Old 12-04-2013, 11:24 PM   #1
L3MONz
My Ride: 2003 325i
Lost My Only Key to My E46
I have came to the conclusion that I dropped my key on the ground and someone else picked up or I have lost it in Narnia because theres no way it's in my house. Are there any security measures I could possibly take? Maybe calling my insurance company to open my car and remove the fuses to starting the car? Also how much would it cost for BMW to make a brand new key without an original copy? I'm hoping it's the same price of a new key if I had the original.
**Edit** Meant to say without the original key.
L3MONz is offline   Reply With Quote
Old 12-04-2013, 11:27 PM   #2
HBizzo88
My Ride: 2002 bmw 330ci
My key cost me $225.
HBizzo88 is offline   Reply With Quote
Old 12-04-2013, 11:35 PM   #3
L3MONz
My Ride: 2003 325i
But you had your original key with you still, right?
Old 12-04-2013, 11:36 PM   #4
Cazz
My Ride: 2005 BMW M3
The price varies from dealer to dealer, but expect $170 to $300 for a new key.
It doesn't matter if you have the old key.
The procedures is the same:
- The dealer will submit an order to BMWNA.
- BMWNA looks up your car in their database and selects/creates the next unused key for your EWS. There are 10 total.
- The new key is shipped to the dealership.
You can program the remote yourself. Once you do this, the remote on the old key won't unlock the doors.
The dealer can lock out the old key from the EWS so it can't be used to start the car. They will probably charge an hour of labor to do this.
Even though the old key is locked out of the EWS, the old key can still be used to manually unlock the doors.
You can pull one of the big fuses from the ECU box under the hood and the car won't start until it is replaced.
Cazz is offline   Reply With Quote
Old 12-04-2013, 11:44 PM   #5
VishTheFish
My Ride: Ex M54B30 ZHP
Bad luck OP, i suggest you order a spare as well!
VishTheFish is offline   Reply With Quote
Old 12-05-2013, 12:19 AM   #6
L3MONz
My Ride: 2003 325i
Thanks man, you have no idea how much you just helped me with just this reply!
Old 12-05-2013, 01:09 AM   #7
L3MONz
My Ride: 2003 325i
Also, what fuse should I pull out? Don't wanna mess up anything important..
Old 12-05-2013, 03:58 AM   #8
cityjohn
My Ride: 2001 M3
Maybe someone found your key and put it in Santa's bucket
cityjohn is offline   Reply With Quote
Old 12-05-2013, 06:42 AM   #9
bmwguyNC
My Ride: 02 325i/06 330i e90
Send a message via AIM to bmwguyNC
You can deactivate the lost key using PASoft when you receive your new one.
bmwguyNC is offline   Reply With Quote
Old 12-05-2013, 09:02 AM   #10
moiz21
My Ride: 1999 323i 5-SPD
Send an email to this guy: pcasey@faulknerbmw.com
He is: Patrick- BMWPartsSource
A vendor for the site. He works out of PA at a dealership. He was able to get my brother a key without the remote, for $76. He is probably your best bet for a cheap key replacement. You just have to supply a copy of your driver license and registration, to prove ownership.
MODS
P46 Projectors + FX-R Retrofit + 6k D2S / 60 LED AE's / Smoked LED Tails / Smoked Turn and Side Markers / BSW 10" Sub /ZHP Knob / Matte Black Grills / DICE / Parrot + Connects2 / OEM Alternative Alarm Mod / Clutch Switch Delay Mod / M3 Rep Front Bumper / 3M Black CF Di-Noc Wrap / K&N Intake / 35% Tint All Around / Black Short Eurotray / 545i Shifter
moiz21 is offline   Reply With Quote
Old 12-06-2013, 02:15 AM   #11
Lusticles
My Ride: 325Ci
And hope that you haven't maxed out on key replacements. I think you can only have 7 replacements per vehicle? My buddy lost his E39 key and turns out the PO had already used up all the replacements. According to the dealership, anyways.
number one Audi Fan
Lusticles is offline   Reply With Quote
Old 12-06-2013, 02:31 AM   #12
VishTheFish
so what happens when you use up all the replacements? car go BOOM?
Old 12-06-2013, 02:35 AM   #13
Lusticles
My Ride: 325Ci
More logically the dealer would require you to replace the entire ignition and locking mechanisms to fit with a new key.
number one Audi Fan
Old 12-06-2013, 02:42 AM   #14
VishTheFish
That's insane?! I can't imagine what that would cost at the dealer
Old 12-06-2013, 10:57 AM   #15
aarondb4
My Ride: 2002 BMW 330CI Vert
Talk to Sean at the BMW Parts Store. I only have one key as well, decided to order a backup. About $130 shipped, just needed my VIN and registration and drivers license to verify ownership.
2002 BMW 330CI Convertible
aarondb4 is offline   Reply With Quote
Old 12-06-2013, 02:07 PM   #16
BearDeXPS
My Ride: e46 M3
dealer bend over time
'13 Ford F-150 FX4 Blk/Blk fully loaded
'05 BMW ///M3 JB/Blk fully built
Dinan | Rogue Engineering | Status Gruppe Tuning | H&R | Koni | 3M | Umnitza | Turner Motorsport | TeKarbon | Coby | aFe | Bimerworld | C&R
EVOsport | Michelin | Beisan | Dr. VANOS | Macht Schnell | Lamin-X | AKG | BSW | Eurosport Design | Mason Engineering | Vibra-Tech | evolve-R
BearDeXPS is offline   Reply With Quote
Old 12-06-2013, 04:52 PM   #17
jfoj
My Ride: 330CiC, M5, X5, E93
The EWS system can only support a total of 10 keys. Depending on what year car you had, some orignal came with 3 keys, some came with 4. I think after 10/2003 it was only 3 as they dropped the plastic Service/Wallet key then.
Once all the EWS slots are used up, you probably need to deal with someone like http://www.rpmmotorsport.net/
They look like they may have some solutions?
Old 12-07-2013, 12:16 AM   #18
NumbaOneNewb
My Ride: 2003 330CI Silver
Bah. Get yourself an ews writer like me and then you become the boss of how many keys control your car, not BMW. Technically you can have an infinite amount of keys for your car, only that 10 will start your car because of their designated slots.
Portland Metro: ECU updates, Euro tune, euro corner delete, air bag light, DSC light, cluster and any led color change, soldering work, transponders for keys, and all custom work related to computer or electronics.DIY AK90 A walk through on coding your mcu and transponders EWS3 How to make your own key (ak90 review)
Old 12-07-2013, 12:17 AM   #19
NumbaOneNewb
If you lose one, another can take his spot. And no a person who possessed a key to that same spot won't be able to start your car. Once your replacement shares with ews a new random rolling code, the one that key knew would be ancient history
Old 12-07-2013, 12:51 AM   #20
jayb328i
My Ride: E46 2000 328i
At one time I use to order dog tags and clip it onto the key with the phone number and address of a relative on it. That way no one comes to your house to start the car.
jayb328i is offline   Reply With Quote
