Old 12-31-2016, 05:41 PM   #1
Ev0lone
My Ride: 2000 328ci
2000 328ci auto
Yes it's auto...i know...no I'm not just buying and m3 and slap an intake on it...or no I will not just buy a 335 if I want a boosted car.
Lol sorry for that but people keep suggesting the easy way out for what I WANT to do...so here it goes.
Now this is my first legit post on here asking for some assitance so please if youre not going to add beneficial information then you do not need to put your two cents in.
So onto the reason of this thread.
My plan is to boost my m52tub28. Unfortunately I seen little to no information on people boosting a tu. Currently it's stock but my next move is doing the Porsche caliper swap using rallyroads caliper brackets with the m3 csl rotors.
From there I'm gonna start working on my shopping list for turbo parts and eventually put an smg in.
Now for my questions...
Head gasket...i been looking for a mls 140 gasket but I seen to find nothing listed under a tu...all i seem to find is m52 or m54...would one of those work with a tu?
As far as a stroker kit to turn my 2.8 into a 3.0...is there a way to do this without having to shave down piston?
Turbo option...i kind of want to cheap out a bit initially until I actually decide to bite the bullet and get a greddy unit I kind of want to rip a stock turbo off a car and have a friend of mine fabricate a manifold for me. Any ideas on what turbo or car would be a good choice to rip one out of? Obv I plan on rebuilding the turbo before installation so just kind of curious as to what would be a good choice.
Exhaust i plan on fabricating with some magnaflow outlaws or if i find a good turboback I may go that route.
I plan on ripping some Injectors out of a Volvo or maybe jus buy green bocshe injectors from ecs.
Fuel pump...i seen a few online but does anyone have a good suggestion?
I plan on slapping m50 cams on provably before i even boost along with an m50 intake manifold...now ivr heard this requires me to turn my car to obd1 but I've seen a bracket for it so i can use my current throttle body...if anyone had any info on this that woulf be a lot of help.
And for the biggest issue of them all...anyone know any reputable tuners in North jersey?!?!? Lol I've spoken with a few few and im noy sure if they just don't feel comfortable with bmw engines but that's where i leep gettting these "just buy am m3/335"
So lets see how this goes
Ev0lone is offline   Reply With Quote
Old 01-03-2017, 02:51 PM   #2
Ev0lone
My Ride: 2000 328ci
Bump
Old 01-04-2017, 11:45 AM   #3
PEI330Ci
58mm of Bliss
PEI330Ci's Avatar
My Ride: 330i, 330Ci
Forget about it.
I've pushed a heavily upgraded 5HP19 automatic past it's limits with only 5 PSI of boost. (I have more $$$ in my transmission setup than the cost of your entire car)
PEI330Ci is online now   Reply With Quote
Old 01-04-2017, 01:09 PM   #4
TrippinBimmer
My Ride: Just Fast!
Forget about it.
I would take Adam advice to heart. I am in need of a new transmission soon only 92k on it
Alpine White M3
MaximumPSI Stage4
993whp/651wtq SAE Corrected
Old 01-05-2017, 01:11 PM   #5
autospeed_01
My Ride: 2000 328Ci
Use the m54 parts, the tu shares a lot of its design with the m54. The older cast iron engine had different coolant passages and the head gasket from that definitely won't work.
M54 crank, con-rods and pistons.
Search it. The information is endless on various forums for turbo bmw setups. You have "x" displacement to work with (whether you decide 2.8 or 3.0L). What type of powerband are you after? Eg. Fast Highway Runs vs weekend drag car vs quick daily driver.
By searching you can find the turbo m54 thread:
http://forum.e46fanatics.com/showthr...p#post17030936
The OBD1 thing was for e36s.
This thing called search lead me to this thread:
http://forum.e46fanatics.com/showthr...&highlight=m50
If you convert the car to ms43 then RK Tunes can do it:
http://forum.e46fanatics.com/showthr...hlight=rktunes
My Build Thread
From Salvage to Custom Widebody
DTM Style Angel Eyes (flat bottom)
autospeed_01 is offline   Reply With Quote
Old 01-21-2017, 02:52 AM   #6
LastGreatOne
My Ride: E46 328i
Im also looking at doing a boost engine build now idk what info i read i can trust but my idea and please guide me if im wrong is to run a 330 camshaft and a rods ( these are forged from what i have read ?) Idk about piston heads yet idk what would work best/cost? Now should i look at upgrading the valve springs or just buy oem? And the other thing i was thinking is getting a 330 air intake manifold (supposedly they flow better than 328 ones) I was also looking at msl headgasket but why did you decide 140 the page i read recommended a smaller one ?
Sent from my LGLS992 using E46Fanatics mobile app
LastGreatOne is offline   Reply With Quote
