Old 10-09-2015, 01:54 PM   #41
GoodGravy
My Ride: 2001 740IL, 325IT
Yes, that could be it! And that agrees with the attached DISA test procedure which also points to the DME.
And IF it is a DME/software bug, there could be many vehicles out there with undetected inoperative DISAs because there are no obvious symptoms (mine doesn't have any).
Do you plan to try to reprogram?
For the interim, would it make sense to lock the DISA in the closed position to give the best overall performance? (most driving is done under 4000 RPM when DISA should be closed)
GoodGravy is offline   Reply With Quote
Old 05-18-2016, 12:01 AM   #42
Mauricio H
My Ride: 525 e39
Euro 2 DME version does not active DISA at idle. My car is Euro 2
Mauricio H is offline   Reply With Quote
Old 09-23-2016, 07:13 PM   #43
Triumph777
My Ride: Z4
So where do things stand with the DISA?
Excellent thread. Lots of info but I haven't seen a conclusion. I have the same exact problem with my DISA. Did the original poster identify the issue as a faulty DME? Also, how did you identify that you have a Euro 2? Help please!!!
Triumph777 is offline   Reply With Quote
Old 04-21-2017, 02:29 AM   #44
dranzerhbk
How did u fix this issue. It seem s to be on mine too?
dranzerhbk is offline   Reply With Quote
Old 04-21-2017, 11:27 AM   #45
Synrgy
My Ride: 2000 323i, 2001 525i
I've tried three different software flashes and they all do not close the DISA at idle. I've confirmed it works through the DIS test which actuates the DISA. The DME is fully capable of opening and closing the flap, it just isn't programmed to do so at idle. Weird right!?
Synrgy is offline   Reply With Quote
Old 05-30-2017, 07:18 PM   #46
MMMM_ERT
My Ride: non-green vehicles
I'm having the same issues as some of you with the DISA valve. Car is a 2000 E46 323i. I pulled it to check because I read horror stories about the flapper valve/pin getting sucked into intakes if they have high mileage.
The flapper works great (no rattles, smooth operation), and it passes the finger vacuum test. (shown in 1st video)
It does not however "close" when I turn the key to run as shown in the 1st video.
I also bench tested as shown on the 2nd video (starting at 3:00 min). When I apply 12v, I hear a click and what sounds like release of the vacuum...but no movement of the flap.
Thoughts?
MMMM_ERT is offline   Reply With Quote
