General Off-Topic
Old 03-12-2017, 09:54 AM   #1
Renboy
My Ride: 04 330Ci '08 Daytona
Need help from a computer geek
I have a problem and don't know what the best solution is to the problem.
My cable modem and router are in the basement, which I want changed so that the router is upstairs (for better signal, don't care where the modem is). But, I also want to have lines running to each of the bedrooms in the house (I can do this easily as I have a bungalow with access through the ceiling in the basement). Trying to use an android box over wifi in my house is painful. I'd like the ethernet lines going to the breaker panel to keep things clean in the basement, I won't run the lines parallel to power lines to avoid interference. I also want everything in the house to be able to communicate, think network printer. To my understanding this means the same subnet? I've tried to do some research about this and have come to a few different ways of doing this, but in any of the situations I'm not sure if the network printer will work all the time.
1. Have modem in basement, run a line upstairs to a router, then run a second line back to the basement to a hub/switch that will then split the lines to the bedrooms. What's the difference between a hub and a switch?
2. Modem in basement, router in basement, second router upstairs hardwired to the first. Would need an 8 port router in the basement.
3. Modem in basement, router in basement, router upstairs used as an access point over WDS. Would need an 8 port router with WDS.
4. ......? Any other options?
Renboy is offline   Reply With Quote
Old 03-12-2017, 10:30 AM   #2
Knight
My Ride: '05 330Ci | '01 325i
I have 4 of these rigged up currently:
https://www.amazon.com/Actiontec-Eth...actiontec+moca
Modem, router and MoCA box 1 are all in the family room, while the other 3 are distributed throughout the house with Ethernet switches attached.
Should give you some flexibility. Used this setup for a couple years now and no issues.
Keep in mind, upgraded versions have since come out. My ISP has recently upped their speeds, so I'll probably upgrade to these:
https://www.bhphotovideo.com/c/produ...0_network.html
Knight is offline   Reply With Quote
Old 03-12-2017, 12:45 PM   #3
MorganFreeman
My Ride: bacon
Just have everyone move down to the basement.
MorganFreeman is online now   Reply With Quote
Old 03-12-2017, 02:36 PM   #4
Brucifer325
My Ride: 2007 Ford Edge
Sex slave might escape on the ground floor.
Originally Posted by SPDSKTR View Post
I'm doing something wrong with my life.
"Love Us with Money, or We'll Hate you with Hammers!" - Milk & Cheese
BMWCCA# 147961
Brucifer325 is offline   Reply With Quote
Old 03-12-2017, 03:58 PM   #5
Renboy
If you're good looking, they don't want to escape
Anyone else?
Old 03-12-2017, 04:06 PM   #6
cowmoo32
cowmoo32's Avatar
My Ride: Yukon
Keep the modem in the basement, make sure DHCP is off (it's probably already off so just don't change anything). Run Cat5/6 to all of your rooms or just the rooms where you want or need a solid connection. Plug in router to one of the wall ports, problem solved.
Old 03-12-2017, 05:59 PM   #7
BIZ323
My Ride: Miyagi
Send a message via AIM to BIZ323
Google Wifi
BIZ323 is offline   Reply With Quote
Old 03-13-2017, 01:50 PM   #8
calvinz
My Ride: 01' 330ci
switch is smarter and will direct traffic as needed.
modem line to router (usually 4 ports on the router) otherwise link it to a switch for more ports. ethernet cat6 can run up to 300 feet for distant.
calvinz is offline   Reply With Quote
Old 03-14-2017, 12:53 AM   #9
lab rat
My Ride: '02 330iT
The option 1 is the easiest. Why mess with two routers when you don't have to. Hubs almost don't exist these days, just get a switch.
Because sleeper
