Old 04-20-2017, 09:26 PM   #21
YoitsTmac
My Ride: 328Ci
If one additional person wants a video I will
YoitsTmac is offline   Reply With Quote
Old 04-20-2017, 10:37 PM   #22
AndreBXP
My Ride: 2001 BMW 330ci
Originally Posted by Spannerhead View Post
How can you rev match a car when the engine and driveline are never disconnected? Rev matching by definition is manually synchronizing the engine and input shaft speed before clutch re-engagement.
I always revmatch the downshifts in my Auto E53 X5. It's much quicker to shift and smoother for the occupants+driveline.
AndreBXP is offline   Reply With Quote
Old 04-20-2017, 10:48 PM   #23
WDE46
My Ride: '13 128i, '04 330Ci
Your "rev matching" on the auto is most certainly not smoother for occupants. Modern autos are practically imperceptible.
I have a dream that one day our children will live in a
nation where they will not be judged by the color of
their skin but by the color of their coolant.
Old 04-20-2017, 10:51 PM   #24
evanr614
My Ride: used 2 have 2 pedals
Yes i'm very confused by this.
Atlantis Blue 328Ci Project Thread
http://forum.e46fanatics.com/showthr...523&highlight=
evanr614 is offline   Reply With Quote
Old 04-20-2017, 11:41 PM   #25
Jason325xi
My Ride: 2004 325xi 5speed
Ok fine! I want to see this too lol
Adjustable koni yellow front struts, Rob43 9-way adjustable rear shocks, Special Rob43 lowering springs, supreme power drop hats, billet aluminum rear shock mounts, poly RTAB, G.A.S. Disa kit, G.A.S. 1.2bar expansion tank cap
I run 6010 overhead in a t-shirt!
Jason325xi is offline   Reply With Quote
Old 04-21-2017, 12:11 AM   #26
hodgkinsc330ci
My Ride: 2002 BMW 330Ci
I know exactly what Tyler is talking about and I do it in my auto as well... it takes a lot of finesse to get the timing perfect so you get a smooth throttle blip. Not worth it to do most of the time unless I'm in a performance driving setting, and if you mess it up it just feels jerky like applying sharp throttle inputs in a lower gear at high speed.
And yes, I know that it's not actually "rev-matching" but it does help smoothen out and sometimes quicken the shifts. The whole process for rev-matching is much more intuitive in a true manual gearbox, albeit I'm not all that great at it either.
2002 BMW 330Ci 5AT
Originally Posted by lingon300k View Post
[BMW Motors] Advertising has somehow convinced people that they're different. That they're made by magical Dachshunds who only eat special bratwursts made by virgins in an undisclosed magical spot inside of the black forest that can only be accessed via a special hydrogen powered BMW helicopter.
hodgkinsc330ci is offline   Reply With Quote
Old 04-21-2017, 12:16 AM   #27
TobyB
My Ride: 2004xit, 2001ci
Hmmm, in for video of double- clutching... a car without a clutch!
hee
t
TobyB is offline   Reply With Quote
Old 04-21-2017, 12:23 AM   #28
hodgkinsc330ci
hee
t
Rev-matching and double clutching are technically two different practices.
2002 BMW 330Ci 5AT
Old 04-21-2017, 01:17 AM   #29
AndreBXP
Obviously it's not the same as rev matching in a manual transmission car.
Many steptronic automatics will jerk the car forward if you manually downshift in steptronic mode. It's similar to the type of jerk you get if you downshift a manual without rev matching. If you give a little bit of gas during the shift the Auto will do the manual downshift smoother and sometimes quicker (aka rev matching). At first getting the timing right is tricky, but I do it every time I drive an Auto in manual mode. It is definitely smoother. (Note: This only applies to automatics with manual mode while manually downshifting and doing it in drive is probably pointless.)
Maybe the new BMW's do the rev match for you but I know for sure the ZF in my X5 doesn't and many other automatics don't do it.
Just my 2. YMMV.
Old 04-21-2017, 02:04 AM   #30
YoitsTmac
My Ride: 328Ci
I will do a video...maybe tomorrow. I don't have any classes or appointments
Old 04-21-2017, 05:40 PM   #31
Mysticblau03
My Ride: 03 325 sedan
Originally Posted by JJR4884 View Post
you do have a manual transmission right
Yes
Mysticblau03 is offline   Reply With Quote
Old 04-21-2017, 05:45 PM   #32
Mysticblau03
Sorry for the wait guys. My catch can finally came in today even tho my maf has been here for a few thanks to one of the guys on the site so I havnt been able to throw it back together untill just now. The new maf did indeed fix the problem. i can heel toe again. Sounds a lot healthier now too and throttle response is back. So far so good.
Old 04-21-2017, 07:37 PM   #33
hodgkinsc330ci
Good to hear! Sorry for our massive thread-jack...
In other words, I made a quick video today on the downshifts. Not perfect, and I bet Tyler will do a much better job if he uploads something. Making this video really reminds me that I need to do a full transmission fluid change.
2002 BMW 330Ci 5AT
Old 04-21-2017, 10:26 PM   #34
Mysticblau03
yea I'm glad it worked out. have only heard of the no heel toe thing a couple of times with no real solution posted with it. Also had done all the small stuff ( upper and lower Intake boots, valve cover gasket, oil cap, metal ecs f fitting, disa valve o ring and inspected, cleaned icv and tb and now the ecs catch can to do away with all the ccv issues) leading up to replacing the maf too with no change in the heel toe situation.
Old 04-23-2017, 10:14 PM   #35
Sm0k3s91
My Ride: 325CI
Send a message via AIM to Sm0k3s91
Im curious in this cant do sit down burn outs ever since my MAF-less intake swap n tune
IG= @Mr_Rowden
*sig removed, too large*
Sm0k3s91 is offline   Reply With Quote
Old 04-23-2017, 10:50 PM   #36
tks
My Ride: slower than yours
its awkward to heel toe, i toe heel
WTB:: Natural Brown Sedan Full Interior
tks is online now   Reply With Quote
Old 04-24-2017, 07:14 AM   #37
WDE46
What's the purpose of a tune like that?
