Old 01-16-2017, 12:34 PM   #1
El Gato Liso
My Ride: BMW NOTHING.
E46 330i Supercharged looking for more boost in stock engine...water meth inquiryThe
Hey all!
My e46 is charged with a 6psi pulley. I was thinking of grabbing a smaller pulley to aim for roughly 9-psi.
My engine is currently stock and non intercooled. I was thinking of adding a water meth kit to allow safe operation of the higher boost, without intercooling or engine modification.
My question is...how does water/meth kit work along side tuning? I know some may be boost operated...
I'm really trying to wrap my head around the tuning aspect with water/meth. So far all I can think is once X boost is reached, water/meth then comes on and sprays away while boost increases...and ecu is tuned to do its thing with the higher boost, as per normal.
What if the water/meth runs out? Can the ecu be tuned to cut out at X rpm to prevent boost from increasing?
Thanks for any help folks!
-Rob
El Gato Liso is offline   Reply With Quote
Old 01-18-2017, 01:21 PM   #2
03_330Ci
My Ride: 03 330ci5 94 840i6mt
Hi Rob
are you running the ESS kit or a centri charger? i would also look at e85 if its available in your area. PEI330ci is probablt going to comment before to long and share an epic kernel of wisdom as adam usually does.
-Rob
RRT- Epic - Dinan- ESS - Technik - Stoptech - TMS- Arc-8
to many parts to list, i'm overdue for a build thread..
03_330Ci is offline   Reply With Quote
Old 01-18-2017, 02:09 PM   #3
El Gato Liso
I have a vortec kit from VF engineering. I'd consider e85 but looking for more practical daily driving type of power
