Old 02-10-2017, 09:07 AM   #461
Pole position
My Ride: E46 330ci
Originally Posted by cwarel View Post
Yeah
Perfect, thanks
Shut up and drive
Pole position is offline   Reply With Quote
Old 02-17-2017, 11:25 AM   #462
Pole position
My Ride: E46 330ci
Yeah
What parameters should I change in the tune? I don't see anything in the ms43 wiki. Thanks
Shut up and drive
Old 02-17-2017, 11:28 AM   #463
cwarel
My Ride: 330ci coupe
Ight its the DTC supression in tuner pro,one of the categories u read what u looking for and plave a 0 in thtat scalar
cwarel is offline   Reply With Quote
Old 02-17-2017, 05:15 PM   #464
Pole position
My Ride: E46 330ci
I dont see anything mentioning the Ebrake and DSC, is it these steering wheel ones near the bottom of this pic?
Shut up and drive
Old 03-01-2017, 10:15 PM   #465
Pole position
My Ride: E46 330ci
Hmmmm
Shut up and drive
Old 03-02-2017, 10:22 AM   #466
autospeed_01
My Ride: 2000 328Ci
Widebody non-m. Love it!!!!!!!
My Build Thread
From Salvage to Custom Widebody
DTM Style Angel Eyes (flat bottom)
autospeed_01 is offline   Reply With Quote
Old 03-02-2017, 11:02 AM   #467
Pole position
My Ride: E46 330ci
Just Another M54 Turbo Build. By the People, for the People
Thanks, while the car is up as I install the widebody kit I will finally be installing the rear handbrake calipers, wide angle kit, and updating to boost by gear. Also picked up some beefy 135i calipers from the junkyard for bargain and and hoping they will fit my new wheels with csl rotors, attached via burkhart engineering adapters.
I ran the car at 19psi before I pulled it off the road and it was mental!
Shut up and drive
Old 03-02-2017, 02:59 PM   #468
PEI330Ci
58mm of Bliss
PEI330Ci's Avatar
My Ride: 330i, 330Ci
Originally Posted by Pole position View Post
Hmmmm
Where did you get this from?
I've been on the fence about going with a wide body, but haven't found anything I liked....
Old 03-02-2017, 03:05 PM   #469
Pole position
My Ride: E46 330ci
It's the DTM fiberwerks V2 fender flare kit. It doesn't fit perfectly because it's for an M3 but has been very easy to make fit with a little sanding. Using rivnuts/machine screws to attach it so they are quickly removable.
Shut up and drive
Old 03-02-2017, 04:46 PM   #470
PEI330Ci
58mm of Bliss
PEI330Ci's Avatar
Looking good on your car, but it might be too much on mine.
Old 03-02-2017, 05:14 PM   #471
Pole position
My Ride: E46 330ci
Yeah it's definitely aggressive. Had to order custom wheels to fit. 18x11 all around (max tire size for time attack is 275)
Shut up and drive
Old 03-17-2017, 11:16 AM   #472
Sindre.B
My Ride: E46 320D
Love your project man. I recently discovered that i can get a preface 330 manual in Sweden for like half of what i payed for my 320D
So suddenly a project car like yours looks very feasible over 5 years or so Definitely gonna watch your project and use it as reference of sorts
Sindre.B is offline   Reply With Quote
Old 03-17-2017, 03:38 PM   #473
CarbonZHP
Because Race...Convertible?
CarbonZHP's Avatar
My Ride: used to be an auto
Really like the hack engineering lid. High price for one piece of the oil cooler puzzle though
Modification Thread
Original Car: Silver Grey on Grey, A/T (1 of 186)
As it sits: Silver Grey on Black, M/T (1 of 51)
Instagram: @CarbonZHP
CarbonZHP is offline   Reply With Quote
Old 03-19-2017, 10:26 PM   #474
philliplong
My Ride: 2002 325CI
Are you still going to be running the MS43 when you switch to boost by gear?
Sent from my ONE A2005 using E46Fanatics mobile app
philliplong is offline   Reply With Quote
Old 03-20-2017, 12:28 AM   #475
daniel_f.
My Ride: 330iC
Probably yes, as gear-dependand boost is possible with some code hacking.
Im currently at baby vacancy!
Siemens MS42 wiki!
Siemens MS43 wiki!
Old 03-20-2017, 10:13 PM   #476
Pole position
My Ride: E46 330ci
An update. Widebody kit has been attached. I have t off now for some spray paint before I plastidip the car again. I have a professional kit for this so it comes out very well, and runs me 250 in supplies.
The hydraulic handbrake is fully functional. Can't wait to try this out! The SLR mini kit is also installed which should give me some more steering rate and angle, along with roll center and bump steer correction.
Getting corner balanced and aligned on Wednesday. Was going through the exhaust I had made and it had some serious issues with shoddy workmanship so I am fabbing up a new mid pipe myself. I am by no means an expert welder, and just have a flux core welder, but it still is looking better than before. Will likely make a 3" downpipe to replace the 2.5" this summer.
Other than that I got some junkyard 135i calipers, ecs tuning two piece csl size rotors, and adapters from Germany. I will be running ebc blue stuff, pretty good deal.
All in all, it's coming down to the wire, but the car should be pretty well prepped for its first time attack "race" on April 8th.
Shut up and drive
Old 03-23-2017, 08:32 AM   #477
cwarel
Me when I see ur car/progress
View post on imgur.com
******** async src="//s.imgur.com/min/embed.js" charset="utf-8">*********>
Cant wait to see your car once widebody kit is done, I was searching for widebody kit and couldnt find anything that looks decent
Old 03-23-2017, 02:09 PM   #478
Sindre.B
My Ride: E46 320D
I think the WTCC kit has some potenial, I'm not super crazy about the sharp angles on the wheel wells but that could be the owners execution.
http://bimmers.no/uploads/monthly_20...acf5fdac19.JPG
