Old 04-16-2016, 02:41 AM   #1
mrbobmicjoe
My Ride: 2001 325i
Share your Oil Catch Can Setup
Hey guys,
I know that a lot of E46 owners (especially those with FI) have been switching over to catch can systems in place of the junk CCV system. Im curious to see what setups people are running.
I have a closed loop system at the moment with a check valve, hooked up to a $15 ebay special catch can. My question is, does anyone have any experience with systems that vent to atmosphere?
Share your setup below
mrbobmicjoe is offline   Reply With Quote
Old 04-16-2016, 02:46 AM   #2
daniel_f.
My Ride: 330iC
Originally Posted by mrbobmicjoe View Post
Hey guys,
Venting into ambient will give fault maf readings and therefore problems with engine smoothness, most probably stalling issues and lambda regulator difficulties
Im currently at baby vacancy!
Siemens MS42 wiki!
Siemens MS43 wiki!
Old 04-16-2016, 02:51 AM   #3
mrbobmicjoe
My Ride: 2001 325i
God himself has spoken!
I was curious about a system like this because im looking to get rid of the ugly distribution piece that the ccv hooks up to (part #5 on the diagram). Since the catch can setup outputs mostly clean air back into the intake, could i plug up the 6 return ports on the intake manifold, and run a single line from the can back into the intake manifold?
Name:	Screen Shot 2016-04-16 at 12.52.47 AM.png
Old 04-16-2016, 04:29 AM   #4
daniel_f.
My Ride: 330iC
Probably the best way is M56 valve cover to get rid off of all this emissions stuff.
I met a friend a few days ago and hes using a catch can forever with venting back into intake, his frickin oil refill cap is as new! Not a single bit of carbon build
up
Siemens MS42 wiki!
Siemens MS43 wiki!
Old 02-12-2017, 08:36 AM   #5
eemil
My Ride: Z3 Coupe
How would you solve this? MAF before turbo and recirculating blow off valve?
What kind of catch can do you recommend? Where do i need a check valve?
eemil is offline   Reply With Quote
Old 02-13-2017, 11:12 AM   #6
cwarel
My Ride: 330ci coupe
Well i got catch can installed , i completely removed ccv , the valve cover bung i placed a hose going to oil catch can and on the other side i ran to that distribution thing ( also it has a 1 way valve with flow restriction)
So far I check on it and I had margarine and I was amazed how much it was in such a short term ( oil catch can was full of it ). So what happened I think is that since its cold outside , water condensates inside of the oil catch can , and when oil vapors come through they are accumulate with water . Since you are driving everything rattles and shakes , so that caused water and oil to mix and produce margarine which is disgusting. So honestly I think Oil catch can in cold climate is a no no, unless you willing to check on it every so often like me.
Ill post pictures of mine in a little bit
cwarel is offline   Reply With Quote
Old 02-16-2017, 05:56 AM   #7
eemil
My Ride: Z3 Coupe
Some pictures would be nice! Also what kind of valve did you use?
Old 02-16-2017, 03:26 PM   #8
Pole position
My Ride: E46 330ci
I just run mine out the valve cover to a vented can. When I had it all checked valve up to work under vacuum it kept getting clogged. No issues with it this way so far.
Shut up and drive
Pole position is offline   Reply With Quote
Old 02-17-2017, 07:22 AM   #9
eemil
My Ride: Z3 Coupe
I think i will run the same setup, any negative about it? How is the idle?
Old 02-17-2017, 12:24 PM   #10
Pole position
My Ride: E46 330ci
It's not a vacuum leak so it's unaffected
Shut up and drive
Old 02-17-2017, 01:29 PM   #11
eemil
My Ride: Z3 Coupe
Thanks!
Old 02-19-2017, 08:26 AM   #12
SoloII///M
My Ride: Many
I'm running the Moroso catch can that is made for (I believe) the E36. Works perfectly on my E46.
The catch can is plumbed inline with the crankcase vent in the valve cover and the vacuum source at the back of the (M50) manifold plenum. Could easily do the same thing with the M54 manifold. I usually capture a couple ounces of oil after a race weekend. The catch can has a valve at the bottom for easy draining.
JV
John V
'02 330Ci - Megasquirt 3 tuned by PFTuning.com
SoloII///M is offline   Reply With Quote
Old 02-19-2017, 08:29 AM   #13
rkneeshaw
My Ride: 330i ZHP
Old:
New:
(actually the catch can is removed, I installed the M56 valve cover that has a built-in air/oil seperator)
2003 BMW 330i ZHP
ESS Twin Screw Stage 2 - Wavetrac - Headers - Magnaflow - BMW Performance
Turner Motorsports - Powerflex - StopTech
Build thread: http://forum.e46fanatics.com/showthread.php?t=696662
Wheelwell: 2003 BMW 3 Series
Fuelly: 2003 BMW 330i
rkneeshaw is offline   Reply With Quote
