330Ci turbo Daily car - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 02-25-2017, 09:29 AM   #1
JoeTe
My Ride: BMW 330CiA '04
Hello everbody,
I'm plaining go to turbo (another more yes!) in my 330Ci Steptronic. Is my daily car but I don't use a lot probably about about 15000 km/year.
In first time I know that Steptronic is the biggest problem but at the moment I would like keep it . If it broke then I would go to Manual and probably more boost.
First I will go buying the parts bit by bit and when I have all go to install (you know daily car so I can't stay a lot time without it)
I would like have some advice and if you think that I would need some part more. I first time I hope go to 7-8 psi
-Turbo T3/T4 with internal wastegate. Compresor trim 55 and Turbine 0.63A/R
-Siemens deka 42lb injector
-Cast Iron manifold (bottom)
-Modified mount (for bottom turbo)
-BOV quiet (I don't like the "psss")
-Manual Turbo Controller (or maybe don't use it and just regulate by internal wastegate)
-330d e46 Intercooler. I know people use universal intercooler, but I think this will be easier to install and like is smaller than others so I will get less "lag" (is important for me). I think that work good in that setup because if 330d e46 work about 20 psi andI plain go about 7-8psi I guess will be enough
-Downpipe 3" stainless homemade
-All piping about intercooler. Compresor outlet to intercooler in 2" and intercooler to throttle in 2,5" and final adapter to 3".
-MS43 tune
-OEM MAF
What do you thing? Did I forget something? Some advice?
Cheers guys!
JoeTe is offline   Reply With Quote
Old 02-25-2017, 12:42 PM   #2
daniel_f.
My Ride: 330iC
Wastegate can be Controller by MS43, no need for external Controller. If you can afford, install alpina torque converter and flash alpina Egs Software. Should work with ~ 350hp, torque can be reduced where it's needed.
Im currently at baby vacancy!
Siemens MS42 wiki!
Siemens MS43 wiki!
Old 02-27-2017, 04:55 AM   #3
eemil
My Ride: Z3 Coupe
Where can i find more info on controlling the wastegate?
eemil is offline   Reply With Quote
