"Pulsing" or "surging" in 3rd gear - Page 2 - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 02-01-2017, 09:54 PM   #21
bayos04
Hmmmm. I think I have an XP laptop at work that I don't care about....
bayos04 is offline   Reply With Quote
Old 02-02-2017, 04:03 AM   #22
topher339
My Ride: 2001 M3
Best of luck.
topher339 is offline   Reply With Quote
Old 02-21-2017, 09:55 PM   #23
bayos04
Update #2
Got my scan tool. No codes at all
Disconnected the battery for a minute, no change
TPS tests fine.
I did find this thread that sounds like my issue
http://www.bimmerforums.com/forum/sh...urging-feeling
Software update? Anyone else have this done. As I don't have any codes I don't want to drop a few hundred bucks at the steelership for no reason. Would an Indy shop be able to handle this?
That thread describes it as pulsing, which is probably more accurate. It is like I am lifting off the throttle and then hitting the gas again, but 200 times a second. When the pulsing hits, its frequency does not change with engine RPM.
I have discovered it is there in second, but the torque and quick acceleration hide it. Going up a steep hill makes it slightly more apparent. It is also there in fourth, but you really have to be paying attention.
Sent from my iPad using E46Fanatics
Old 02-21-2017, 10:17 PM   #24
jfoj
My Ride: 330CiC, M5, X5, E93
forum.e46fanatics.com/showthread.php?t=966614
Old 02-21-2017, 11:42 PM   #25
bayos04
Thanks jfoj. Only one problem. My surging doesn't stop at 3000 rpm. It continues right up to redline. Do you think it is the same problem?
Old 02-22-2017, 12:25 AM   #26
MacLoGoS
My Ride: 1999 323i sedan
Originally Posted by topher339 View Post
Love the pre-71 models. Although, I was actually looking for a Camaro at the time... Simplicity is king with classic cars.
I have a 70 Camaro RS 4 speed. Decided to restore it and swapped a LS1 in it. Its the metal and body work that kills you on these!!
MacLoGoS is offline   Reply With Quote
Old 02-22-2017, 05:35 AM   #27
jfoj
DME flash may be in order anyway given the model and year.
But the problem should not have come on out of nowhere, unless you have started to drive the car differently.
If you have OBDFusion you could do some Logging, but to monitor the Ignition Timing properly, you would want to use no more than 4 PID's for Logging.
If the timing is the problem it should be pretty clear if you can get a good Log.
Has any work been performed just before this problem showed up? I see this is a lower mileage car.
Old 02-22-2017, 11:02 AM   #28
topher339
My Ride: 2001 M3
Indeed. Specially if you live in a rust-prone area.
Old 02-22-2017, 11:07 AM   #29
topher339
My Ride: 2001 M3
If a flash won't fix it, it might just be time to hand it off to a mechanic. You should be able to find a decent indy shop that specializes in BMWs.
Old 02-22-2017, 02:33 PM   #30
bayos04
Did some more testing this morning. I realized that if I shift into third above 3000 rpm it doesn't happen. It has to start in that 2500 range. Mine just doesn't stop at 3000 once it starts.
So I am thinking it really is that same issue.
I don't ever just take my car to a shop, Indy or otherwise. I have yet to pay a mechanic for anything in my 39 years, and don't plan on starting now. That being said, I will pay them to flash the DME and possibly a full scan that I can't do, but that would be the end of it. With all the experience on here and other forums the odds of even a good Indy shop figuring out a problem that I can't is slim, and will cost me a whole pile more $$$ in the long run. Nothing against mechanics, they exist for a reason.
Old 02-22-2017, 02:39 PM   #31
bayos04
Sorry, my app just updated and I missed your reply jfoj. I haven't played with the OBDfusion app enough. I will figure out how to log things and post them up when I have a chance.
The only thing that has been done in the last 6 months is a cooling system refresh, and I put in a GAS disa valve repair kit.
This is a very subtle problem, and as others have experienced, it is only when driven "moderately" hard. Meaning just idling around town, or really going hard (rpm always above 3000) it doesn't appear. So I may just not have noticed. I have only put 6000 kms on the car in about 9 months, so it isn't driven all that much (thus the low miles).
Old 02-22-2017, 03:34 PM   #32
jfoj
Read the PDF in this thread about OBDFusion and Logging - http://forum.e46fanatics.com/showthread.php?t=1097893
Your DME needs to be updated.
I will outline your issue.
Starting off in 1st gear and make a spirited run you have no problem. This is because the engine spins past 3k RPM and you shift at 5000-6500 RPM and the engine never drops back below 3k RPM. This means the engine RPM is out of the 2-3k RPM range where the timing Map problem is. The car runs well and performs as you expect it to. You think to yourself "wow, this thing runs good, why do I have this other problem?"
Driving around and start to accelerate in 3rd or 4th gear with the engine RPM under 3k and there may be a slight incline you will feel it and the more you tip the throttle in under 3k RPM the worse or more obvious the problem becomes. The lower the RPM and the further you tip in the throttle you can even get the car to "buck".
In 4th-6th gear if you tip into the throttle while under 3k RPM it may or may not happen depending on the load and road grade.
If you can find the "sweet spot" where it really acts up and you can start to tip the throttle in deep & hard but not fast, it will really act up, car feels like an anemic 4 cylinder, feels like misfiring, but never a misfire code. If you ever get the pedal to the floor while this is all going on and you have road available, the car will not pull for crap.
You NEVER hear the engine ping or knock, even with Regular fuel, you might hear an occasional knock or ping, but never when getting hard onto the throttle.
When coasting down a hill in gear and transitioning back into the throttle there is bucking.
If I am even 60% correct, UPDATE the DME!!!!
Old 02-22-2017, 04:01 PM   #33
bayos04
Bang on jfoj. Other than it never feels anemic. It still pulls fairly hard, but otherwise 100% accurate. Thank you.
Old 02-22-2017, 04:18 PM   #34
jfoj
Maybe you have not been able to get the anemic mode, it takes very specific driving conditions, bet I could get it to happen! Wait until you find out how the car runs after the DME update. Can you believe the car has been like this for 13 years!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
DME reflash with the latest update is needed.
Granted there may be other underlying problems, but the DME update is the smartest first step.
ASK ME HOW I KNOW ALL OF THIS.
I dealt with this NOT on and E46 and NOT on a 6 cylinder. BMW F**KED up the Ignition Timing Maps for many models, many engines for many years.
I need to have my 2008 E70 X5 with a 4.8l flashed as well!!!
Old 03-20-2017, 07:32 PM   #35
bayos04
Hey jfoj, would a tune from active auto works or someone similar fix the problem as well. I have been really busy at work and have hardly driven the car in the last two months. I did talk to the stealership and it will be just shy of $200, and a major pain in the ass to get it there. I can get the aa cable and software for $400, do it at home, and gain some performance at the same time.
Thoughts?
Thanks again,
James
Old 03-20-2017, 09:19 PM   #36
jfoj
Here is the PROBLEM.
Almost ALL 3rd party DME flash programs extract the OE flash that is currently in the DME, then they tweak the timing, fuel and VANOS tables and then you flash this back into the DME.
The PROBLEM is Garbage In = Garbage Out, the screwed up Ignition Timing tables will typically be carried over and often the 3rd party tune is even worse then with the stock tune.
You REALLY need to update the DME before you make any DME changes with 3rd party performance updates.
Old 03-20-2017, 09:22 PM   #37
bayos04
Thank you very much for your assistance jfoj. Greatly appreciated.
Old 04-05-2017, 08:19 PM   #38
bayos04
Well I finally had time to get my car in for a re-flash. My wallet is $280 lighter, but the stutter is gone!
Thanks again jfoj.
Old 04-05-2017, 08:26 PM   #39
jfoj
Glad the DME flash sorted the problem, there are WAY too many BMW's with this problem.
I believe even my 2008 E70 X5 4.8l has this same problem.
Dumb ass BMW DME programmers!!
Old 04-07-2017, 05:55 PM   #40
ctad
My Ride: 330ci
So my vehicle has very similar problems. I've only noticed it in 3rd or 4th gear and it's pretty much exactly from 2700-3000 rpm only. So to make a long story short, found an independent mechanic to do it for $95. He asked what was happening and I explained the problem to him. He said that updating the DME has never fixed the problem for him but he'd do it anyway. BTW, His suggestion was the problem was with the ignition coils. Anyway, about 10 minutes later he comes to talk with me and said that when his tech hooked up the car to do the reflash, a warning message came up on their computer warning them that if they did the reflash, it could wipe out and/or damage the whole electrical system (DME, ECU, etc.). Anyway, I decided to bail on it and do more research. Has this happened to anyone who has tried this. Also, once the DME is reflashed, is there anything else on the car that needs to be updated as well (that coincides with the DME update)? Thank you.
ctad is offline   Reply With Quote
