The Showroom
Old 11-30-2016, 11:18 PM   #21
CMendez
My Ride: 08 E90 M3, 04 ZHP
And with an overnighted part and a few hours of work, Heidi is happy again.
https://goo.gl/photos/qMV1n5ivL8Sb94E29
Now back to the ZHP project. Parts shipment expected Friday and Monday.
2008 E90 M3- Heavily Modded
2009 E70 X5M (Wife's Car)- Mostly Stock
2004 E46 330CI ZHP- Project Car. Bringing it back from the dead...
Previously Owned-
2004 E46 330CI ZHP
2005 E46 M3 Competition Package
2009 E70 X5 Diesel
2006 E90 330
CMendez is offline   Reply With Quote
Old 12-02-2016, 09:35 PM   #22
CMendez
First box of goodies arrived. Excited to put these on... Similar to my M's grilles which the German flag instead of M colors.
https://goo.gl/photos/Sz4ygzxoXC5wLKyy7
Previously Owned-
2004 E46 330CI ZHP
2009 E70 X5 Diesel
2006 E90 330
Old 12-03-2016, 04:01 AM   #23
sillieidiot
My Ride: '06 AW 330ci
Can you host the pictures elsewhere? it sucks to click them because none of them show up here. All I see is the grey minus sign logo lol
Old 12-03-2016, 11:36 PM   #24
CMendez
Sorry, show up fine on mine. Not sure why... migrated images to photobucket. Should be fixed now.
Previously Owned-
2004 E46 330CI ZHP
2009 E70 X5 Diesel
2006 E90 330
Old 12-04-2016, 12:27 AM   #25
Mflara20
My Ride: 04 330i
Great looking car.
I would highly suggest going to UUC motorwerks lightweight flywheel with a performance organic clutch. I have that combo and I love it!
Be sure to remove your cdv valve and get a braided steel clutch line. Also if you live in a hot climate follow their fluid recommendation because it would sound like a diesel.
Sent from my SM-G930P using Tapatalk
Mflara20 is offline   Reply With Quote
Old 12-04-2016, 08:04 AM   #26
CMendez
^Thanks for the recommendations, I have a stainless clutch line on the way and already have fluids ready to go. Going to run a redline D4/MTL mix due to the age of the transmission.
Previously Owned-
2004 E46 330CI ZHP
2009 E70 X5 Diesel
2006 E90 330
Old 12-04-2016, 07:13 PM   #27
CMendez
Small update, rest of parts are being delivered tomorrow, but I went ahead and installed the painted grilles from ECS.
Before- Stock chrome grillles
After- ECS Matte Black w/German flag colors
Previously Owned-
2004 E46 330CI ZHP
2009 E70 X5 Diesel
2006 E90 330
Old 12-05-2016, 10:26 AM   #28
05SMG
My Ride: 2005 330ci ZSP
Looks cool. My 330 is dark and I didn't think that grill would work on a dark base but it does!
Is the ZHP Black or a steel grey? It looks different from the driveway shot.
05SMG is online now   Reply With Quote
Old 12-05-2016, 11:56 AM   #29
zander271
My Ride: 6spd ZHP/5sp XI
How is the quality of the ECS grills? The khoalty ones are not so great, the tabs break off as you are trying to install them.
ZHP Mods: JB Lightweight fly wheel (10.5 pounds), Koni FSD ProKit, Supreme Power Drop Hats, Hotchkis front(30.2mm)/rear(25.4mm) sway bars, Sprint Booster, AFE Stage 1 Intake, Morimoto EvoX-R Headlights, Orion V4 Angel Eyes, Satin Black 18x9 ET42 APEX ARC-8 Wheel
330xi Mods:Front Koni Yellow Struts and Rob43 Rear 9 Way adjustable Rear Dampers,Custom Sport Springs,Supreme Power Drop Hats,ZHP 5 speed shift knob
Old 12-05-2016, 04:20 PM   #30
CMendez
The car is Sapphire black metallic, looks slightly grey under fluorescent lighting. The ECS quality is really good. I've never been unsatisfied with their products.
Previously Owned-
2004 E46 330CI ZHP
2009 E70 X5 Diesel
2006 E90 330
Old 12-07-2016, 10:46 PM   #31
CMendez
Parts delayed, so decided to tackle the last interior project for now. Here's the center console the car came with. Not my cup of tea, and in really bad shape.
Here's the replacement armrest installed. Much better!
Also replaced the window seals, but that's not exactly photo-worthy.
Previously Owned-
2004 E46 330CI ZHP
2009 E70 X5 Diesel
2006 E90 330
Old 12-08-2016, 10:27 PM   #32
CMendez
The car's dead pedal was broken off. Not sure how that happened but it needed to go.
Much better.
New window seals.
And the last bit of parts finally arrived. New flywheel, rear main seal, transmission seals, mounting bolts, etc.
Previously Owned-
2004 E46 330CI ZHP
2009 E70 X5 Diesel
2006 E90 330
Old 12-09-2016, 10:51 PM   #33
CMendez
Time to get back to the dirty work...
Flywheel removed, back of engine degreased. Note how the starter just sits there. The metal gasket that goes between the engine and transmission helps hold it in place, but it really just bolts through the transmission side. Might be interesting getting it back together.
New rear main seal kit installed. Should take care of the oil seepage problem that contributed to the clutch dying in the first place.
New flywheel installed. Ooh shiny...
New pressure plate and clutch disc installed.
Transmission getting resealed, refilled, and going back in tomorrow.
Previously Owned-
2004 E46 330CI ZHP
2009 E70 X5 Diesel
2006 E90 330
Old 12-09-2016, 11:41 PM   #34
Mflara20
My Ride: 04 330i
Be sure to line up the starter, I repeat make sure you line up the starter before you bolt the tranny. I didn't and I had to take off the intake manifold to align it.
Old 12-10-2016, 01:07 AM   #35
CMendez
^Thanks for the tip. Plan to pre-thread the bolts through if I can reach.
Previously Owned-
2004 E46 330CI ZHP
2009 E70 X5 Diesel
2006 E90 330
Old 12-14-2016, 11:26 PM   #36
CMendez
Sorry for the late update. Haven't had a ton of free time lately. Good news, transmission went back in without a hitch. Transmission jack was a huge help here. Being able to tilt the transmission on two axis was very helpful with installation. Make sure to use new bolts. Aluminum bolts are only designed to be torqued once.
Previously Owned-
2004 E46 330CI ZHP
2009 E70 X5 Diesel
2006 E90 330
Old 12-14-2016, 11:29 PM   #37
CMendez
Driveshaft and center support bearing reinstalled.
New flex disc
New center support bearing
Now just need to reinstall heat shield, exhaust, and wheels and car will be back on the road.
Previously Owned-
2004 E46 330CI ZHP
2009 E70 X5 Diesel
2006 E90 330
Old 12-17-2016, 09:34 PM   #38
CMendez
And here she is for now. My ZHP which will now affectionately be known as "Hilde".
Here is Heidi, Hilde, and Matilda.
Hilde drives very well now. Solid suspension, effortless clutch, engine purrs nicely. Going to take a break for a bit and enjoy the car, but have big plans for her in the future.
Previously Owned-
2004 E46 330CI ZHP
2009 E70 X5 Diesel
2006 E90 330
Old 12-18-2016, 01:18 PM   #39
xi46
My Ride: 2002 330xi ZPP/SP/CW
Been enjoying seeing your progress! Can't wait to find out what's next.
xi46 is offline   Reply With Quote
Old 12-18-2016, 07:22 PM   #40
CMendez
^Thanks. Won't be too long for updates.
Previously Owned-
2004 E46 330CI ZHP
2009 E70 X5 Diesel
2006 E90 330
