Saw your other post in Xi forum...believe all fuel pumps are in the gas tank...and though I haven't done it myself yet...hear it's about 20 mins to do...listen for fuel pump priming...humming...as was said...under rear pass seat...lift up rear seat...see two rubber covers...might be opened...might not be...cut rubber if necessary...replace pump...if you can get one today.
Because of the sub amp...if not wired properly...if he's running it while car not running...looking more like bat...have him run cluster test.
turned key on could not here pump so i toke fuel pump out, new one dont fit dam napa even oem bosh part , turns out when i hookup to a battery it still works, thanks napa, next ? fuel fuse was good but im wondering now if relay is shot but i could not locate it where is it!
Related Threads
E46 Fanatics Forum
17.9M posts
592.5K members
Since 2001
A forum community dedicated to BMW E46, E90, and F30 owners and enthusiasts. Come join the discussion about M performance, turbo kits, engine swaps, builds, modifications, classifieds, troubleshooting, maintenance, and more!
