Old 02-11-2017, 09:05 PM   #1
zackmillerlite
My Ride: 2004 BMW E46 325i Wa
Need Key/Fob Help!
Hey everybody, I've been reading on here for a long time but posting for the first time.
For a long time I wanted an E46, and just purchased one today.
I got A 2004 325I wagon in alpine white with 130xxx miles. I was able to check the car out and it is really clean and running great. Originally purchased at Spreen BMW Newport California dealership.
I got it at auction for a very good price.
The only things that are wrong with the car,
Is that they took the driver door key cylinder out, and the fob battery is Dead. So I cannot lock the car, as I won't be able to get back in.
I'm trying to figure out what my options are, without paying an arm and a leg at the dealership. Does anybody have any ideas or experience with something like this? I'd appreciate any help that I could get.
zackmillerlite is offline   Reply With Quote
Old 02-11-2017, 09:25 PM   #2
jfoj
My Ride: 330CiC, M5, X5, E93
You should be able to purchase a replacement drivers door lock cylinder than will work with the original key for around $70 from the dealer or an online dealer as I recall.
For a new keyfob, you can check locally, but they are probably too expensive.
For around $156 you can have a new keyfob on your doorstep in about 3 days from thebmwpartstore.com. I think you can email Sean and provide proof of ownership.
You should also read up on the GM5 relay problems, you really should get the GM5 relays replaced in the module, this may be a good part of what the problem is/was with your car.
www.bmwgm5.com
I would also spend the $30-$35 now and replace the center console door lock switch NOW.
I would probably also buy 1 or 2 of these and just use the keyfob portion to remotely lock/unlock the door.
http://www.ebay.com/itm/315MHz-Keyle...9U3yVV&vxp=mtr
I would not try to get this key working with the car, it is not cost or time effective. You could cheat and even just cut the keyblade off and use the fob, just as a fob from the old days before there were integrated keyfobs. This is how my 2005 GMC truck is, I have a separate fob and key.
Old 02-11-2017, 09:27 PM   #3
Overboost
Binary is in my DNA
Overboost's Avatar
My Ride: 2002 325i
One of our members (Scottjoh) is a genius on the GM5 electronics. He should see your post and give you the correct procedure moving forward. Here is a link to his door lock cylinder replacement. The guy knows his ****, listen to him and follow his directions. Welcome to the family and let us know how it goes.
https://www.bmwgm5.com/bmwgm5/lock_cylinder.htm
The older I get... The faster I was...
No Fear
Overboost is offline   Reply With Quote
Old 02-11-2017, 09:27 PM   #4
jmo69
My Ride: 03 325xi 98 328is
Proof of ownership emailed here with the VIN https://thebmwminipartstore.com/part...&siteid=218365= new key, can't speak for the missing lock cylinder. Scot can replace your key battery for you too.
HERSHIS
2003 325xi auto Stahlgrau almost modless, just lots of new parts. 1998 328is 5sp lowered, X-brace, Sparco strut brace, HIDs and almost everything blacked out
jmo69 is offline   Reply With Quote
Old 02-12-2017, 10:59 AM   #5
zackmillerlite
Thanks guys. I feel better having an idea where to start.
So, what I don't understand,
I see some new fobs that are almost 200 dollars and some that are 15 dollars. What is the huge gap in expense?
Could I have a blank $15 fob cut to my ignition and program it to my car?
I see videos on YouTube of people who put the key in the ignition turned to the on position and then hold the lock and BMW button on the fob and it seems to immediately work for locking and unlocking the car?
Old 02-12-2017, 11:03 AM   #6
zackmillerlite
And as far as the door cylinder goes, they're only $30 to get a replacement with two keys online. And super easy to replace. I am absolutely a DIYer.
You're not really supposed to use the doorlock much anyway, so after I get A couple new fobs with keys for the ignition I won't have to use the door.
So I'll just throw the new key that comes with the door cylinder on the key ring in case of an emergency.
Old 02-12-2017, 11:11 AM   #7
zackmillerlite
www.bmwgm5.com
Awesome suggestions with the center console switch. I've had those go out on several of my cars in the past. I'll get one.
Do you know if A PA soft scanners check the GM5 modules relays?
Old 02-12-2017, 11:28 AM   #8
jfoj
No codes or warnings about GM5 relays going out, it is not IF but WHEN and I would just assume PM the GM5 relays buy year 10 if you do not have problems before then.
If the auto locking is enabled, the GM5 lifespan is shorter due to the added number of relay cycles.
Old 02-12-2017, 11:41 AM   #9
Overboost
Binary is in my DNA
Overboost's Avatar
My Ride: 2002 325i
Good point. I have never even thought about that. I have been hovering over the auto lock function for a while now and it just became less important.
No Fear
Old 02-12-2017, 12:07 PM   #10
jfoj
I have a friend that is the original owner of a 2001 325xi Touring and she had the auto locking enabled and I had to replace the GM5 relays in her car around year 9, which was back in 2010, might be time to replace the relays again in a few years!!
How time flies, in Sept it will be 7 years since I replaced the original relays at this point!!
Old 02-12-2017, 12:50 PM   #11
scottjoh
Modded ///Member
My Ride: '99 323i & '02 540i
Need Key/Fob Help!
Yes. The general module has several codes for the relays. You can use INPA, PASoft or any other software that can read the general module to read them. These faults are not always caused by the relays even though it says relay in the fault description. It can be cause by failure of the relay driver transistor or a broken circuit board trace.
Auto locking isn't that bad. The two things that are hardest on the relays is double locking and double unlocking (using the remote or key in the door) on all door simultaneously. Both are worse on a 4-door. Certain contacts must handle the current from 9 motors (2 motors per door plus fuel flap). Auto locking and unlocking from an auto locking doesn't activate the double lock motors so the load is only 4 motors max for all doors on a 4-dr or only 1-2 motors on a 2-dr coupe/convertible. I wouldn't worry about Auto Locking.
scottjoh is offline   Reply With Quote
Old 02-12-2017, 12:57 PM   #12
jfoj
While there may be relay related codes, will they always indicate bad relay contacts?? I could see relay codes for an open relay coil, but question if there are really codes that would be accurate for the relay contacts having too much Voltage drop. If there are codes for relay driver transistors, then I doubt those codes can determine there is too much Voltage drop within the relay contact unless the system actually compares the command to Lock or Unlock the door latch and then the door latch has a feedback to indicate what state the locks are in. Giving the intermittent nature of the relay behavior there may or may not be codes as well. I have seen a low battery aggravate door unlocking when the relays are going bad.
I find that most monitoring is for the controller side, not the output side of devices.
In any event, I recommend PMing the GM5 relays at around year 10 based on what I have been seeing. Why wait until you have your back against the wall or cannot get into your car?? The relays never fail on your schedule!
Old 04-21-2017, 12:30 AM   #13
Sinehmatic
My Ride: Shopping for an E46
Canadian alternative online for a new key fob?
"When you talk, you are only repeating what you already know. But if you listen, you may learn something new." - Dalai Lama XIV
Sinehmatic is offline   Reply With Quote
