Sponsored by The Tire Rack
Old 02-13-2017, 01:30 PM   #1
ZHPOWER
My Ride: 2003 ZHP
Help... ordered ARC-8s but...
Here's the situation
I'm currently running a staggered setup with 19x8.5 and 9.5 OZ's (offset 46) and with H&R Cup kit. Some rubbing under load so decided to order ARC-8 square setup 19x8.5 et 35 - I'm positive I wont have rubbing issues BUT you think a 9" ET38 rear would rub?
Thanks!
ZHPOWER is offline   Reply With Quote
Old 02-13-2017, 03:31 PM   #2
hodgkinsc330ci
My Ride: 2002 BMW 330Ci
You're moving the wheel out 8mm farther than it was, plus you have .5" less of wheel. I guess it really depends on how bad your rub is.
Sent from my 831C using E46Fanatics mobile app
2002 BMW 330Ci 5AT
Originally Posted by lingon300k View Post
[BMW Motors] Advertising has somehow convinced people that they're different. That they're made by magical Dachshunds who only eat special bratwursts made by virgins in an undisclosed magical spot inside of the black forest that can only be accessed via a special hydrogen powered BMW helicopter.
hodgkinsc330ci is offline   Reply With Quote
Old 02-13-2017, 04:24 PM   #3
ZHPOWER
My Ride: 2003 ZHP
I'll stick with the square set up for now. thanks
Old 02-13-2017, 05:14 PM   #4
hodgkinsc330ci
Awesome. Yeah, square ARC-8's in 8.5" won't rub at all, especially if you have an M.
2002 BMW 330Ci 5AT
Old 02-13-2017, 05:43 PM   #5
SK330ci
My Ride: 02 330ci w/ 3 Pedals
If you want to get rid of rubbing with your current wheels n tires,
Raise it up a 1/4" all around, problem solved.
Mods: Header, CAI, Shark, Koni Sport Struts, Rob43 9 Way Shocks, Big Sway Bar, Special Lowering Springs, 3.38 Diff, PFC Z-Pads, 75 Shot Of N20
E46 M3's are just tasty snacks i eat for lunch.
SK330ci is offline   Reply With Quote
Old 02-28-2017, 01:25 PM   #6
Vas
My Ride: zhp
Curios to see pictures of the new ARC8 wheel set-up.
Got any?
Vas is offline   Reply With Quote
Old 03-01-2017, 02:15 PM   #7
lamsv
My Ride: 2001 325iT
^ His signature shows them mounted.
lamsv: 2001 HELLROT on BLACK 325iT
lamsv is offline   Reply With Quote
Old 03-01-2017, 04:31 PM   #8
Vas
My Ride: zhp
Saw that but was hoping for full size images
Old 03-01-2017, 06:51 PM   #9
lamsv
My Ride: 2001 325iT
^ Click on his sig picture... it takes you to the larger picture. You are welcome.
