2003 330ci Bad Rpm's Drop in D and R - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 03-31-2017, 12:02 AM   #1
willysalazar1
My Ride: 2003 330ci
Hello I just finished cleaning MAF , ICV , TB and check for vacuum leaks and my car still shakes a lot when I shift from P to D or R .
At this point I don't know how to diagnose , I have no codes
New Disa , CCV, Coils, here's a video of the problem
Thanks any advice will be appreciated
https://www.dropbox.com/s/kbbj8pz5vz...29.33.mov?dl=0
willysalazar1 is online now   Reply With Quote
Old 03-31-2017, 04:48 AM   #2
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
Engine mounts.
I did EVERYTHING to fix that vibrations (spark plugs/boots, intake boots, disa, vacuum hoses, etc etc etc). Its the engine mounts. When they get worn out they will create the vibration when the gear is engaged to the transmission. If you can do the transmission mounts at the same time then that would be idea. Stick with the Lemforder/Corteco brand.
Old 03-31-2017, 05:59 AM   #3
jfoj
My Ride: 330CiC, M5, X5, E93
Most of these cars idle at 700 RPM in Park or Neutral and 600 in Drive.
Your RPM's seem a big higher than that.
Did you have the problem before you worked on the ICV & TB?
Old 03-31-2017, 08:55 PM   #4
willysalazar1
My Ride: 2003 330ci
I have this problem for over 4 months now . I cleaned everything thinking It will get better
Enviado desde mi iPhone utilizando E46Fanatics
Old 03-31-2017, 08:57 PM   #5
willysalazar1
My Ride: 2003 330ci
Originally Posted by Solidjake View Post
Engine mounts.
Thanks jake . I don't know how old the engine mounts are . It's there any way to test they bad ? I am on a thigh budget right know new baby coming in a few months
Old 04-01-2017, 04:46 AM   #6
jfoj
Did you check your power brake booster for leaks?
http://forum.e46fanatics.com/showthread.php?t=1057387
Sucking Jet Pump Links
http://forum.e46fanatics.com/showthread.php?t=1061188
http://forum.e46fanatics.com/showthread.php?t=523763
http://www.bimmerfest.com/forums/sho...d.php?t=578766
Old 04-01-2017, 05:52 AM   #7
ReIntegration
My Ride: 2003 BMW 330Ci
Send a message via AIM to ReIntegration
I can tell you when my 330Ci was brand new, It shifted in "R" and "D" a lot smoother and the RPM didn't drop to the point the car felt like it was gonna stall but now 14 years later @ 90k miles my car's idle drops to about 600 and shakes like it's gonna stall when I put it into gear but it never does. I even did a trans drain and fill and also replaced the rear diff fluid and it still does it. My car drives fine and shifts as it always did. Although Jake makes a good point. I too never checked my engine mounts and that makes sense.
']['|R(G
Wernher Von Braun
2001 330Ci (My uncle was the original owner then given to me as a secondary to my 03)(Sold)(Kept younger brother)
2003 330Ci (Current & original owner - Born on 1.10.03)(Had it since new born. Delivered from Regensburg on 2.24.03)
Originally Posted by Mordecai
Ready to get destroyed?
ReIntegration is offline   Reply With Quote
Old 04-01-2017, 12:49 PM   #8
willysalazar1
My Ride: 2003 330ci
Thanks for your replay Reintegration, I just order mounts , I am not 100% sure will fix the problem but they are ready too be change at 96k miles I will report after . Also will read jfof brake booster leaks my breaks aren't very good so maybe is another problem
Old 04-01-2017, 01:40 PM   #9
jfoj
Confirm your typical elevation, seems you should be around 1700 feet above sea level? This may be a factor to consider when comparing behaviors.
I am like 300 feet above see level.
Old 04-01-2017, 01:43 PM   #10
willysalazar1
My Ride: 2003 330ci
Good afternoon jfof I am at 540 meters 1770 ft above sea level
Old 04-20-2017, 11:26 PM   #11
willysalazar1
My Ride: 2003 330ci
Hi . Can some look at my Diagnostic Report car runs good but still vibrates when idle
https://www.dropbox.com/s/4n9ww8eqmx...4-20.html?dl=0
Old 04-20-2017, 11:37 PM   #12
willysalazar1
My Ride: 2003 330ci
Log report
https://www.dropbox.com/s/hkdul64ksd...20827.csv?dl=0
Old 04-21-2017, 07:45 AM   #13
jfoj
1770 Feet is pretty high for my point of reference. I assume the MAF reading may be lower as you increase in altitude, there is clearly less Oxygen and I believe the Mass decreases, but I have no if the engine actually uses more air at idle?
Anyway the Fuel Trims look pretty good.
I would like to see an Log only at idle and a Diagnostic Report while at idle.
What is a bit troubling is the P0741 - Torque Converter Clutch Circuit Performance or Stuck Off
While this code is for a Torque Converter Clutch Performance or Stuck Off, I am now wondering if some of your problem is a problem with the Torque Converter or circuit??
I see the title of the thread as Bad RPM's drop in D and R. What is the engine idle in gear consistently? Most automatic E46's tend to idle right at 700 in gear. Does your engine idle at 700 RPM? Is the idle rough?
Old 04-21-2017, 12:51 PM   #14
willysalazar1
My Ride: 2003 330ci
Thanks jfoj here's the idle logs and reports
https://www.dropbox.com/s/ij6jvj4tdt...4-21.html?dl=0
https://www.dropbox.com/s/2eqvgyf7b5...23525.csv?dl=0
Code P0741 shows up every week or so I just clear it and keep driving . My rpm idle around 710 and 730 rpm's .
Hope these report tell a bigger picture
Old 04-21-2017, 01:19 PM   #15
jdstrickland
My Ride: '94 325iC & '00 323i
Personally, I think you are throwing good money after bad. You need somebody that knows a thing or two to look at your car. You are like the Polish mine sweeper, you cover your ears with your hands so the noise doesn't hurt, then stomp along the side of the road banging your feet on the ground looking for mines. This is a bad way to fix a car. It's difficult to read how violent or mild the shaking is. You need somebody onsite to help you understand what you are facing.
Normal idle in P or N should be about 700 to 750 rpm. When you shift into R or D, the idle should fall by about 100. Motor mounts should not cause a vibration, although at a certain harmonic they could play a role. A harmonic is a speed that is a multiple or derivative of another speed.
Old 04-21-2017, 01:25 PM   #16
jdstrickland
P07nn is a transmission code. Your vibrations in R or D can easily be from transmission related causes. You can't just clear the codes and keep going. Well, that's not entirely true. You can clear codes and keep going to see if they or a subset of them come back, then set about to make the repairs. Your car is screaming at you that the transmission is not happy, and you are asking about a vibration that happens at idle when the transmission is not in P or N. You are FEELING an unhappy transmission and the car is confirming an unhappy transmission.
https://www.obd-codes.com/p0741
Old 04-21-2017, 01:26 PM   #17
jdstrickland
Your idle speed is good at 710 to 730 rpm. It might even be a bit on the high side, but it's not alarming or reason to buy a new set of wrenches.
Old 04-21-2017, 01:34 PM   #18
willysalazar1
My Ride: 2003 330ci
Thanks for the reply jd I know I have a unhappy transmission the thing is here in Mexico there's is no good shop to fix it I've been all over my town without luck . Dealers will charge me what my car is worth . Transmission oil and filter will be done by me this weekend I will report back about the code coming back . Regarding my shaking I change my plugs just now and is gone . After testing with a voltmeter 3 of them were 0 ohms . Car runs better now
