Old 03-07-2017, 08:36 PM   #1
OnTheFence
My Ride: 2001 330i (and 530i)
Swapped headlight bulbs. Passenger side still going out.
Passenger side bulb intermittently going out.
I get the warning light on the dash.
I swapped the driver's and passenger bulb.
Passenger side bulb still intermittently going out.
So, it's not the bulb.
What's my next step?
Ballast? Ignitor? I have zero clue about any of these parts.
Do I buy a new one? Both? Part number?
How hard are these to replace?
OnTheFence is offline   Reply With Quote
Old 03-07-2017, 09:07 PM   #2
SHALANG
My Ride: BMW 330I
Try swapping out the ignitors. If it turns on then that's your problem.
If not, could be a wiring fault. May be a loose connection, ground or corroded bulb socket.
SHALANG is offline   Reply With Quote
Old 03-08-2017, 05:44 PM   #3
OnTheFence
I'm having trouble finding a DIY for how to replace the ballast.
I don't even know where it is.
Also, anyone have a part number?
I only want OEM (or junkyard replacment, if deeply discounted)
Old 03-08-2017, 05:53 PM   #4
SHALANG
My Ride: BMW 330I
1 307 329 074
Old 03-08-2017, 06:10 PM   #5
OnTheFence
Do I order part #3? Is it an east remove and replace?
http://www.realoem.com/bmw/enUS/show...diagId=63_0644
Old 03-08-2017, 06:15 PM   #6
SHALANG
My Ride: BMW 330I
Did you try what I said regarding the ignitors?
Don't just order things because it may not even be the problem.
Old 03-08-2017, 06:18 PM   #7
jfoj
My Ride: 330CiC, M5, X5, E93
Maybe not the same problem as the Adaptive Bi-Xenons, might want to at least look at this problem - http://forum.e46fanatics.com/showthread.php?t=1121315
Old 03-08-2017, 07:02 PM   #8
OnTheFence
Is it stupid to buy a new $70 aftermarket ballast?
Is it stupid to buy a used ballast for $30?
I see a new ballast for $150 or so.
Old 03-08-2017, 07:04 PM   #9
OnTheFence
Ok, I will swap the ignitors.
My attitude is that if I am going to take the time to remove something, I'd rather just replace it if it's a common wear item.
So, I almost prefer to just drop the $150 if I've got a 50%+ chance that is the issue.
Is swapping ignitors like an easy scale DIY?
Under 1 hour? If so, I guess I will swap before buying.
Old 03-08-2017, 07:06 PM   #10
OnTheFence
I'll take a 2nd look at the wires, but everything is clean and intact, if I recall.
Old 03-19-2017, 04:07 PM   #11
OnTheFence
I switched ballasts today.
That was more of a PITA than I Was expecting.
First, the retaining bracket would not come off easily because of the clip on the bottom side.
Then I realized I needed to remove the entire carrying bracket in order to free the ignitor cable.
Getting those tiny bolts on and off on passenger side was a PITA with the A/C lines in the way. Magnet tool was a savior.
Then I realized I needed to also disconnect the other bulbs to clear the wires clearance.
I did not tuck the cables back like OEM when I reassembled.
For $50, I should have just replaced the passenger ballast instead of hassling with swapping.
Now, I will drive with my lights on and see if the problem switches to the other side.
Old 03-20-2017, 07:07 PM   #12
OnTheFence
Do I need the exact same Ballast model number?
Mine says 5DV 007 760-29
This new one from China says
5DV-007-760-37
Are aftermarket ones to be avoided?
Is the last number just a version that can be updated?
Should I just buy a used one for $50 ?
