Sponsored by The Tire Rack
Old 02-10-2017, 03:42 PM   #21
Bcovany
My Ride: 2005 325i
I did 255/35/18 rear 225/40/18 on the front and it's everything I wanted even the 13inch back tire some people don't like that but if you don't just go 235 rear or even 245
Sent from my SAMSUNG-SM-N920A using E46Fanatics mobile app
Bcovany is offline   Reply With Quote
Old 02-10-2017, 03:46 PM   #22
Ne70
My Ride: E46 323ci
the problem with the current 235/35
is that in the rear the rim is bigger than the tyre (wider) , so, don't like that look at all
i wanted that the tyre could fill all the rim, so that's why i'm thinking in 255 in the rear
Ne70 is offline   Reply With Quote
Old 02-10-2017, 03:50 PM   #23
BartenderPlease
My Ride: '03 540i/6 M-Sport
To get rid of the 9.5" wheel being wider than the tire you would need to go with a beefier 275, like a BFGoodrich G-Force Sport. That just won't fit. So in all honesty it requires more work than normal, or an 8.5" wheel with BFGoodrich 255/35/18's.
.............................................@jb540i6
'02 JR/Naturbraun 330i M-Tech I | M-Tech II Fr. | Supersprint Headers | Remus Sport |
.....| SM Flywheel Conv. | 18" CH'ish reps | Short Shift | Orion V2.5 | RCR LED Tail |
'03 JB/Schwarz 540i M-Sport 337 | Decatted | Short Shift | Carbon Trim | JL Audio | V1
BartenderPlease is offline   Reply With Quote
Old 02-10-2017, 03:53 PM   #24
Ne70
My Ride: E46 323ci
my current rims are:
8.5 front
9.5 rear
the new rims are:
8.5 front
9.5 rear
do you think with 255/35 or 255/30 I can forget about that problem
Other people over here in CR, mention that if I put 265 in the rear, I'll start rubbing in the fenders if I there's people in the back seats
Old 02-10-2017, 03:57 PM   #25
BartenderPlease
Unfortunately those wheels will be wider than the tire. I know that 255 mm is equal to 10 in., but when it is mounted and aired up, one tire just doesn't work out to having 1/4" per side of "beef" to it.
Old 02-10-2017, 03:58 PM   #26
BartenderPlease
actually, this does not look too bad.
http://forum.e46fanatics.com/showpos...2&postcount=13
Old 02-10-2017, 03:59 PM   #27
BartenderPlease
http://forum.e46fanatics.com/showthread.php?t=795013
I'll be back in this thread later tonight. Some info in the link above.
Old 02-10-2017, 03:59 PM   #28
Ne70
My Ride: E46 323ci
got it... that is a problem
tyres over here are: 255/30 about $320 each - kumho or something
255/35 are about : $100 each - generic
Old 02-10-2017, 04:00 PM   #29
BartenderPlease
WOW! Run a 245? :/ Not sure. That is insane.
Old 02-10-2017, 04:09 PM   #30
Bcovany
My Ride: 2005 325i
255 in the rear is amazing fat back tire but if you don't mind it it covers the whole rim nicely I definitely recommend that to you
Old 02-10-2017, 04:13 PM   #31
Ne70
My Ride: E46 323ci
yeap that's what I want
but Im inquiring about if with 255 is going to rub the fenders or something
my car acttually is this with the old rims
