Thread Tools Search this Thread Rating: Thread Rating: 2 votes, 3.00 average. Display Modes
Old 06-24-2013, 11:15 AM   #1
mdlax30
My Ride: 04 M3 Vert
Control Unit self-test, torque manager monitoring Code help!
So the M is throwing a 1b-C3 or Control Unit self-test, torque manager monitoring. Any idea whats causing this?
I replaced the plugs and Coilpacks last weekend and still pulling it today.
no CEL or dashlights on
04 M3 Vert- Titan Silver
mdlax30 is offline   Reply With Quote
Old 07-05-2013, 07:45 PM   #2
03BIMMERM3
My Ride: 2003 BMW M3
Re: Control Unit self-test, torque manager monitoring Code help!
I pulled this code twice so far in the past couple weeks, my symptoms are while driving, my EML, BRAKE, DSC come on and then the car goes into limp mode, this code pops up, no SES light..was this happening to you?
Sent from my myTouch_4G_Slide using BimmerApp mobile app
03BIMMERM3 is offline   Reply With Quote
Old 07-05-2013, 07:51 PM   #3
mdlax30
My Ride: 04 M3 Vert
Exact same scenario. I'm going to try and replace the front tps tomorrow.
Old 07-05-2013, 08:15 PM   #4
03BIMMERM3
I spoke to my indy shop and he told me its most likely my dsc unit on the way out, gonna bring it in on wed so they can get more info on the code...I've read everywhere else about speed sensors..curious, how frquently has it been happening?
Old 07-05-2013, 08:21 PM   #5
mdlax30
My Ride: 04 M3 Vert
Let me know how it goes. My car does it once every week usually.
Old 09-27-2013, 02:48 AM   #6
paschen
My Ride: '01 330ci
Hey did you sort out this issue? Just had the same issue
cheers
paschen is offline   Reply With Quote
Old 03-08-2014, 04:48 PM   #7
m3-4aj
My Ride: E46 M3 / F80-M3
Send a message via AIM to m3-4aj
thread revive - this happen to my car today. what needs to be done? thanks guys
m3-4aj is offline   Reply With Quote
Old 03-29-2014, 04:59 PM   #8
m3-4aj
Help with this guys- car did the same thing after replacing maf for other codes I was getting
Old 07-07-2016, 03:04 PM   #9
E.Hands
My Ride: 01 M Coupe S54 Turbo
I just started getting this code too. It always happens while in deceleration, EML and goes into limp mode. On restart the EML goes out and the throttle comes back to life.
Has anyone figured out what is the cause?
<a href=http://s1218.photobucket.com/user/EHands/media/Mobile%20Uploads/IMG_8155_zpswckacmzm.jpeg.html target=_blank><img src=http://i1218.photobucket.com/albums/dd403/EHands/Mobile%20Uploads/IMG_8155_zpswckacmzm.jpeg border=0 alt= /></a>
E.Hands is offline   Reply With Quote
Old 02-21-2017, 07:10 PM   #10
dpdcmn
My Ride: 2004 M3
I have the same code and issue. Did you figure out what caused it?
dpdcmn is offline   Reply With Quote
Old 02-21-2017, 08:42 PM   #11
E.Hands
No, I'm stumped. I replaced both of the TPS and still going into limp mode.
Old 02-21-2017, 09:37 PM   #12
mdlax30
My Ride: 04 M3 Vert
So its been a few years since I threw it. Never quite figured it out. I had it scanned on a V1.4 Scanner and on an Autologic @ TTFS and couldn't find a fix (even reset all adaptations on the engine). However, I narrowed it down to what seemed to trigger mine.
It usually came on and went into Limp mode when I was driving at a low RPM (below 3k), going in the neighborhood of 25-35 MPH but in a high gear (typically around 4th-5th gear) and then I pressed on the gas, around 1/2 WOT or more. Example: I am coasting in 4th, around 30 mph, to reduce speed before a stop in the distance, but suddenly I have to increase my speed (unexpected lane change etc). I don't down shift to increase my RPMs, but instead press on the gas. As I press on the gas, it would trigger Limp mode and I wouldn't be able to go above 25 mph in any gear. Luckily with mine, all I would need to do is stop, turn the car off, sit for maybe a minute, and then turn it back on and it would be back to normal.
Sorry I couldn't ever figure it out. It never progressed to anything worse than this so it was challenging identifying the problem without replacing a crap ton of parts.
Old 04-20-2017, 10:42 PM   #13
Iceberg157
My Ride: E46 M3
Send a message via AIM to Iceberg157
BUMP, getting the same code. Has anyone figuring it out?
My Ride: E46 M3
Iceberg157 is offline   Reply With Quote
Old 04-20-2017, 11:19 PM   #14
E.Hands
For me it was a torque value that was exceeding a stock threshold. Once the threshold was tweeked by my tuner the fault no longer occurs.
