Old 12-07-2013, 01:03 AM   #21
cityjohn
My Ride: 2001 M3
Originally Posted by jayb328i View Post
At one time I use to order dog tags and clip it onto the key with the phone number and address of a relative on it. That way no one comes to your house to start the car.
I like that idea! I guess it's best if it's a relative you rarely visit using your car though.
cityjohn is offline   Reply With Quote
Old 12-07-2013, 01:55 AM   #22
Bishopgoldy
My Ride: '05 M3 '92 325is
Re: Lost My Only Key to My E46
Originally Posted by NumbaOneNewb View Post
If you lose one, another can take his spot. And no a person who possessed a key to that same spot won't be able to start your car. Once your replacement shares with ews a new random rolling code, the one that key knew would be ancient history
How much do you charge and what do you need? I have one key and I only need a nother to unlock my doors
Sent from my SAMSUNG-SM-N900A using BimmerApp mobile app
Bishopgoldy is offline   Reply With Quote
Old 12-08-2013, 12:31 AM   #23
NumbaOneNewb
My Ride: 2003 330CI Silver
If you need a spare solely to unlock the doors and not start it, plenty of cheap blank keys can be found online or under $15. Have a locksmith cut it emphasizing that you are not asking them to program it to start the car. You only want a physical copy made.
Portland Metro: ECU updates, Euro tune, euro corner delete, air bag light, DSC light, cluster and any led color change, soldering work, transponders for keys, and all custom work related to computer or electronics.DIY AK90 A walk through on coding your mcu and transponders EWS3 How to make your own key (ak90 review)
Old 12-08-2013, 12:38 AM   #24
Bishopgoldy
And how will it unlock my car?
Old 12-08-2013, 02:52 AM   #25
L3MONz
My Ride: 2003 325i
Welp.. I found my key.. couple hours after ordering a new diamond key fob for $190. I tried ordering a regular without the remote but for some reason they said that they aren't able to order one for my car and my only choices were either the valet key or the diamond key fob.
Quick question, what are the chances of me being able to cancel my order for the new key fob after a day ordering it?
L3MONz is offline   Reply With Quote
Old 12-08-2013, 03:03 AM   #26
Cowspoo
My Ride: 328Ci
The valet keys aren't programmed, right? They can start the car though.
spacebarissolazy
doesntfeelikebeingpressed
Cowspoo is offline   Reply With Quote
Old 12-08-2013, 03:18 AM   #27
L3MONz
My Ride: 2003 325i
Yeah they can. It just won't open the glove box or the trunk I think.
Old 12-08-2013, 03:29 AM   #28
dwtaylorpdx
My Ride: 2005 330xi
ONly one of my remote keys still work, I'd keep the new one coming .. Youll need it eventually, the remote part only activates the central locking, the EWS is powered by the rf signal so you can manually open the driver door witht eh key and start the car.. At least thats what I'm doing with my 06 330xi right now.
Dave
dwtaylorpdx is offline   Reply With Quote
Old 12-08-2013, 04:07 AM   #29
L3MONz
My Ride: 2003 325i
Thing is that I've been planning on selling my car for a while now since I need the money for my tuition and now I just spent an extra $190 for no apparent reason. Another thing that was rather strange was when they told me they couldn't order the key without the remote. I really hope I wasn't duped by them into buying the more expensive key.
Old 12-08-2013, 06:27 AM   #30
jfoj
My Ride: 330CiC, M5, X5, E93
As of build date 10/2003 there were only 2 key options vs the previous years 3 key options.
The plastic Service/Wallet key was probably not available for your car.
So the only option would be the keyfob and Valet key.
Doubt you could cancel the order for the keyfob due to the quick process they use when keys are ordered, usually if the key is ordered at the counter before 11 am Mon-Thurs and the parts guys get the order submitted in a timely manner, the dealer will have the key before 12 noon the next day.
Old 12-08-2013, 12:45 PM   #31
L3MONz
My Ride: 2003 325i
The dealership told me the plastic key IS the valet key and my only option was to either get the plastic key or the keyfob.
Old 12-29-2013, 01:55 PM   #32
E46alldayy
My Ride: 2004 bmw 330xi
If I just got a new key from the dealer why can't I use my old key to unlock/lock? how do I make both keys work??
E46alldayy is offline   Reply With Quote
Old 12-29-2013, 04:34 PM   #33
Bishopgoldy
You need to re train both keys at same time. You can find instructions online or youtube its very simple
Old 12-29-2013, 05:03 PM   #34
jfoj
Dealer is WRONG!
Plastic key is NOT the Valet key, it is considered the Spare/Wallet key.
The Valet key has a plastic head and a metal blade, the Spare/Wallet key is all plastic.
Again, you have to be careful about listening to the parts guys, they seem to get the key thing screwed up often.
You have a 2003, likely it is a later 2003 and there are only 2 key options, Keyfob and Valet key, the Spare/Wallet key was dropped somewhere mid 2003.
Old 12-29-2013, 05:37 PM   #35
E46alldayy
Thanks! I found a link online and worked like a charm. Got worried over nothing
Old 04-01-2017, 09:19 PM   #36
saifulik
My Ride: BMW318i
Originally Posted by aarondb4 View Post
Talk to Sean at the BMW Parts Store. I only have one key as well, decided to order a backup. About $130 shipped, just needed my VIN and registration and drivers license to verify ownership.
Hi, do you still have the contact details? I lost my only key just now.
saifulik is offline   Reply With Quote
Old 04-01-2017, 10:26 PM   #37
saifulik
My Ride: BMW318i
Hi, I emailed PAtrick but his email bounce back. Do you still have his/service contact details?
Cheers...
Old 04-20-2017, 11:34 PM   #38
Sinehmatic
My Ride: Shopping for an E46
Disregard this comment
"When you talk, you are only repeating what you already know. But if you listen, you may learn something new." - Dalai Lama XIV
Sinehmatic is offline   Reply With Quote
