Old 12-13-2016, 06:58 PM   #1
Millhood Garage
My Ride: 1987 Corvette. 2005
Which e46 is best to turbo?
Hello all this is my first post here. Im looking for a e46. My buddy has a 325i and were turboing it in February. All I want to know is which of all the e46 is best to modify and to turbo. Also which will build the most power. Thanks!
Sent from my iPhone using E46Fanatics mobile app_a_
Millhood Garage is offline   Reply With Quote
Old 12-14-2016, 10:33 AM   #2
Cruzader
My Ride: Alpinweiß facelift
not the 325
Cruzader is offline   Reply With Quote
Old 12-14-2016, 10:34 AM   #3
Millhood Garage
Originally Posted by Cruzader View Post
not the 325
Which one would you prefer.
Old 12-14-2016, 10:45 AM   #4
813_Tony
My Ride: 2001 BMW 330ci
Probably the 330 on a budget since it has the m54 that is already in the realm of 225 hp but the best would be a m3 the only problem is once you start putting forced induction on these cars they become a bit more unreliable if you are using it as a Daily. But a 325 would be a fun car to have a turbo on aswell. The m54 in the 330 has a limit of 400hp stock but idk much about the engine in the 325.
813_Tony is offline   Reply With Quote
Old 12-14-2016, 11:11 AM   #5
TrippinBimmer
My Ride: Just Fast!
m3
Alpine White M3
MaximumPSI Stage4
993whp/651wtq SAE Corrected
Old 12-14-2016, 11:18 AM   #6
Millhood Garage
Well i see where i am at that there are so many 325i for sale. And they are mad cheap. What is the most power i could build of a turbo, cams, intercooler, turbo, fuel injectors, and other goodies for a 325i. My goal is 350ish hp.
Old 12-14-2016, 05:41 PM   #7
Commanderwiggin
My Ride: 900rwhp Turbo M3
Originally Posted by Millhood Garage View Post
.... My goal is 350ish hp.
Just buy an M3...intake, exhaust and cams...done.
900+RWHP, PT6870 w/ Custom FSR Turbo Kit, AEM Infinity, Lab22 Motor
Old 12-14-2016, 10:52 PM   #8
Cruzader
323
Old 12-14-2016, 11:03 PM   #9
Rob43
Rob43's Avatar
My Ride: 03 331Ci 5spd R1200R
OP, this is a great answer from someone that knows knows & still knows some more....
Rob43
SUMMIT POINT WV 1:24:229 SCCA
Old 12-15-2016, 01:43 AM   #10
cwarel
My Ride: 330ci coupe
There is a guy running 22 psi in stock engine , he runs e85 ofcourse and makes 700 bhp so about that 400 hp limit i dont know where anyone heard that
cwarel is offline   Reply With Quote
Old 12-15-2016, 05:19 AM   #11
813_Tony
400 hp at the crank is not so much it's limit but instead a safe number if you go more than you you should be replacing the rods and all that good stuff
Old 12-15-2016, 05:50 AM   #12
Millhood Garage
A 330i? Damn.
Old 12-15-2016, 10:31 AM   #13
cwarel
Well im in the middle of getting my e46 turbo its a 330 coupe and i will push stock internals untill crank snaps or knockrod happens or pistons melt what ever on pump gas so next engine ill just build it cuz i got 2 engines in the back that got 30k miles on them but they were sitting there for years covered up ofcrourse and my family is mad about it))
Old 12-15-2016, 11:52 AM   #14
PEI330Ci
58mm of Bliss
PEI330Ci's Avatar
My Ride: 330i, 330Ci
True....but no Pssssshhhhh....
Old 12-15-2016, 03:27 PM   #15
Millhood Garage
323
Why. Better than 330i?
Old 12-18-2016, 03:19 AM   #16
Davconelectric
My Ride: Mainly cars
Listen to the guys saying M3. They are correct
Davconelectric is offline   Reply With Quote
Old 12-18-2016, 10:12 AM   #17
Millhood Garage
Cant afford it
Old 12-18-2016, 11:29 AM   #18
philliplong
My Ride: 2002 325CI
The M54B30 is probably your best option for boost. A few people on here have been doing it with good results around 15 PSI.
philliplong is offline   Reply With Quote
Old 12-18-2016, 10:04 PM   #19
Millhood Garage
Cool thanks
Old 12-19-2016, 12:07 PM   #20
Pole position
My Ride: E46 330ci
The 330 is plenty fine past 15psi. Dont even need to pull the head to replace the studs. Its not bad too, but I haven't and its all still holding together.
Shut up and drive
Pole position is offline   Reply With Quote
