Sponsored by The Tire Rack
Old 12-09-2015, 06:09 PM   #1
MNBMW325xi
My Ride: E21 323i E46 325xiT
Style 32 on E46 325xi Wagon
Will these fit on my wagon? They are staggered and look sick! 235/45/17 tires for the front and 255/40/17" tires for the rear.
MNBMW325xi is offline   Reply With Quote
Old 12-10-2015, 07:19 PM   #2
lamsv
My Ride: 2001 325iT
If those are a set of style 32's from an E39 (17x9 et20, 17x9 et26), they may rub. The tires are a bit aggressive for wheels that are also aggressive. You may rub depending on your suspension set-up.
I am running those same wheels on my touring. I have 225/45-17 front, 245/40-17 rear. I'm lowered on Eibach Pro-Kits, -1.5 degrees camber front and back, rolled fenders, and I do not rub. The wheels sit almost perfectly flush to my fenders.
lamsv: 2001 HELLROT on BLACK 325iT
lamsv is offline   Reply With Quote
Old 12-10-2015, 09:54 PM   #3
MNBMW325xi
I don't think I could do that. My skill level is entry level. Thank you so much for taking the time to respond to my question.
Old 03-22-2017, 05:24 PM   #4
St00pidfast
My Ride: 2002 E46 325xiT
lamsv could you help me out? I just purchased a 02 325xiT and I have been trying to find the style 32 wheels. What size style 32 wheel will bolt on to the car? Since its an X Im pretty sure you have to run a square setup. I have been researching and Im assuming its the 17x7.5. 17x8.5?
St00pidfast is offline   Reply With Quote
