Here are some pictures of our upcoming CFR line of S54 supercharger systems. This is a protoype kit, final versions of the kit might vary slightly.
The lineup will consist of :
CFR-550 (stock engine internals) 470RWHP @ 7PSI
CFR-700 (ESS FI cams, 9000RPM valve springs, lowered compression forged pistons -9.5:1 CR, engine bearing kit) 600RWHP @ 13PSI
Both kits use the same basic hardware and the 550HP kit is fully upgradeable to the 700HP version.
All power numbers are rated on 93 octane pump fuel.
