LSD units - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 02-28-2017, 12:13 AM   #1
2004zhp
My Ride: 04 ZHP 330CI
LSD units
What kind of set up are people running for hpde tracks?
I have been reading a lot on lock up and preload. Seems like the sweet spot is 40% lock up. But I'm wondering what everyone is running or how they are set up.
2004zhp is offline   Reply With Quote
Old 03-03-2017, 07:18 AM   #2
pvaultguy
My Ride: 2004 330i
I plan to go with the Spec E46 diffsonline from bimmerworld
http://www.bimmerworld.com/SpecE46/B...ferential.html
pvaultguy is offline   Reply With Quote
Old 03-04-2017, 11:07 AM   #3
Feffman
My Ride: BMW M3 (Race Car)
I run a Drexler from the good folks at Autotech (http://www.autotechdriveline.com/drexler.htm) in my M3 racer.
Feff
Feffman is offline   Reply With Quote
Old 03-15-2017, 09:19 PM   #4
I8UR911
My Ride: Spec E46 (01 330Ci)
I run Diffsonline's 3 clutch variable ramp 3.46 r&p diff in my SE46. I also opted for polished r&p and bearings as well given that it's a track/race car.
Don't read too much into lock up, etc. If you have any big questions just call Dan @ Diffsonline (he builds most of the diffs sold by the big companies.... Turner, Bimmerworld, etc).
Sent from my Pixel using Tapatalk
I8UR911 is offline   Reply With Quote
Old 03-22-2017, 10:51 AM   #5
CrowsFeast
My Ride: 330CI ZHP
Could you expand on this?
Obviously almost any LSD will be a huge improvement over an open diff, but the engagement still seems like a pretty important point. Where the sweet spot is would be pretty variable depending on track types and driving styles though I would suppose.
CrowsFeast is offline   Reply With Quote
Old 03-22-2017, 01:04 PM   #6
I8UR911
I say don't worry too much about lock-up because a lot of people will over analyze differentials and likely buy something that is WAY more than what they need.
Again, the guy to chat with is Dan @ Diffsonline. He has a small "Technical Information" page on his site; http://diffsonline.com/bmw-different...formation.html.
I don't want to lead on that I'm a diff guru (far from), but I know that Dan builds some of the best diffs in the country.
Old 04-17-2017, 07:17 PM   #7
bigjae1976
bigjae1976's Avatar
My Ride: 2011 E90 M3
I ran a Metric Mechanic 3 clutch 3.15 diff. It was a great upgrade and a nice ratio for the street and track.
If you have a 6 speed...you can bolt on an M3 rear end and driveshaft. No mods. LSD included.
2013 F30 328i - Melbourne Red
2004 E46 M3 - Imola red
bigjae1976 is online now   Reply With Quote
Old 04-17-2017, 08:40 PM   #8
I8UR911
Not sure I agree with this unless you mean "bolt on" the entire M3 rear subframe.......???
E46 M3 rear diff does not simply bolt up to non-M rear subframe.
Old 04-17-2017, 11:34 PM   #9
bigjae1976
bigjae1976's Avatar
Entires rear end - subframe to brake rotors.
Old 05-24-2017, 07:28 AM   #10
BUSHHAWG
My Ride: e92M3, e46 M3, X3
Wavetrac vs M Factory
Has anyone compared Wavetrac to M Factory?? Thx.
BUSHHAWG is offline   Reply With Quote
Old 05-27-2017, 10:26 PM   #11
rkneeshaw
My Ride: 330i ZHP
I had the wavetrac out on the track today and I loved it. But, I don't think I lifted a wheel so it probably performed the same as an MFactory or other helical diff
2003 BMW 330i ZHP
ESS Twin Screw Stage 2 - Wavetrac - Headers - Borla - BMW Performance
Turner Motorsports - Powerflex - StopTech
Build thread: http://forum.e46fanatics.com/showthread.php?t=696662
Wheelwell: 2003 BMW 3 Series
Fuelly: 2003 BMW 330i
rkneeshaw is offline   Reply With Quote
Old 05-29-2017, 06:16 AM   #12
SoloII///M
My Ride: Many
No meaningful difference between a helical like MFactory and the Wavetrac unit. Pick whichever one you prefer and go with that. The MFactory helical appears very well built and is an easy install.
For lots of hard track or autocross use, go with a Blanton or Diffsonline LSD. Jim can set you up with a diff that uses larger spider gears from the M 210mm diffs which will be much more durable than anything in the MFactory clutch diffs. This is important if you start hitting curbs on track which shock loads the LSD. The MFactory clutch diffs work well but they are more fragile. They use standard sized spider gears which don't stand up well to a lot of shock loading.
For setup, it comes down to personal preference... I like a 1.5 way diff with 80-100lb-ft static preload (breakaway torque), 45 degree ramp on accel and closer to zero on decel. Some people on track like a two way diff with less pre-load and 45 degree ramps on accel and decel, this makes the car more stable when braking from high speeds, but it hurts turn-in. Either way if you get it close you can always tune it with what fluid you run.
John V
'02 330Ci - Megasquirt 3 tuned by PFTuning.com
SoloII///M is offline   Reply With Quote
Old 07-12-2017, 06:30 PM   #13
elgreengo
My Ride: e46 touring, e36m3
Syncro Design Works builds great e46 differentials!
From helical to clutch type, including Drexler race units.
http://https://m.facebook.com/SyncroDesignWorks/
elgreengo is offline   Reply With Quote
Old 07-13-2017, 12:00 AM   #14
Harry330
My Ride: 330Ci
i can't get your link to work.
One Of Many Goals.
Harry330 is offline   Reply With Quote
Old 07-19-2017, 05:41 AM   #15
BUSHHAWG
Kaaz
After a lot of research, I ended up with a Kaaz unit. My 330Ci is built with Spec e46 in mind.
I went for the competition version. I have 2 autocrosses (plus 250 street miles)and a Track Night America at CMS on it and am very pleased. It is noisy as expected but I don't have a problem with it. They have a coated version that is supposed to be quiet but I wanted the best possible performance option.
Installation was easy but I've done this before.
I don't have experience with the other manufacturers, but I can't imagine an easier or better alternative.
