Old 04-18-2017, 08:23 AM   #541
Depraved
My Ride: ZHP Sedan 6mt Imola/
I would just skip on the girdle, the initial issue with our motors and boost that I've read thus far is the head lifting so I'd say the focus should be on proper fasteners; until you're shooting for obscene numbers I would bet you have a lot of headroom with all the hardware you're adding.
Sent from my SCH-I545 using Tapatalk
Depraved is offline   Reply With Quote
Old 04-18-2017, 01:29 PM   #542
Pole position
My Ride: E46 330ci
Perfect, sounds good. Full set of studs on way from CTS.
Shut up and drive
Pole position is offline   Reply With Quote
Old 04-18-2017, 01:42 PM   #543
cosmos328Ci
My Ride: 398.5whp. 498.8ftlb
Use the ARP for your girdle.
M54B30, ESS TS2, Schrick Cams, S54 Cam Chain Tensioner, ATI Super Damper 6.8", 3.5" Throttle Body, XForce Headers, Custom Twin Exhaust, Quaife LSD 2.93:1, UUC Twin Plate and Lightened Flywheel, GSR Four-bolt Oil Pump, M56 Engine cover with Built-in CCV.
http://forum.e46fanatics.com/showthr...619&highlight=
cosmos328Ci is online now   Reply With Quote
Old 04-18-2017, 01:59 PM   #544
Pole position
My Ride: E46 330ci
On the fence really, don't ARP not make a stud for the M54 since they had issues with aluminum?
Just scored an ATI damper for the M54 on eBay for 350!
Shut up and drive
Old 04-18-2017, 02:01 PM   #545
Depraved
That's exactly the issue, I haven't seen anyone use ARP on M54 or aluminum m52 with success.
Old 04-18-2017, 02:14 PM   #546
cosmos328Ci
The problem is with mating the aluminium head, aluminium block and the way the head and block behave with heat and boost.
Nice pick up on the ATI damper.
Old 04-19-2017, 07:49 PM   #547
cosmos328Ci
Hey, Pole position,
Do you have a part number for the cut ring head gasket and what size did you go.
Cheers.
Old 04-19-2017, 08:50 PM   #548
Pole position
My Ride: E46 330ci
Originally Posted by cosmos328Ci View Post
Hey, Pole position,
Cheers.
Here's where I ordered mine : http://server.pure-pf.com/webshop2/e...50mm-bore.html
Shut up and drive
Old 04-19-2017, 10:24 PM   #549
cosmos328Ci
Thanks Pole position.
Ahh, I looked at the one with out the rings included.
http://server.pure-pf.com/webshop2/e...rings-m54.html
Cheers
Old 04-26-2017, 08:50 AM   #550
Pole position
My Ride: E46 330ci
Been grinding here, motor should be out of the machine shop next week with the bottom end assembled. Plan to get it in within 2.5weeks with the new boost lab turbo. Anybody know where to rent a good set of cam timing tool?
Installed a much lighter odyssey battery and altered the stock bracket with some angled aluminum and rivets, and shortened the steel stay with a a quick cut and weld.
Was going to a "dyno day" event to see where I was, just for the clutch to start slipping on the way to the event. I was at 18psi. Just got worse and worse. It's an ecs lightweight flywheel and m5 clutch setup. I ordered a cheap ceramic 6 puck friction disk to try out. People don't like to sell just the nice discs, only in full kits....
Also have been pulling the headliner to install a fiberglass sunroof delete panel from DTM fiberwerkz. Going for lap time now! Wrapping the pillars in black suede, turning out very well so far, and the headliner in a space themed fabric. Pics to come of that.
I wired up a relay to power the fuel pumps directly from the battery as well. So far it's working great, and the bimmerworld anti-starvation kit seems to be doing it's job. Much better than the stock siphon.
Also have dual oil coolers going into the front bumper ducts, and reusing my current oil cooler after I reposition it, as a power steering cooler (was boiling at the track).
Basically melted the ebc blue pads at the track last time, don't use them! Hoping to change to something better in time for the next round.
Big updates, I am traveling this week, but hopefully will get a few things wrapped up and a video made when I get back of the current progress
Shut up and drive
Old 04-26-2017, 09:13 AM   #551
cwarel
My Ride: 330ci coupe
Ive got psi stage 3 6 puck clutch , and apparently its garbage im on 4 psi and it aint grabbing sh*t ( unless ive got no traction with 3.46 diff and 235 tires in the back ,but i dont heer the squeeling tho)
cwarel is offline   Reply With Quote
Old 04-26-2017, 09:25 AM   #552
Pole position
My Ride: E46 330ci
Link? Is that with the stock pressure plate or M5?
I didn't have too many issues with the stock M5 setup, but I'm sure glad they showed up before I pull everything apart anyway.
Shut up and drive
Old 04-27-2017, 01:02 AM   #553
nick325i_
My Ride: 2001 e46
You have an instagram? I have a boosted b25 e46!
nick325i_ is offline   Reply With Quote
Old 04-27-2017, 01:02 AM   #554
nick325i_
My Ride: 2001 e46
If so follow me @thatboosted46thoo
Old 04-27-2017, 05:38 AM   #555
Pole position
My Ride: E46 330ci
Yeah, it's birdbrain155 and seemslegitgarage for anybody that wants to check it out
Shut up and drive
Old 05-07-2017, 07:09 PM   #556
Pole position
My Ride: E46 330ci
Just Another M54 Turbo Build. By the People, for the People
Motor on the way out and interior all finished
Shut up and drive
Old 05-07-2017, 07:32 PM   #557
xi46
My Ride: 2002 330xi ZPP/SP/CW
I'm usually not a fan of headliner fabric that doesn't look stock, but that space headliner is awesome!
xi46 is offline   Reply With Quote
Old 05-07-2017, 07:33 PM   #558
avantgarde
My Ride: 2001/2005 325xi A/M
so THAT'S what you meant by "Galaxy headliner" in your youtube video... got it
avantgarde is offline   Reply With Quote
Old 05-10-2017, 10:43 AM   #559
Pole position
My Ride: E46 330ci
Thanks!
Motor should be back from the shop next week. Went with King tri-metal Bearings all around. Everything looked good so standard sizing cleared well.
Shut up and drive
Old 05-10-2017, 12:36 PM   #560
cwarel
Are you gonna do m56 valve cover? since you got that downpipe close by crappy plastic valve cover))
