in the engine compartment and under the engine if needed. Do not forget the dipstick guide tube and the lower CCV oil return line. These areas may be hard to see from above in the engine compartment.
After looking for intake air leaks, remove the oil fill cap and allow the crankcase to fully fill up with smoke, then replace the oil fill cap. Check for cracks in the valve covers and leaks around the grommets, half moons and around the perimeter of the valve cover.
Common areas of leaks:
Upper and lower intake boots
Upper intake boot around F connector
DISA main O-ring and shaft area
Vacuum hoses under the rear of the intake
Fuel pressure vent hose that connects to the F connector on the upper intake boot and under the drivers floor board where it connects to the fuel pressure regulator
CCV and hoses, especially the lower oil return line
Dipstick and dipstick guide tube
Oil fill cap
Valve cover gaskets and cracked valve covers
SAP vacuum line to Kombi valve on front of engine, this will not leak smoke because of the control valve under the rear of the intake
Power brake booster sucking jet pump and hoses.
Note that the brake booster usually cannot be smoke tested because of the input vacuum check valve at the booster connection.
Other areas to look at include:
Intake manifold gasket, this can leak to single cylinder, cold start misfires that usually only happen after sitting overnight and at temps below 50F. These are almost impossible to test for with smoke and/or spraying with brake cleaner or carb cleaner.
CCV overall, but the oil drain back hose is the most common failure point.
Fuel Pressure Regulator vacuum hoses - https://forum.e46fanatics.com/showpost.php?p=14087261&postcount=30
Plastic check "T" fittings and associated rubber vacuum hoses and rubber caps - https://forum.e46fanatics.com/showthread.php?t=921500&highlight=
IAT (Intake Air Temperature) sensor O-ring leakage, O-ring is cheap and easy replace. BMW Part #13621743299 Note the IAT is located between intake runner #3 & #4 under the main engine cover.
ICV and its L shaped hose that connect near the throttle body.
Throttle body O-ring.
Upper intake flexible boot from MAF to coupler.
Power brake booster vacuum hose.
Air pump check valve vacuum hose.
Idle control valve and associated hoses.
Dip stick O-ring(s).
Fuel injector O-rings.
Oil fill cap.
Valve cover gaskets and small top seals.
Air distribution manifold and O-rings, over top of the intake manifold with a connection to each intake with an O-ring.
Fuel pressure regulator vacuum hoses.
EVAP hoses and valve.
VANOS seals, usually cause more MPG loss and upper RPM loss of performance, however, many have claimed that VANOS seals have help these issues.
Almost all of intake air leaks can cause misfire codes, O2 sensor codes, fuel trim codes, rough running and stalling. All these parts are basically rubber and after 7+ years and are starting to fail because they are subjected to high heat, gas and oil vapors, thermal cycling and vibration and it is time that they be replaced.
Lately there have been a lot of owners that have been dealing with what appears to be single cylinder, cold start misfires that cannot or do not appear to be corrected by eliminating vacuum leaks and they are being given advice to open the engine and replace lifters or take other drastic measures. There seems to be a lot of consensus that there is no way a vacuum leak can cause a single cylinder misfire. I say there clearly are certain vacuum leaks that will cause single cylinder misfires and it is my position that I would invest the time, money and effort to replacing hoses, seals and gaskets long before I would be taking the engine apart. You do have to use some logic on your approach and make decisions along the that that maybe you will pull injectors and have them professionally cleaned by someone like www.witchhunter.com before you possibly may pull your intake and/or tear into the motor. Also you may want to make sure you have performed a cylinder leakage and compression test long before removing the intake as well. Also do not forget to actually make sure the connector to the problem cylinder injector and ignition coil are tight, you may want to take a sharp pick and actually try to tighten the terminal inside the connectors for the injector and coil.
There has been some discussion that hydraulic lifter bleed down may be the cause of single cylinder, cold start misfires. This may be the case and a few owners have had lifters replaced, however, it is really hard to tell if the lifter was really the problem, or if when replacing the lifter a leaking valve cover gasket and/or other hose or gasket may have also been replaced during the repair that may have really been the source of the problem?? If it was my car, the LAST thing I would even consider would be to tear into the engine unless I had a really good idea that I had ruled out all the basic maintenance issues and common problems these car tend to have as they aged. Again, I would be focused on eliminating possible burnt valves early on in the process with cylinder leakage and compression testing, then methodically address the move obvious problems as I did things like professional injector cleaning and determining if intake manifold gaskets should be replaced.
10. Engine mechanical problems and restricted/clogged catalytic converters/exhaust
Something to also keep in mind, if you are totally unsuccessful in isolating a persistent misfire problem, please keep in mind you may in fact have an engine mechanical problem. Although rather rare, there have been a number of higher mileage cars that have been found to have a burnt exhaust valve in one cylinder. We have also been been seeing restricted and/or clogged catalytic converters also causing loss of engine power, performance and at times misfiring and even Lean codes. If this is the case the repair cost, required skill, time and effort is greatly increased. One problem is the sale of used catalytic converters tends to be against the law, so you will not likely be able to buy used exhaust manifolds with integrated catalytic converters from any junk yard/dismantlers. If you are lucky, you may be able to find a Forum member than has installed headers or has a parts car that may have a good used set of catalytic converters
When all else fails, do not forget to check the engine compression and perform a cylinder leakage test! I do not usually suggest these tests up front because the majority if these problems can be addressed with basic maintenance, however, as these engines get more and more miles added on to the odometer, we may need to change the philosophy about when to perform compression and cylinder leakage tests.
Following are some recently examples of burnt exhaust valve that caused persistent misfire problems both cold and hot along with some clogged catalytic converter threads:
https://forum.e46fanatics.com/showthread.php?t=889143&highlight=
https://forum.e46fanatics.com/showthread.php?t=904997&highlight=burned+valve
https://forum.e46fanatics.com/showthread.php?t=1124176
https://forum.e46fanatics.com/showthread.php?t=1123756
I had a car the other day with over 12 CEL/MIL trouble codes that included misfires on individual cylinders, misfires on multiple cylinders, O2 sensor out of range, O2 sensor codes, fuel trim codes.
Turns out the primary problem was the $11 CCV oil return hose between the CCV and the dip stick tube, also the DISA O-ring was rather loose. $25 later no CEL/MIL, no trouble codes, no misfires or rough running.
Quick suggestion, if you car is running poorly now that the weather is cold, replace at least the lower intake elbow, the DISA O-ring and the CCV lower oil return hose, clear the DME codes, about $50. Then worry about other things if the car is still running poorly or has additional CEL/MIL codes.
Other items that can cause problems and need to be kept in mind are (in not specific order): VANOS seals, MAF, Fuel Pump & Pressure Regulator, Coils & Coil Boots, Spark Plugs, O2 Sensors, Cam and Crank Sensors.
NOTE: Many times the Mass Air Flow sensor will soft fail or degrade over time and cause an under reported airflow amount, which in turn may cause the long term fuel trims to increase above the 10% mark. An indicator of a degraded or soft failed MAF may be that the short term fuel trim is within +/- 3% or less at idle, but your long term fuel trims are much further off. Additionally a degraded or soft failed MAF may cause the CEL to come on only on the highway and not around town. Vacuum/air leaks are more likely to trigger a CEL during idle and round town, where a degraded or soft fail MAF is more likely to trigger while on the highway.
Before proceeding with parts purchases, I have made every attempt to present accurate information here, however, it is your responsibility to verify part numbers @ www.realoem.com or other BMW parts guide to verify proper part application for your vehicle!
You can them use the BMW Part Number Price Comparison tool to find the best pricing on replacement parts - www.bmwpnpc.com This is a great tool written by a Fanatic right here on our forum.
Footnote/disclaimer on this thread, sorry if it seems some of my writing is a bit disjointed. This originally started out as a very simple 1-2 paragraph look what problem I had and how I resolved the issue. But then the thread this took on a life of it own. Many, many additions and edits and although I am not very proud of what I have put together, it will hopefully help some of you out with your problems. If I had enough time, I should really sit down and rewrite this information from the ground up so it is a bit more cohesive and clear, but I think overall most of you can see beyond my ramblings and will get the point. I do from time to time make corrections and additions as needed and as long as this thread has the edit feature still active, I may make slight corrections and additions from time to time. I hope this has helped some BMW owners out with identifying and correcting their issues and allow you to keep you car reliable.
Special thanks for the many other Fanatics that have allowed me to use some of their photos to illustrate this thread and help out the community! Also this information is a work in progress, if there are any mistakes, errors or omissions, please PM me with specific details, corrections and comments
See less See more
30
#264 ·
A few things.
1. If your header gaskets are leaking at the cylinder head, then this can possibly let air enter the engine and play games with your pre Cat O2 sensors and trigger lean codes. So some of your problem with the P0171/P0174 may be related to leaking header gaskets as the cylinder head?
2. I would swap the horn relay and the fuel pump relay. Fuel pump relays in these cars are known problem areas. The relays are behind the glove box. I think you can easily unscrew the glove box and remove it for easy access to the relays? 4 relays mounted up top. Fuel pump left most relay, horn is right most relay. Price is right!
3. Unclear if your current problem was a flooded engine? Did you try to start it many times before you floored the gas pedal? Did you use starting fluid this time?
4. Fuel pressure testing, I have not confirmed this on my E46, my wife's car so I do not play with it like my M5! But it appears there should a pressure testing point on the fuel rail near the front of the engine under the main engine cover. You can probably rent, buy or borrow a gauge from a parts store and test it. Fuel pressure should be 3.5 +/- 0.2 BAR or between 47-53 PSI.
#265 ·
I agree with jfoj, a no-start condition is one of the three: spark, fuel or air (maybe too much air!). I would definitely try the starting fluid into the intake to see if it starts then dies (fuel issue). Also, can you do a smoke or low pressure test of the intake system? I couldn't find any leaks on mine until I pressure tested it and found a rather large leak in the VCG. Let us know how the motor mounts go, I'm looking into doing mine soon. Good luck, I think we can all feel your pain when the problems seem unbeatable.
#267 · (Edited)
Every time you turn key on the fuel pump primes for 5-10 seconds.
#268 · (Edited)
Well, I'd like to share my experience and hopefully make a helpful contribution to this thread. For those tackling the CCV and the intake boots for the first time, the tools in this pic will be of help. Assorted torx bits for your rachet and a flexible driver with 6mm socket. The flexible driver is your best friend for the intake boot clamps.
The T27 torx screw in the pic below holds a bracket that is in the way of getting a clear run at the bellows clamp on the throttle body.
When I started working on the vac lines from the SAP to the electric valve under the back of the intake, I simply could not get my hands back there. I then realized that the firewall cover to the cabin ventilation system could be removed with just two screws.
More to come....
#271 ·
Pumps are known issues, swap the horn & fuel pump relay.
#273 ·
The pump still turns on so the relays fine. Swapped it anyways and the same happens.
I bought a wrecked car for parts several years ago, and it had been sitting in the same spot for 4 years, with no battery. I towed it home, and 3 years later, I went to pull the injectors, and found out the hard way that the fuel sYstem was still fully pressurized, after sitting for 7 years. So, yes, you may have a problem.
That's exactly what I wanna here. New fuel pump on its way from pelican parts. Tuesday delivery.
#274 ·
Are you sure there is enough fuel in the tank? See my sinature below for hidden OBC menu. Check tank levels via OBC.
#276 ·
I have the cold start misfire issues pretty much the same as described at the beginning of this thread by the OP and so many others. My car runs great when warm and has 220K on the clock. Here are some more things I discovered along the way towards trying to fix this issue.
I have replaced the entire CCV, put a new gasket on the DISA and put in a new dipstick O-ring. My DISA has no rattles, a good return spring, and passed the vacuum diaphram test. I replaced the VCG about a year ago. I also replaced the throttle body gasket and the grey tubing for the idle control valve begause it was hard and didn't seem to be making a good seal. Even with all this, I STILL have the cold start misfire codes. So, I began thinking about the other sources of leaks as noted by the OP.
I used the SAP testing described by Bavarian Autosport and everything seemed to be functioning just fine during the cold start period. Nevertheless, when I tested the vac line from the SAP to the vacuum switch, I could hear air leaking behind the manifold. So I changed out all the rubber tubing. Once I got all the vac lines reconnected, I blew air though again to test it out for a good seal. To my surprise, I could still hear air leaking and it was coming from the vacuum switch. So, I figured maybe the switch was working, but had a leak, so I ordered a new one as well as the little black and white filter unit.
HERE IS A WORD OF WARNING, EVEN THE NEW VACUUM SWITCH WILL LET AIR THROUGH WHEN YOU BLOW FROM THE SAP VALVE TOWARDS THE SWITCH!!
Apparently this is normal, so I did not need to replace the switch. However, I am glad I replaced all the lines because they were in bad shape.
I also found the rubber cap for the large vacuum opening on the underside of the intake was in bad shape. I got one of these kits from NAPA;
You can see the one I used in this pic, next to the vac line that goes to the SAP vac switch;
Here is another odd discovery. I found another vac nipple right next to the small one to the vac switch, with no plug or tubing (its in the mirror, but hard to see). I wondered what it was so I went back to look over this picture from the beginning of this thread;
The car this intake came from has a vacuum line attached to the nipple I found. Its the one going off to the upper right in this picture. Anyone know where this vac line goes when installed? I have no other vac lines like this in my car, so I capped the nipple with one of the rubber plugs.
Even after all this, I still have the following codes at cold start-up;
(PEAK tool)
Ca = O2 sensor control limit, Cyl #1-3
Cb = O2 sensor control limit, Cyl #4-6
E3 = O2 sensor adaptation limit, Cyl #1-3
E4 = O2 sensor adaptation limit, Cyl #4-6
F1 = misfire, Cyl #4
The pre-cat O2 sensors were replaced with OEM units just last fall. I also had a dead fuel pump then and replaced that and the fuel filter. The vac lines to the pressure regulator on the filter are in good shape.
If I hold the throttle to 1200rpm during the cold start period, I do not get any codes and no SES. Let her idle on her own and get the codes. Once she's warmed up, no issues. However, two times this winter I did get a misfire code while driving, 45 minutes into my trip home from work. This went away after a restart.
I have swapped around the coils in the past, and the misfire did not follow the #4 cyl coil. However, I swapped it again today with #2 to test this one more time. I will see what happens in the morning when the car is cold again.
Seems like I've done it all, but still have this issue. Anyone have a thought on what to try next? :banghead:
#277 ·
The SAP electric vacuum control solenoid under the intake bleeds air/vacuum to atmosphere when there is no electricity powering the solenoid valve, this is normal.
As for your codes, you may need to perform the brake cleaner spray tests around the intake manifold, under the air distribution manifold, IAT sensor.
Some CCV units have a port that needs to be plugged off on the side of it. Did you look your CCV over very closely to make sure there was no open vacuum port? If it was a cold weather, insulated CCV, it may have been hard to see with the insulation on?
I assume the intake manifold in the picture is not yours?
There are injector O-rings, O-ring for the air distribution manifold so there are a lot of other places to end up with vacuum leaks. Also depending on how far you decide to dive into the engine, you may even pull the injectors and send them out to someone like Witchhunter.com.
Did you change the fuel filter out and also check the fuel pressure regulator vacuum line under the car?
Power brake booster can be another source of vacuum leaks, but usually you can identify this by other means.
You may be in a situation where a compression test and cylinder leakage test may be useful?
Coil boots?
Can't think of anything else off the top of my head right at this moment.
#278 ·
Coil boots?
I did get the cold weather CCV kit. I honestly can't remember if the valve unit comes with the vac port plugged. My car did not have a vac line coming from the CCV valve on the original I replaced. Maybe I can call BavAuto and they can tell me if new units come with the port plugged.
The intake in the pic is from the beginning of this thread, not mine.
When I put in the new fuel filter I did check the vac line to the regulator. The rubber is in good shape, but I put a small hose clamp on it to make sure it sealed well.
All the coil boots seem to be in good shape. The rubber remains soft and pliable.
The starter fluid spray seems like the best thing to try next to track this issue down. If its bad rings leaking compression, I'll just have to live with it. Given how common this issue is, it has to be a leak somewhere. May need to bite the bullet and find a shop who can do a smoke test. Sure would be nice to track this down myself though. Thanks for the ideas!
#279 · (Edited)
Not likely rings on these cars unless the car was really run low on oil and/or overheated badly enough to cause the rings to expand, butt and break.
More likely a burnt exhaust valve if it is a mechanical problem with the engine.
Compression test and cylinder leakage test will quickly verify if you have a burnt exhaust valve.
But you may very well have some sort of vacuum leak still, even the intake to cylinder head interface can be a problem, more so when cold and it may not show up with a brake cleaner spray test once the engine has warmed up for 2+ minutes. This is because the silicon gaskets get heat set in a compressed state after many years and many miles and they will not spring back enough to seal up surfaces when parts are cold and contract.
#282 ·
Thank you for the additional thoughts. I tried the brake cleaner diagnostic. I did it during a cold engine start for all of the reasons you described. Makes sense. Never got a surge/change in idle speed. Tried spraying everywhere their is potential for a leak, including intake to cylinder head. Only so many spots you can reach though.
One thing I did discover is the spark plug to #4cyl was not torqued correctly (my bad). Correcting that eliminated the four O2 codes. Progress.
Still have two misfire codes at cold start, #4cyl and now #3cyl. We'll see what she throws today.
#283 ·
Assume you has the primary engine cover off?
You may need to try a smoke test as well?
#286 ·
Hey guys!
Okay so I replaced my fuel pump and she's a different car!
When the ignition on I can actually hear the pump. Different tone then my old one. I knew there was much more pressure! She fired right up! No hesitation! My damn failed motor mounts broke my power steering reservoir so I couldn't take her out yet. I replaced those motor mounts and my leaking exhaust gaskets. Those bolts were a a** to get out. I could only get 3 back in. That last one stripped. Muffler shop will take care of that soon. Doesn't leak with one bolt so I'm good for now. But yeah that reservoir comes in tomorrow and I'll update on how she runs. :)
#289 · (Edited)
Well on my way to autozone to clear my codes I stopped at a gas station to pick up a drink. Started the car again and the cel light was gone! I was like no way!. It's been 250 miles since I cleared the codes. Cel popped up 5 miles after I cleared them and I just left it on. Went to Boston and back the next day. After that trip the day after I replaced the fuel pump. Never cleared the codes. 10 miles after I replaced the pump on my way to clear the codes the light goes away! So it should be all good now right? Is 250 miles enough for emissions testing?
#292 ·
Get it done ASAP.last year, before my inspection, I was getting an intermittent CEL. I had no time to diagnose or fix it at the time, so I would just wait for it to go off. It was a vac leak somewhere, and on really hot days, it would seem to seal up enough for the light to go off.
In NC, you have to drive 90 miles after a CEL cleared to pass inspection. So, when it would go off, I would get on the beltway, and drive circles around the city until I had 90 miles without a CEL. Several times it would come back on, and I would have to give up. Two of those times, it came on just as I pulled into the inspection place.
I was finally able to get to the inspection place with 90 miles without a CEL, and get my inspection done. So, if it is off, then get your car in for an inspection tomorrow!
#290 ·
It is possible that some of the codes that trigger the CEL will clear by themselves. Usually some of the parameters are configured that after X amount of start/stop cycles the CEL may automatically clear of the problem is back in a "normal" range.
Now a few things to keep in mind, the emissions readiness monitors take a while to clear. Usually 3+ engine runs from cold start, with no engine speed over 3k RPM and you may need to drive as much as 10-15 minutes at 45-55 MPH.
The Evap system is usually the last and most painful to get to readiness monitor to clear. Usually you need somewhere between 1/2-3/4 tank of fuel for these to clear quicker.
If you need an emissions test, a few things to remember.
1. Do not clear codes on the car with a scan tool unless you feel you need to as every time you clear the codes, the system readiness monitors have to reset as well
2. If you are is sure your problem is repaired or heading in the proper direction, sometimes you can get a CEL to come back on, but sometimes stopping the engine and restarting may clear the CEL automatically.
3. Some states allow up to 2 emission readiness monitors to not be cleared or turned off for an inspection. Depending on the year of the car and the state. You need to check your states requirements to see if they allow any, 1 or 2 emission readiness code to be not clear and still be eligible to pass inspection.
#291 ·
Tomorrow I'll still get her scanned. But the car is just so much different! I really believe this is it. She doesn't hesitate. No stalling. When I remove the oil cap she doesn't almost stall like she did before the idle actually just slightly changes but it still sounds fine. I've got 1/2 tank now. The pump sounds totally different. The pressure at the fuel rail is where it should be now. I replaced all these parts and the faulty part was the damn pump. haha. Still I know now that all those parts I replaced were going to need to be replaced sooner or later so it works out.
The scanner will tell me my readiness codes.
I'll keep updating. :)
#296 ·
I finally got my reader and pulled my codes that I had after doing the CCV, VCG, spark plugs, etc.
In the Peake manual it's Graph19
CA-O2 sensor control limit cyl.1-3
E4-O2 sensor control limit cyl. 4-6
EE-Cyl1 Misfire
EF-Cyl2 Misfire
FO-Cyl3 Misfire
E3-O2 sensor adaptation limit cyl. 1-3
Cb-O2 sensor adaptation limit cyl.4-6
FA-Functional check purge valve
Background is that after I did the work on the car, it would randomly have a poor idle and loss of power for short periods. A few days ago the check engine light cleared itself and it has been running fine ever since. I just pulled codes today. While doing the work the line to the Evap solenoid snapped off, I had to rig it back together with some clear tubing and hose clamps.
My guess is that after I did the work the car was getting a lot different vacuum than it was used to, which might have thrown the O2 sensors for a loop. The weird readings on the O2 sensors could've caused all the misfires(poor power and idle), and it was fine once it relearned what was going on.
Either that or the snapped evap line caused some problems, I've heard you're not supposed to disconnect that.
If anyone else has some better insight please feel free to pipe up. I'm just taking my best guess right now.
#297 ·
I had the exact same codes after changing my plugs. I didn't torque one down properly. Fixed that and replaced a number vac lines and gaskets. No codes for 5 days!!! Check the plugs first, then check for vac leaks. Could be a combo of things. Hopefully, it's just the line you found already. My 2 cents
#298 · (Edited)
Suggest you do not get overly excited about the CEL coming on if you think you have resolved most of your problems.
Many times the DME adaptations need to readjust before things settle in, so you may get a sporadic CEL after repairs.
If the problem is really resolved, many times the CEL will clear itself, you may still have codes in history, but the CEL will turn itself off.
Suggest you drive the car for 3-5 days and see what happens. You can continue to read and monitor codes, suggest you log them, but you may want to delay actually clearing the codes if you feel the car is running correctly and you feel you found most of the problems.
But also keep in mind, you may have other issues that still need attention even after resolving most of the obvious vacuum/air leaks.
We are seeing fuel pump, filter and pressure regulator vacuum line issues cause problems as well and they are not usually "hard" failures that do not leave the car stranded, but situations where "soft" failures are causing fuel pressure problems.
An yes, you could have other unusual problems like loose plugs, bad fuel, bad ignition coil(s) and/or coil boots that can have you pull your hair out.
#299 ·
My car misfires, did a scan and no codes were shown. I know there is a vacuum leak somewhere, but not at the hoses. When i remove the oil filler cap, there is suction pressure. I'm going to replace the CCV Valve. I have pulled the disa and inspected it, but it in excellent condition, i re-installed it, but i've order a new o-ring. I'm getting a rattling sound when i rev the engine from under the hood, in the area of the intake manifold, when i disconnect the electrical connect that goes to the disa, the ralltling stops and the rev is smooth, but car still misfires. I'm troubleshooting, any addition insight would be welcomed. I'm doing my spark plugs also, and i've replaced camshaft sensor recently.
Status
Not open for further replies.
You have insufficient privileges to reply here.
