Old 01-29-2017, 12:17 AM   #1
325imsport
My Ride: 2003 BMW 325i
E46 Full custom build
Hi all
I'm assuming this would be the appropriate section for my post considering I will be doing this entire build myself. I need some assistance from you guys though.
I have a 2003 BMW 325i with the 2.5l M54 in it. Starting soon I plan to do a full 2.5l to 3.0l stroker (need to know what I will need for this). Also I am building a fully custom big turbo kit for my car which will be all custom and all hand made piping and work. I am trying to find out if I will need to run a stand-alone ECU and if so what will work for me. I want to push 600HP or at least very very close to it. I don't care how long it takes me, it will get done. I have the funds and I have the time. Also I am trying to find out what injectors and fuel pump I would need to run for e85 and if there is anything else you guys can throw out there to help me achieve my goal of 600HP on ethanol with a big precision turbo. I have already done brake upgrades, suspension work, and started some other mods to prepare for this build. All advice will help me.
Thank you guys very much.
325imsport is offline   Reply With Quote
Old 01-29-2017, 10:10 AM   #2
cwarel
My Ride: 330ci coupe
There is a guy running on Stock engine 22pse of boost making 700whp , on E85 , I think he suses 1000cc injectors and stock ecu but for the ecu part im not sure
cwarel is offline   Reply With Quote
Old 01-31-2017, 01:16 PM   #3
03_330Ci
My Ride: 03 330ci5 94 840i6mt
pretty sure you are talking about hobbit. having a 3.0 push out 600 is right up at the limit of what the stock rods will take before they break. you might want to consider 400 hp as a more realistic target and size the turbo accordingly. with the open diff in that car you will have severe traction problems with 400 whp and one wheel peel
RRT- Epic - Dinan- ESS - Technik - Stoptech - TMS- Arc-8
to many parts to list, i'm overdue for a build thread..
03_330Ci is offline   Reply With Quote
