Old 05-24-2014, 06:16 AM   #81
Davew
My Ride: 2004 330ci Msport
It seems the people working on LS engines and VW racing engines are all over increasing overlap and the advantages with a supercharged engine with sequential / multipoint injection (though not turbo).
Apart from the benefits of clearing the combustion chamber, there is also believed to be a benefit as far as valve/combustion chamber/piston cooling, etc.
Issue is that exhaust readings show lean, so they are normally tuned without the exhaust sensor. There is further info that I wont go into, but a quick Google search will put you on the right track.
I am not trying to be controversial with this, I simply have a mate who has a car that seemingly runs perfect with no defects, no pinging, no detonation, etc, but put it on a dyno with the exhaust sensor, and it shows lean as hell. I have an inquisitive mind and wanted to get to the bottom of why this was so.
In my search for info, there has been a lot of posts where people have dynoed there cars with less aggressive cams and also had borderline lean AF readings, and told with no explanation that this is normal by the tuner, and that their engine is going to blow up by everyone else.
I have read other posts again where people are struggling to tune for newer, larger FI cams, and again they are struggling. I suspect these also have increased overlap, and tuning to a certain AF ratio via exhaust just isnt going to work.
The ESS TS2+ tune does seem to cater well for the 272 intake cam, but it is horrifying to see the exhaust measured AF reading.
I will get back on original topic now
Davew is offline   Reply With Quote
Old 05-24-2014, 06:21 AM   #82
Davew
Originally Posted by jdjg View Post
yes, Im the one who bought the TS2+ few months ago and came in my SC kit the 85mm from the TS2 and the 83mm in the TS2+ update
jdjg, which motor are you running, I wonder if the differencre in pulley size is simply that your running the M52tub, and not the M54???
Old 05-24-2014, 06:49 AM   #83
jdjg
My Ride: e39, m52tub30
Im running the m54b30
jdjg is offline   Reply With Quote
Old 10-13-2015, 10:24 PM   #84
rkneeshaw
My Ride: 330i ZHP
Anyone have an 83mm pulley they want to get rid of?
2003 BMW 330i ZHP
ESS Twin Screw Stage 2 - Wavetrac - Headers - Magnaflow - BMW Performance
Turner Motorsports - Powerflex - StopTech
Build thread: http://forum.e46fanatics.com/showthread.php?t=696662
Wheelwell: 2003 BMW 3 Series
Fuelly: 2003 BMW 330i
rkneeshaw is offline   Reply With Quote
Old 10-13-2015, 10:28 PM   #85
Davew
I have a spare 78, 70, and 60mm
Old 10-20-2015, 10:02 PM   #86
rkneeshaw
My Ride: 330i ZHP
Now that would quite the upgrade I don't have cams or other engine work so I need to stick to 83mm if I can find one...
2003 BMW 330i ZHP
Old 10-20-2015, 10:33 PM   #87
jdjg
what pulley you have?
why dont you made your own pulley??
I made my two pulley 79 and 75 mm, cost me US $ 45.00 each one
Old 10-21-2015, 12:22 AM   #88
Davconelectric
My Ride: 2 dog powered sled
I was running a stock engine with 78mm pulley. It was fine
Davconelectric is offline   Reply With Quote
Old 10-21-2015, 04:49 AM   #89
cosmos328Ci
My Ride: 398.5whp. 498.8ftlb
I run a stock engine with a 60mm pulley, no problems so far.
cosmos328Ci is offline   Reply With Quote
Old 10-21-2015, 06:47 PM   #90
rkneeshaw
My Ride: 330i ZHP
Don't you guys have cams and custom tunes to run those pulleys?
I've got a MS45.1 DME, so there's a limit to how much boost I can run before there are software issues of some kind, so I hear.
I've got the 85mm pulley that comes with the latest TS2 kits. I have abundant access to 93AKI so I'd like to run the 83mm pulley. AJ says I can run this without any update to my tune.
Eventually I'm thinking FI cams and a 81mm pulley will be in my future, but I've got to let the check book heal a bit from all of this year's mods
I wish I knew how to make my own, but I don't know anything about creating something out of metal... just thought if someone upgraded to a TS2+ kit and had a spare 83mm pulley laying around then maybe we could strike a deal or something...
2003 BMW 330i ZHP
Old 10-21-2015, 09:57 PM   #91
jdjg
why you think you will meed cams to put a smaller pulley?
I have right now 79mm pulley (use my 83mm and converted to a 79mm) with stock TS2+ tune (also I have SC cams) and no problems, also in my country (Panama City, CENTRAL AMERICA) I only
can get 93RON (the tune from ESS are for 98RON)
when I put the 75mm, I use two bottles of
torco and no problem, and definitely felt the difference......
Old 10-21-2015, 10:03 PM   #92
rkneeshaw
My Ride: 330i ZHP
I'm sure I would need an updated tune at a minimum.
Regardless, I don't know how to make my own pullies...
2003 BMW 330i ZHP
Old 10-21-2015, 10:16 PM   #93
Rob43
Rob43's Avatar
My Ride: 03 331Ci 5spd R1200R
Guys, can't someone cough up a source on where smaller pulleys for the TS2 can be bought new or a source on who can custom make them ?
If all fails, I know of a U.S. based Race / Supercharger shop that can build almost anything on their 5 Axis CNC machines, any size pulleys would be No Problem as long as you sent them your current pulley as a reference. You'd need to call them to find out pricing.
Rob43
SUMMIT POINT WV 1:24:229 SCCA
Old 10-21-2015, 11:03 PM   #94
jdjg
ESS TS Pulley Upgrades
Rob43
I, 75mm and TS2+ tune
Old 10-21-2015, 11:08 PM   #95
Rob43
Rob43's Avatar
The question is,......Where did you buy your smaller ESS 75mm pulley ??
Who is your ESS Pulley source ???
Rob43
Old 10-22-2015, 12:37 AM   #96
cosmos328Ci
Rob43
I bought my 60mm Pulley from ESS.
Old 10-22-2015, 12:41 AM   #97
cosmos328Ci
Yes, if you decreased your pulley size significantly you would want to re-tune.
If you take your current pulley to a CNC Machine Shop, they would be able to replicate a pulley for you smaller or bigger.
Call a few machine shops to see if they would do it for you.
All the best rkneeshaw.
Old 10-22-2015, 01:26 AM   #98
Davew
I manufactured all my "custom" sized pulleys myself on a manual lathe, and also davcons 78mm. Any machine shop could either make, or turn down the original (cheaper option).
I did send data logs to Asbjorn of ESS when running the 78mm pulley with my stock (apart from stage 3 head, and 3 inch exhaust) TS2+ setup, and the tune had adapted fine, but was advised at that time not to go further on the ESS supplied 30lb injectors.
Old 10-22-2015, 01:38 AM   #99
Davew
The TS2+ cams do have a little more overlap, the vanos isn't adjusted between the TS2 or TS2+ files, I don't think I would personally go as low as 78 with stock cams, but I would PERSONALLY try an 80mm and see how it logs on stock TS2
Old 10-22-2015, 01:45 AM   #100
Davew
Two on the go, such a shame I had to start with this :
