Old 03-19-2017, 11:32 AM   #61
MTX-4
My Ride: E46 320i
I only disconnect negative battery terminal (not whole battery), I don't know if this vary in some way if we are talking in terms of "reset" -> this equal to total disconnection as the battery has two terminals.
In the las 2 months I disconnect the battery 2 times, reset adaptation one time and disconnect the MAF with the engine ON to reset LTFT numbers one time. Neither of this things change the LTFT negative tendency. -> then my first speculation cannot sustained as you have already disconnect the battery before. Thanks for telling me as I have never disconnected the battery before even when I replaced the battery a used a small battery connected in parallel to avoid memory lost.
I can add third speculation: Seems like all electrical connectors has been designed with low voltages threshold and the years/corrosion makes lost continuity quality. -> Then this is the most likely root cause.
Thanks for the information
Originally Posted by POLGOZ View Post
MTX your speculations have sense. Im my experience, I only disconnect negative battery terminal (not whole battery), I don't know if this vary in some way if we are talking in terms of "reset"
In the las 2 months I disconnect the battery 2 times, reset adaptation one time and disconnect the MAF with the engine ON to reset LTFT numbers one time. Neither of this things change the LTFT negative tendency. The DME bug idea sounds real, but I think... if is in this way and after my several resets and disconnects, why LTFT still failing??
and as you say.. engine happier, happy heart
MTX-4 is offline   Reply With Quote
Old 03-19-2017, 11:35 AM   #62
MTX-4
My Ride: E46 320i
Agree with that and it looks like it is the only reason. Thanks jfoj.
Constant thermal cycling can and will cause the female terminals for sensors to loosen up over time.
You need to pay attention when connecting/disconnecting the connectors to see if the female terminals have enough "grab".
Also many aftermarket sensors do not have the same thickness metal male pins or blades, so this can and is another tricky spot to pay attention to.
Old 03-20-2017, 01:39 AM   #63
MTX-4
My Ride: E46 320i
The DME of this car is a bear to understand and really has a mind of its own.
Old 03-20-2017, 11:42 AM   #64
POLGOZ
My Ride: BMW 328i E46
the fact to fisically disconnect the DME is the trick I think. Some kind of clear/reset happens without the voltage input supply. Something unreachable across software reset or battery supply.
POLGOZ is offline   Reply With Quote
Old 03-20-2017, 08:31 PM   #65
MTX-4
My Ride: E46 320i
Agreed. Somehow I felt the before disconnection the DME program is looping in the wrong mode. After each major repair, the procedure for battery disconnection cannot be emphasized enough I think.
Old 03-22-2017, 07:31 AM   #66
sebograf
My Ride: 2003 325 Ci SMG
Hmm, i checked all my connectors, at the maf, at the icv, at the throttle body and at the dme - all looked finde and it didnt made a difference. still stuck at -3.9...-2.3 and -2.3...-1.6.
but what he says in the video makes too much sense:
after resetting the battery everything works for a week or so and then it gets bad again.
sebograf is offline   Reply With Quote
Old 03-22-2017, 02:20 PM   #67
POLGOZ
Do you disconnect the power supply connectors at the DME?? Im still in -2,3 and 0,0
Old 03-23-2017, 04:09 AM   #68
sebograf
Yes - i disonnected the battery first, then removed all the connectors at the dme, checked everything, replugged everything to the dme and then reconnected the battery.
Old 03-25-2017, 03:42 PM   #69
POLGOZ
Update: now my LTFT values are -1.6 / +1.6
Last night doing a night combined city/highway trip, LTFT values was moving more quick than a city normal travel. They move around in this way bank 1 -2.3 > -1.6 > -0.8 and bank 2, 0.0 > +1.6 > +2.3
Never before since I put an eye over it (3 months), the numbers goes positive on any bank. Definitely this method is doing something.
Old 04-02-2017, 12:00 PM   #70
sebograf
Had a long trip yesterday (over 600kms) and noticed something interesting - when driving 140km/h in 6th gear at a bit over 3000 rpm(with cruise control) values went up to even 0.8/0. Driving slower (120ish, around 2600 rpm values almost imediately dropped to the usual -3/-1.6. Going faster again and the values climbed back up really fast. Still dont know whats causing that, will run some testruns to see if it is rpm related (and thus for example disa related although its only 1.5 years old) or whats going on.
Gesendet von iPhone mit E46Fanatics
