Old 02-01-2017, 12:04 PM   #1
Sushiholic
My Ride: 06 M3 11 335d 96 Z3
issue with Active Stage 1.5 '06 M3
We are having some issues. It started to run a little rougher, and finally set a code, then really ran bad, that was a code for injector circuit on Cylinder 3. We reset the code and it ran fine for a while. Then the same problem occurred, now the code was misfire on Cyl 5. (we did swap coils to verify that this was not a coil issue, all plugs recently replaced)
We then ordered 6 "new" injectors, green giant 42lb. replaced all 6 injectors.
Now things get weird, (interesting) after putting in 6 new injectors it runs "funny" after applying throttle and backing off, there was a "flutter" now it sets P0202...... appears we have a bad "new" injector on 2.
We then swapped 1 and 2, and put an old injector on 1, now the code is P0201. replaced that "old" injector on 1 with another "old" injector. still P0201, and still the flutter. any ideas here ?
Sushiholic is offline   Reply With Quote
Old 02-01-2017, 03:32 PM   #2
TrippinBimmer
My Ride: Just Fast!
I would do a compression test and get back with us.
Alpine White M3
MaximumPSI Stage4
993whp/651wtq SAE Corrected
Old 02-17-2017, 01:32 PM   #3
Sushiholic
OK. Compression is fine. Things are still interesting.
Realized that the flutter was a vacuum leak, fixed that leak, and flutter gone. There still was a misfire on 2. when pushing on the injector wire harness, on 2 that went away. We messed around with it, and it ran great constantly. We then realized that there was a slight fuel leak from the fuel like connector. replaced the o-ring. that meant taking off the fuel rail again. Now we had a miss on cylinder 4, that goes away when you push on the harness.
is there a trick to putting on the fuel-rail and/or harness ? is there some alignment that needs to be done, and if so how. I am about to take it in to have it "fixed" at my indy shop, but they cant touch it until Tuesday.
Old 02-24-2017, 06:50 AM   #4
Landlorder
My Ride: 330CI Sport
I would replace the o rings on the injectors, and when fitting the fuel rail start with injector 1 push down and work your way along injector 2-6. Push firmly. And start at an angle. That's how I do it.
Landlorder is offline   Reply With Quote
Old 02-26-2017, 02:48 PM   #5
Sushiholic
the injectors are all new, orings should be fine.
Got it back from shop......verdict was a bad ground pin on injector 4
drove like a bat out of hell for 40 miles......then back to intermittent missfire....... now says cylinder 2
Old 02-27-2017, 11:38 AM   #6
AMG-ETR
My Ride: S54B32 On Boost
Send a message via MSN to AMG-ETR
So did you check the ground wire for the remaining?
AMG-ETR is offline   Reply With Quote
