Old 04-20-2017, 07:05 PM   #1
carguy61
My Ride: 2001 330CI
Need an extra key
I just got my 2001 E46 convertible. It only came with one key. Where is the best place to get a second one?
carguy61 is offline   Reply With Quote
Old 04-20-2017, 07:11 PM   #2
jmo69
My Ride: 03 325xi 98 328is
Here, email a pic of your tittle and ID. Not cheap but less than walking into a dealer. Mine was about $150 shipped. https://thebmwminipartstore.com/part...&siteid=218365 you'll still have to sync it to your locks but that's easy.
HERSHIS
2003 325xi auto Stahlgrau almost modless, just lots of new parts. 1998 328is 5sp lowered, X-brace, Sparco strut brace, HIDs and almost everything blacked out
jmo69 is offline   Reply With Quote
Old 04-20-2017, 07:16 PM   #3
jfoj
My Ride: 330CiC, M5, X5, E93
Check you local dealer if you have one close by, if they sell you the key for $160 or less, you can go with them, otherwise the link above I think the key is around $156 last I was aware.
You will need to re-sync BOTH keys together once you get new key.
http://www.bmwgm5.com/key_recode.htm
Old 04-20-2017, 08:40 PM   #4
carguy61
My Ride: 2001 330CI
What about the ones on Ebay for $25
Old 04-20-2017, 08:41 PM   #5
BaliDawg
Keepin' it real stock
My Ride: E24 E32 E46 E39 E84
Originally Posted by carguy61 View Post
what about the ones on ebay for $25
garbage!!!
///Mmmmmm...
Old 04-20-2017, 09:21 PM   #6
jmo69
Maybe get one for the remote locking, but that's about it. You should always have 2 diamond keys, the key lock is weak.
HERSHIS
Old 04-20-2017, 10:40 PM   #7
Sinehmatic
My Ride: Shopping for an E46
Where can I find that key on the site w/o the part number, 66126955748. After entering make, model and year and searching for "key" I still don't see that specific item.
To clarify, is the link provided the remote diamond key fob? Why do some people say you have to send one key and your EWS to get it done but thebmwminipartstore doesn't?
Also, is there an online option for Canadians? The linked provider doesn't ship internationally.
Sinehmatic is offline   Reply With Quote
