Should I even attempt to replace this oil pan? - Page 2 - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 03-19-2017, 06:25 PM   #21
michaelnoblega
My Ride: 2001 Bmw 325i
I agree - to an extent. All engines operate on the principle of "x" amount of oil pressure being present to lubricate the main & rod bearings. All I'm saying is that these engines tend to survive oil starvation better than most.
michaelnoblega is offline   Reply With Quote
Old 03-19-2017, 06:45 PM   #22
turbo8
My Ride: 2002 325i
Yes, I had a 944 turbo that had a problem going around left turns(maybe right turns, I don't remember). If it was a high enough G turn, it would starve the engine of oil and the #2 crankshaft bearing would get destroyed. Happened to me, expensive fix. Fun car though.
turbo8 is offline   Reply With Quote
Old 03-19-2017, 06:58 PM   #23
WDE46
My Ride: '13 128i, '04 330Ci
I don't know where you're getting that impression from. Any engine will get damaged almost instantly without oil pressure. It's just how the bearings work. As soon as metal contacts metal, it's never going to be the same. An engine run without oil pressure for anything but a miniscule amount of time (seconds and then shutting it off completely) isn't worth trying to investigate and salvage.
This guy's N55 survived about 10 minutes before seizing. Damage is immediate and starts getting worse and worse.
http://www.1addicts.com/forums/showthread.php?t=1359507
I have a dream that one day our children will live in a
nation where they will not be judged by the color of
their skin but by the color of their coolant.
Old 03-19-2017, 06:59 PM   #24
WDE46
That's a design flaw in the 944's oil system, not a sign that the M54 is robust to oil loss.
Old 03-20-2017, 11:49 AM   #25
goodmanr
My Ride: 01 325i Sprt&PremPkg
It's probably cheaper to replace the oil pan then to buy another car.
goodmanr is offline   Reply With Quote
Old 03-20-2017, 12:19 PM   #26
Dave1027
My Ride: '06 IR zhp coupe
Of course it would be but the OP's point is the engine is likely toast plus all the other damaged suspension parts.
Old 03-20-2017, 12:37 PM   #27
goodmanr
Actually, the OP never mentioned anything about the suspension. The question was "should I replace the oil pan?" But since he already bought her another E46 I guess it doesn't matter anymore. In fact, now I'm not sure why he even asked the question in the first place.
Old 03-25-2017, 10:00 PM   #28
turbo8
My Ride: 2002 325i
Well, I went ahead and replaced the oil pan. The motor is knocking pretty bad, which I sorta assumed was going to happen.
I'm going to remove the following:
valve cover and engine covers
dip stick tube
headlights'
headlight level sensors
sport seats
battery
bc stalk
steering wheel
possibly the motor mounts (new) and oil pan
rear wheels and tires (tires only have a couple thousand miles on them)
radiator (most of the following have a few thousand miles on them)
electric fan
coolant hoses
water pump
thermostat
expansion tank
Should I bother with the following:
transmission
fuel tank
Old 03-31-2017, 09:37 PM   #29
2003silver330i
My Ride: 03 BMW 330i
Alright, picked up an 04 X3 3.0 for her.
Who wants parts from the 325i? Valve cover and dipstick tube can go to Knight if you want them.
I guess I should start a part out thread in the classifieds.
I'll take your newly installed oil pan if you are up to removing it again. I will even come pick it up from you.
The 2 happiest days of a BMW owner's life is the day they buy it and the day they sell it.
BMW (Broke My Wallet)
2003silver330i is offline   Reply With Quote
Old 03-31-2017, 11:44 PM   #30
Jason325xi
My Ride: 2004 325xi 5speed
Wait...so both girlfriends drove over something and busted the oil pan, and your both in las vegas?
You gotta admit that's a funny lol
Adjustable koni yellow front struts, Rob43 9-way adjustable rear shocks, Special Rob43 lowering springs, supreme power drop hats, billet aluminum rear shock mounts, poly RTAB, G.A.S. Disa kit, G.A.S. 1.2bar expansion tank cap
I run 6010 overhead in a t-shirt!
Jason325xi is offline   Reply With Quote
Old 03-31-2017, 11:53 PM   #31
dck8267
My Ride: 2003 325ci M56
What color is the interior?
Sent from my SAMSUNG-SM-G930A using E46Fanatics mobile app
dck8267 is offline   Reply With Quote
Old 04-01-2017, 01:53 PM   #32
2003silver330i
Wife did. I bet it probably even happened on the same road.
Old 04-01-2017, 08:18 PM   #33
turbo8
My Ride: 2002 325i
Black
Started part out thread here: http://forum.e46fanatics.com/showthr...347&highlight=
Old 04-03-2017, 04:43 AM   #34
dck8267
Dang, if it were tan I would jump on the sport seats, my 325ci has everything sport but the seats lol
