Old 03-12-2017, 09:00 PM   #1
Gunner_e46
My Ride: 2001 e46 325xi
Car starting problems
I drive a 2001 325xi and my car had no problems and was running fine when I parked it. I came back a few hours later and the car would not start just turned over until the battery was dead. So I pushed it in my shop and put a battery charger on it. In the morning it fired up fine no problems so I went a filled it with gas and parked it back in front of my shop again. After it sat for a few hours I came back out and tried starting it and all it did was turn over. So I thought maybe my fuel pump was going bad so I put the key in and turned it to the #2 position for a few second and tried starting it and it fired right up. I figured I probably shouldn't drive it so I left it parked tried starting it today and it fired up right away then a few hours later I tried and all it would do was turn over even if I put the key to position 2 for a few second any thoughts on what it could be I'm thinking maybe fuel pump or filter but am not sure please help!!
Sent from my SM-G900R7 using E46Fanatics mobile app
Gunner_e46 is offline   Reply With Quote
Old 03-15-2017, 04:32 AM   #2
powerstroke
My Ride: 330i G-string
Sounds complex,is engine able to crank at all times?
Sent from my GT-S7392 using E46Fanatics mobile app
powerstroke is offline   Reply With Quote
Old 03-15-2017, 04:34 AM   #3
powerstroke
Am tryin to figure out,mabe starter motor or ignition switch,from yo explanation..
Old 03-19-2017, 03:48 PM   #4
Gunner_e46
Yes engine cranks over no mater what I'm thinking maybe my fuel pump or fuel filter might be the case
Old 03-19-2017, 04:19 PM   #5
BaliDawg
Keepin' it real stock
My Ride: E24 E32 E46 E39 E84
Sounds like the classic fuel pump failure. They often intermittently fail up until total failure. If you don't know when it was last changed just replace it, or you'll be stranded soon. They're easy to replace. I'd get the OE Siemens/VDO brand from fcpeuro.com and pick up a clamp or two if needed.
///Mmmmmm...
Old 03-20-2017, 04:35 AM   #6
powerstroke
Sure,if it cranks then try replacing the fuel pump,get original bosch vdo pump.
Old 03-20-2017, 05:11 AM   #7
jfoj
My Ride: 330CiC, M5, X5, E93
Read this: Fuel pump failures - http://forum.e46fanatics.com/showthread.php?t=929501
Old 03-20-2017, 10:16 AM   #8
Jason325xi
My Ride: 2004 325xi 5speed
Originally Posted by powerstroke View Post
Sure,if it cranks then try replacing the fuel pump,get original siemens vdo pump.
Fixed
Adjustable koni yellow front struts, Rob43 9-way adjustable rear shocks, Special Rob43 lowering springs, supreme power drop hats, billet aluminum rear shock mounts, poly RTAB, G.A.S. Disa kit, G.A.S. 1.2bar expansion tank cap
I run 6010 overhead in a t-shirt!
Jason325xi is online now   Reply With Quote
Old 03-21-2017, 01:02 AM   #9
powerstroke
