Old 03-19-2017, 06:25 PM   #21
michaelnoblega
My Ride: 2001 Bmw 325i
I agree - to an extent. All engines operate on the principle of "x" amount of oil pressure being present to lubricate the main & rod bearings. All I'm saying is that these engines tend to survive oil starvation better than most.
michaelnoblega is offline   Reply With Quote
Old 03-19-2017, 06:45 PM   #22
turbo8
My Ride: 2002 325i
Yes, I had a 944 turbo that had a problem going around left turns(maybe right turns, I don't remember). If it was a high enough G turn, it would starve the engine of oil and the #2 crankshaft bearing would get destroyed. Happened to me, expensive fix. Fun car though.
turbo8 is offline   Reply With Quote
Old 03-19-2017, 06:58 PM   #23
WDE46
My Ride: '13 128i, '04 330Ci
I don't know where you're getting that impression from. Any engine will get damaged almost instantly without oil pressure. It's just how the bearings work. As soon as metal contacts metal, it's never going to be the same. An engine run without oil pressure for anything but a miniscule amount of time (seconds and then shutting it off completely) isn't worth trying to investigate and salvage.
This guy's N55 survived about 10 minutes before seizing. Damage is immediate and starts getting worse and worse.
http://www.1addicts.com/forums/showthread.php?t=1359507
I have a dream that one day our children will live in a
nation where they will not be judged by the color of
their skin but by the color of their coolant.
Old 03-19-2017, 06:59 PM   #24
WDE46
That's a design flaw in the 944's oil system, not a sign that the M54 is robust to oil loss.
Old 03-20-2017, 11:49 AM   #25
goodmanr
My Ride: 01 325i Sprt&PremPkg
It's probably cheaper to replace the oil pan then to buy another car.
goodmanr is offline   Reply With Quote
Old 03-20-2017, 12:19 PM   #26
Dave1027
My Ride: '06 IR zhp coupe
Of course it would be but the OP's point is the engine is likely toast plus all the other damaged suspension parts.
Old 03-20-2017, 12:37 PM   #27
goodmanr
Actually, the OP never mentioned anything about the suspension. The question was "should I replace the oil pan?" But since he already bought her another E46 I guess it doesn't matter anymore. In fact, now I'm not sure why he even asked the question in the first place.
