Sponsored by The Tire Rack
Old 02-02-2017, 12:45 PM   #1
Ne70
My Ride: E46 323ci
best tire size for E46 with 19" inch rims
Hello there;
i just recent buy some CLS rims for my E46
I was wondering about the tire size
right now I'm running, 19"inch rims with
235/35/R19 in the 4 wheels (staggered)
the new CSL rims are: 8.5 in the front, and 9.5 in the rear
I was thinking using only the front tyres in the CSL rims, and buy 255/30 for the rear
any suggestions?
Ne70 is offline   Reply With Quote
Old 02-02-2017, 02:52 PM   #2
SK330ci
My Ride: 02 330ci w/ 3 Pedals
A 255 30 19 on the rear will work good.
Mods: Header, CAI, Shark, Koni Sport Struts, Rob43 9 Way Shocks, Big Sway Bar, Special Lowering Springs, 3.38 Diff, PFC Z-Pads, 75 Shot Of N20
E46 M3's are just tasty snacks i eat for lunch.
SK330ci is offline   Reply With Quote
Old 02-02-2017, 04:04 PM   #3
Ne70
My Ride: E46 323ci
thanks... I think I'll bought some 255/30 for the rear, and keep the 235 in the front
I want to avoid this style:
https://uhappy2stance.files.wordpres...-hs-7-edit.jpg
don;t like the rim stepped out the tyre
I prefer that the tyre can cover the full rim
Old 02-02-2017, 07:20 PM   #4
BartenderPlease
My Ride: '03 540i/6 M-Sport
What is the offset? Nothing wild?
.............................................@jb540i6
'02 JR/Naturbraun 330i M-Tech I | M-Tech II Fr. | Supersprint Headers | Remus Sport |
.....| SM Flywheel Conv. | 18" CH'ish reps | Short Shift | Orion V2.5 | RCR LED Tail |
'03 JB/Schwarz 540i M-Sport 337 | Decatted | Short Shift | Carbon Fiber Trim |
BartenderPlease is offline   Reply With Quote
Old 02-02-2017, 07:28 PM   #5
Ne70
My Ride: E46 323ci
the new rims are: offset front/rear: 35mm
the current ones ,not sure, let me post a picture of it:
Old 02-03-2017, 02:58 PM   #6
BE46N
My Ride: E46 M Sport Coupe
Should be good with 35mm offset, 9.5 Inch width and 255/30 /19, you'll probably have more room on the suspension side than the body side though, if you go super low you'll probably need to roll the arch/fender but that's no biggie.
Sent from my SM-G930F using E46Fanatics mobile app
BE46N is offline   Reply With Quote
Old 02-04-2017, 05:30 AM   #7
powerstroke
My Ride: 330i G-string
Those tires look oversize,try to reduce on width & increase the profile slghtly.
Sent from my GT-S7392 using E46Fanatics mobile app
powerstroke is offline   Reply With Quote
Old 02-04-2017, 05:31 AM   #8
powerstroke
Try 225/40 R19
Old 02-04-2017, 05:32 AM   #9
powerstroke
Remember not to go too much away from manufactures standard.
Old 02-04-2017, 06:34 AM   #10
BE46N
225/40/19 on a 9.5 width will be stretched a bit and give the look he doesn't want, coupes came with 255/35/18 as standard on an 8.5 inch wide rim so no issue going 255/30/19 as long as the offset is 35 or so, may need to roll the arches if it's lowered
Old 02-06-2017, 01:00 AM   #11
powerstroke
Oh!ok its worth giving it a try..
Old 02-07-2017, 09:34 PM   #12
Bcovany
My Ride: 2005 325i
What about 255/40/r18 on the rear and 225/40/r18 on the front how would that look ?
Sent from my SAMSUNG-SM-N920A using E46Fanatics mobile app
Bcovany is offline   Reply With Quote
Old 02-07-2017, 09:51 PM   #13
Rodrow11
My Ride: '04 330 Ci ZHP
I have 19" with 9.5 rears with 265/30, no rub and fills out the space nicely. Fronts, on 8.5s are 235 with no rub.
Rodrow11 is offline   Reply With Quote
Old 02-08-2017, 12:05 AM   #14
powerstroke
Wud recomend 235 on the back & 225 in front,e46 never luks good wt wheel aches so to avoid water and mud splashes all over the car I stil recomend the above.
Old 02-08-2017, 12:37 AM   #15
Perfecto
My Ride: E46 328ci
Some guys made an awesome webite for this. Go to www.tyrestretch.com and just find your fitment. It really is an awesime page for these questions
Another one. Go to http://www.1010tires.com/Tools/Tire-Size-Calculator
Here you can calculate your overall wheel size (rom+tire) so you know how is your speedo and car dynamics affected.
Im posting from mobile if the links do not work just google them.
Sent from my SM-N9005 using E46Fanatics mobile app
Perfecto is offline   Reply With Quote
Old 02-08-2017, 03:41 PM   #16
Ne70
My Ride: E46 323ci
I assume is not good idea to have the same width in the 4 tyres right?
for example:
235/35 front and 255/35 rear
I think If I put in the rear 255/35 would be nice, and no need to roll the rear fenders
Old 02-10-2017, 02:07 PM   #17
BartenderPlease
for example:
Avoid doing that.
My E39 needs one size up on the front sidewalls to be corrected. Even when I hit third gear the DSC light flashes and the DME steps out of the gas or whatever it does very briefly.
I'm certain I'm NOT breaking the tires loose enough (not even at all) to cut throttle and blink on the dash. I blame this on the diameter being too far apart from F to R.
Also, I don't know how many more mm's the coupe has over the sedan, but if you are going to use a 255/30/19 rear, you will rub if you are lowered. At least when you have a load or a passenger, but probably any time. This also depends how stiff the suspension is, and the camber you are running, and the brand tires you run, and if you are rolled or not on the fenders.
Old 02-10-2017, 02:21 PM   #18
Ne70
My Ride: E46 323ci
235/35/19 in the 4 tyres, I;m lowered with HR springs
but with my new rims, i'm thinking to put 255/35 in the back
255/30/19 over here it;s really expensive tyre...
Old 02-10-2017, 02:33 PM   #19
BartenderPlease
Ok, but that is too tall and will not look as good, either. You will be more likely to rub with that as well, due to where the tire rubs up in the fender area. It bypasses the lip and scrubs up above that.
Old 02-10-2017, 02:36 PM   #20
Ne70
My Ride: E46 323ci
ok...
i'll do my best to buy 255/30/19 in the rear
actually with the 235/35 is not rubbing in the fenders
