Old 01-26-2015, 03:43 AM   #1
beky330Ci
My Ride: e46 330Ci
ASA TM12 SC installation
Hey guys, im currently in the middle of installation of the ASA Supercharger (first generation G-Power kit) onto my M54B30 and I would be very thankful for any help - specificaly the best help/information would be the original manual or scheme of the SC kit, since i purchased it second hand. I just need to sort out where few hoses goes and im all set.
This is my first post btw. so greetings from Prague-Czech Republic everybody! My e46 is a original ACS edition with few mods - shorter final gear, Smiedmann headers, Bastuck full exhaust, HR springs and Kaaz LSD.
beky330Ci is offline   Reply With Quote
Old 01-26-2015, 04:25 PM   #2
Alex323Ci
My Ride: M3 & 323Ci (sold)
send me a PM with your email and i can send you the .pdf i have from both ASA and Technik on this for a 330. most likely someone on here has better info on it and mine are just some saved documents on my computer from years ago.
Old 01-26-2015, 04:54 PM   #3
03_330Ci
My Ride: 03 330ci5 94 840i6mt
i have a ASA-tm12 2012 install instructions manual as well as the ASA SKI M54 install PDF, im pretty sure those are what alex has but if i can email them out to you to. Pm me and ill forward them off.
RRT- Epic - Dinan- ESS - Technik - Stoptech - TMS- Arc-8
to many parts to list, i'm overdue for a build thread..
03_330Ci is offline   Reply With Quote
Old 03-15-2015, 06:14 PM   #4
beky330Ci
My Ride: e46 330Ci
Unhappy
So thanks to some of you who provided for me very valuable installation manual i managed to put everything together. Took some time because I was waiting for some parts since the 2nd hand kit i bought missed some. But unfortunately i got different problem now... The car is not running at full power. At around 3k rpm the engine starts to choke ... even at idle after about 1min of running ... When driving slowly the e46 acts normal ... The DIS shows only missfire on one cylinder (different each time) otherwise no other fault codes. Fuel filter is from M3 and the pressure on fuel rail is 4,2BAR at idle. The ASA potentiometer is installed on the MAF and has minimal impact on the run of the engine ... The engine functioned without any problems before installing SC.
Thank you in advance for any suggestions/help guys!
Old 03-20-2015, 08:01 PM   #5
jdjg
My Ride: e39, m52tub30
and what about the DME tune?
jdjg is offline   Reply With Quote
Old 03-21-2015, 02:23 PM   #6
03_330Ci
beky what are you using for a tune? do you have the ASA ECU? or are you still running a N/A tune with a S/C?
Old 03-16-2016, 01:14 AM   #7
smgbimmer
My Ride: E46 MSport
Hi new here. I have bought the car with this installed. I have idle problems too and sometimes it dies during heavy traffic. If i may ask aslo for the install manual? Thanks.
smgbimmer is offline   Reply With Quote
Old 03-16-2016, 10:23 AM   #8
Titan 3
Titan 3's Avatar
My Ride: E46 325ci, F36 428ix
I have a set I can send you. Shoot me over your address and I'll email them over. What you are dealing with is more than likely failing hoses and/or connections than install concerns. I'd trace the plumbing and look for vacuum or boost leaks.
Titan 3 is offline   Reply With Quote
Old 03-16-2016, 10:50 AM   #9
CarbonZHP
Because Race...Convertible?
CarbonZHP's Avatar
My Ride: used to be an auto
Sounds like OP is not running a tune
Modification Thread
Original Car: Silver Grey on Grey, A/T (1 of 186)
As it sits: Silver Grey on Black, M/T (1 of 51)
Instagram: @CarbonZHP
CarbonZHP is offline   Reply With Quote
Old 03-17-2016, 07:54 PM   #10
smgbimmer
My Ride: E46 MSport
Hi titan 3 thankyou for the reply. You got pm. Yes i will start working on the intake and replace first the hoses.
Old 03-21-2016, 12:53 AM   #11
smgbimmer
My Ride: E46 MSport
Update. I have the car idles fine after i have replaced the intake hoses with silicone ones. Theres an instruction from asa that goes like this " adjust lambda of the exhaust with the crank to 0.8 to 0.88 at full throttle between 3000 to 6500" its a small box supplied and the input signal was taken fr maf output then goes to ecu. How can i do this procedure. I have inpa and odbii
Old 04-26-2016, 06:43 PM   #12
Danis
My Ride: e60
installation manual
hi, can you e-mail this manual to me ?
Danis is offline   Reply With Quote
Old 05-27-2016, 03:36 AM   #13
smgbimmer
My Ride: E46 MSport
Pm me your email
Old 07-25-2016, 02:21 PM   #14
Broder
My Ride: E36 M3 & E46 325i
Hello guys
Can anyone send me pdf file please?
Also does anyone know what are those parts?
1. Some metal disc with vacuum and coolant? lines
2. aluminium triangle/spacer? where does it have to be installed?
3. aluminium lid
4. electronic potentiometer, any wiring diagrams?
thanks in advanced
_nr_
Broder is offline   Reply With Quote
Old 01-04-2017, 03:22 AM   #15
leonardo_
My Ride: 323CI Cabrio, X1 18d
Help?
leonardo_ is offline   Reply With Quote
Old 02-07-2017, 01:43 AM   #16
smgbimmer
My Ride: E46 MSport
Originally Posted by Broder View Post
Hello guys
3. aluminium lid
thanks in advanced
_nr_
It's a pressure regulator.to be connected on fuel filter return side. That vacuum hose is just for venting purposes. I bypassed this regulator in my setup. And use higher fuel rate injectors instead.
The lower pic is astronic as they call it. Its inline potentiometer to increase or decrease MAF readings. To make system rich or lean.But still ecu will correct itself due to O2 sensor readings..
