Sponsored by The Tire Rack
Old 02-11-2017, 09:29 PM   #1
TJM
My Ride: 330i
Clutch Replacement
I own a 2005 330i with a 6 speed manual transmission. The clutch is slipping and I will be replacing it. Should I plan on replacing the flywheel? Should i stay with a dual-mass or convert to a lightweight single?
TJM is offline   Reply With Quote
Old 02-12-2017, 08:24 AM   #2
1stWorldProblems
My Ride: 04 330i, 05 S2000
This is in the wrong section, but I'd like to know the answer myself as I may have a leaking rear main seal and should replace the clutch during the repair. From my research, the lightweight flywheel creates a lot of chatter that doesn't seem worth-it to people that daily drive their cars. Not sure if the flywheel is an item that wears out and should be replaced.
2004 330i ZHP
2005 S2000
1stWorldProblems is offline   Reply With Quote
Old 02-12-2017, 03:51 PM   #3
Renboy
My Ride: 04 330Ci '08 Daytona
Unfortunately there are very few options for the 6-speed non-m e46's. There's essentially 2 options: stock dual mass flywheel and stock clutch, or a very light weight aluminum flywheel from JB or UUC that will chatter. On the 5 speeds there was not much if any chatter, but on the 6 speeds it's almost guaranteed. If you're not racing, stick to stock.
Renboy is offline   Reply With Quote
Old 02-13-2017, 09:38 PM   #4
TJM
My Ride: 330i
Sorry this was in the wrong section - but thank you for the information on the flywheel. I've read info that says that the chatter in a lightweight flywheel isn't that bad. Just planning on replacing the original since the tranny will be apart.
Old 02-16-2017, 10:46 PM   #5
Renboy
It's not that bad on 5-speeds. I had one in my 325CI and it made no noise. On the 6-speeds it's quite audible.
