My questions are, what are your thoughts on passing the inspection I'll have to do in order to register the car in Colorado. I'm thinking cats for sure but I'm not familiar at all with Colorado inspections.
Does it have cats? If not, put a set on, make sure all the readiness codes are set and you'll be fine. We don't really have inspections here, you can only fail visual if you don't have the emissions stuff there. They do an ODB2 scan for the readiness codes and run the car on a dyno for emissions. Make sure the car isn't too low, otherwise they'll refuse to run it on the dyno and send you packing.
OEM section 1 doesn't have cats in it. It's debatable whether the car will pass with the Euro cats here, they're placed so far downstream they don't light off very well.
Yep, or get one of those aftermarket section 1's that come with cats. But you'll want the 400 cell ones at least, the 100 or 200's aren't efficient enough to get past smog. Make sure they have the post cat O2 bungs as well.
The car came with the supersprint section 1 so I'm trying to find a solution that I can trade for or will be cheaper or similar to what I can get out of the SS section 1. I just bought the car so trying to keep initial costs down for the wifes sake.
Anyone in the CO area looking for a SS section 1 version 2 that bolts up to the oem header and section 2?
Related Threads
E46 Fanatics Forum
17.9M posts
592.8K members
Since 2001
A forum community dedicated to BMW E46, E90, and F30 owners and enthusiasts. Come join the discussion about M performance, turbo kits, engine swaps, builds, modifications, classifieds, troubleshooting, maintenance, and more!
