Thread Tools Search this Thread Rating: Thread Rating: 19 votes, 4.89 average.
Old 03-07-2017, 01:18 PM   #1001
Davew
My Ride: 2004 330ci Msport
Where did you get the Cut Ring from? PPF?
It is an Athena Coopering/cut ring head gasket. A friend ordered it for me with his parts order, but they are available through PPF, VAC, Achilles, FCP or most Athena gasket stockists.
Davew is offline   Reply With Quote
Old 03-10-2017, 06:34 AM   #1002
jdjg
My Ride: e39, m52tub30
updates??
are you already cut you hair?
jdjg is offline   Reply With Quote
Old 03-12-2017, 03:45 AM   #1003
Davew
Originally Posted by jdjg View Post
updates??
No hair cutting lol, he backed out of the bet as soon as he made it
Not much progress in the last 3 weeks, have been back on it this weekend though. Now that it isn't a daily, work has to take priority
Have bought a nice piece of 250 x 650 x 80mm aluminium to redo the sump I have predrilled the sump to block holes, should hopefully get it on the mill or borer this week
Getting the engine mount done today. With RHD the engine mount and steering column form a bit of a problem area, so I have relocated the mount to be inline with the column, probably not a bad cheat for other RHD owners looking at turbo
Also made an exhaust vanos delete, would still like to go bigger on cams eventually, but will get it going as is for now.
ID:	651500   Click image for larger version
ID:	651501   Click image for larger version
ID:	651502   Click image for larger version
Old 03-12-2017, 04:58 AM   #1004
cosmos328Ci
My Ride: 398.5whp. 498.8ftlb
LOL.
Nice lump of alloy.
cosmos328Ci is offline   Reply With Quote
Old 03-12-2017, 05:20 AM   #1005
Davew
Originally Posted by cosmos328Ci View Post
LOL.
Nice lump of alloy.
35.5 kg of aluminium, most of that will end in the scrap bin lol. The joys of going so custom . It would actually be cheaper to buy a sump, but the mains girdle and longer studs mean that the dry sumps that are produced won't fit
Old 03-13-2017, 04:54 AM   #1006
PEI330Ci
58mm of Bliss
PEI330Ci's Avatar
My Ride: 330i, 330Ci
I'm confused on the exhaust VANOS delete. What will hold the spline on the camshaft?
Also, I've found that UUC engine mount to be really frail. I just pulled mine out last night, and it's deformed after only a couple of thousand kms of driving. The closer to the engine you place the mount, the more force that will be applied, and it will "wear" out quicker.
PEI330Ci is online now   Reply With Quote
Old 03-13-2017, 05:34 AM   #1007
Davew
The spline is no longer used. If you look at the picture with the vanos parts disassembled, you will also see the bolts are now shoulder bolts at the camshaft end. The new machined piece has holes instead of slots, this stops the movement, and I have added a spacer to replace the spring to compress and tighten the parts back to the camshaft. I have been considering removing the helix and adding a bolt and washer to further secure it. Exhaust timing was set by position of the holes, exhaust/ intake cam can still be adjusted using the vanos tool. It took a lot of set up and measuring, but I have confirmed exhaust timing via dial indicator at tdc. I avoided using the helix as I have had it slip once in the past when I installed the Schrick cams.
I have been considering changing the engine mounts, I have had the UUC ones for a while now, they have seemed to have "softened" with time. Must do some research on what is available and recommended now Although the engine mount will be working harder, replacing it more frequently will easily offset the pain not doing this mod would cause. It will be accessible to replace. The mount plus steering column just form a blockage, bringing them inline has just opened a heap of room that I could really take advantage of. I have had thoughts of using a dampener at the top of the engine to body to offset the position of the mount possibly, but will check a new set as preventative maintenance and see how reliable that side is first.
ID:	651558   Click image for larger version
Old 03-13-2017, 05:48 AM   #1008
Davew
I probably haven't explained the locked vanos well again. The replacement "disc" has 6 tight holes instead of 6 slots. The 3 larger holes position the disc to the camshaft via the shoulder screws, and then also positions the cam to crank sprocket via the threaded holes in that sprocket once the screws are threaded in. Unfortunately I have limited photos of the actual install.
Old 03-13-2017, 08:11 PM   #1009
bimmerteknik
My Ride: 2003 E46 ZHP
330ci ess ts2+
Checkout Black Forest industries they just released engine mounts for e46. They look to be well engineered and not just a piece of poly with a bolt through it.
http://store.blackforestindustries.c...bmwe3m3en.html
bimmerteknik is offline   Reply With Quote
Old 03-13-2017, 09:22 PM   #1010
jdjg
link please
Old 03-21-2017, 02:21 AM   #1011
Davew
My block of aluminium is slowly starting to resemble a sump
ID:	652063   Click image for larger version
ID:	652064   Click image for larger version
Old 03-21-2017, 07:52 AM   #1012
GuidoK
My Ride: Z4 3.0i ESS TS2+
They look a bit like vibra technics engine mounts.
But maybe even better shielded from heat.
E85 Z4 3.0i | ESS TS2+ | Quaife ATB LSD | Custom Brembo BBK front/rear | Schrick cams | Schmiedmann headers/cats | Powerflex/strongflex PU bushings | Vibra-technics engine mounts | H&R anti rollbars | KW V3 coilovers | Sachs performance clutch
GuidoK is offline   Reply With Quote
Rate This Thread
