///M3 Forum
Old 03-18-2017, 07:31 PM   #1
imola_e46m3
My Ride: Imola e46 m3
Window not going up
I have a E46 coupe, my window won't go up I took it apart I pushed the button to raise it and pulled the window up and the window is stuck no matter how much force it won't go up. The motor makes noise and the fuses are good. Do any of you guys have any suggestions or know what it is?
imola_e46m3 is offline   Reply With Quote
Old 03-19-2017, 12:37 AM   #2
jealeman
My Ride: 2006 BMW M3 Competit
I have replaced 3 of 4 window regulators on my son's 2002 325i. The plastic spool tends to crack over time, thus causing this issue.
Did you disconnect the window from the regulator? You may need to replace the regulator only and not the motor, although there are some kits out there that sell both as one unit.
jealeman is offline   Reply With Quote
Old 03-19-2017, 02:40 AM   #3
imola_e46m3
I can make the windows roll up if I lock it with the key and hold it, it will roll the window that Won't roll up with the switch. So it could possibly be the switch that's out?
Old 03-19-2017, 02:44 AM   #4
stahlgraue46
Window regulator for sure
stahlgraue46 is offline   Reply With Quote
Old 03-19-2017, 02:45 AM   #5
imola_e46m3
But it goes up when I use the key to lock it without a problem. Just when I use the switch is when it has problems
Old 03-19-2017, 10:12 AM   #6
stahlgraue46
Try replacing the switch, IIRC they're feather cheap to replace especially on ebay
Old 03-20-2017, 12:26 PM   #7
jealeman
You can actually switch the switches briefly. That will definitely tell you if it's an issue there, or whether the issue lies within the regulator. Hope that makes sense.
1996 Cosmos Black M3, HKS Klasse Exhaust, Dinan Cold Air Intake, Dinan Stage 2 Engine Software, Luxury and Competition Package (slat grille, not mesh). Sold 2007.
2006 Carbon Schwarz Metallic Dinan S1-M3 ZCP
Best. Car. Ever!
Old 03-20-2017, 12:28 PM   #8
imola_e46m3
The switches have different plug ins, driver side square shaped and passenger is a way larger rectangle shape
