Old 03-19-2017, 10:29 PM   #21
Overboost
Binary is in my DNA
Overboost's Avatar
My Ride: 2002 325i
Originally Posted by Jagdtiger View Post
Nothing on the back board of the cluster is burned or broken it looks pristine. So I guess that is one thing ruled out.
I have NCS Expert here in the Charlotte area. How far into VA are you?
The older I get... The faster I was...
No Fear
Overboost is offline   Reply With Quote
Old 03-19-2017, 10:35 PM   #22
Jagdtiger
My Ride: 05 330CI
Hey boost it would probably take me like 2 or so hours to get to you. I'll keep this in mind as I work all of the time. I'm in little area called Wise County. I wish you were just a little closer. I'm gonna try tomorrow when I get off work to do the EWS to IKE and see if that changes anything. I'm hoping that will be the fix. I had thought from the beginning that the cluster was ok and that it is something else it's not jiving with.
Jagdtiger is offline   Reply With Quote
Old 03-19-2017, 11:15 PM   #23
BaliDawg
Keepin' it real stock
My Ride: E24 E32 E46 E39 E84
Yes there are no errors being scanned. I have the cluster in my hands now i'm gonna carefully take it apart and check for anomalies. After that i'm gonna read through the links you posted. I know the dealer is gonna bend me over but i'm running out of options here and don't know what to do. Thanks for those links though I greatly appreciate it. Honestly I would be kinda happy to find something blown or burned just to get to the root cause.
Your car is still drivable, right? So no rush to take it to the stealer. Patience on this will get you victory.
I saw your post that there is no obvious circuit damage. That's good news.
Did you ever save the IKE memory to a file using PA Soft? Just in case it's needed later...
https://www.bimmerforums.com/forum/s...40i-IKE-eeprom
///Mmmmmm...
BaliDawg is online now   Reply With Quote
Old 03-19-2017, 11:43 PM   #24
Jagdtiger
My Ride: 05 330CI
Ohh yeah she drives fine nothing going on there. I hear you on that i'm gonna do everything I can to fix it myself before going to the dealer. I have the stock IKE saved. I did that before messing with the temp mod. I really appreciate your guys help thus far. Hopefully that EWS to IKE might do the trick we shall see tomorrow evening.
Old 03-20-2017, 12:32 AM   #25
BaliDawg
I think there are a few things to try on your IKE.
- recalculate EEPROM checksum
- load VO from EWS
- flash in the saved EEPROM contents
- reset coding to defaults using NCS Expert
Should probably post your lastest PA Soft log that shows the IKE's HW and SW versions. Getting details will help us sort this.
///Mmmmmm...
Old 03-20-2017, 12:44 AM   #26
Jagdtiger
My Ride: 05 330CI
I will post that tomorrow to give you some more info. I did do the recalculate EEPROM checksum. I don't have NCSExpert though. I'll get you everything tomorrow once I get off work and we can go from there. Thank you!
Old 03-20-2017, 06:53 PM   #27
Jagdtiger
My Ride: 05 330CI
Ok here is some pics I just snagged. I'm not seeing the option for ews to ike and it is saying my ews is locked and programmed.
(EDIT) Let me know what else is needed?
ID:	652044   Click image for larger version
Old 03-20-2017, 07:11 PM   #28
Jagdtiger
My Ride: 05 330CI
Here are a few more pics from P.A.Soft. Notice hoe my dme has a star beside it and the hw and sw numbers are just x's? What's up with that?
ID:	652046   Click image for larger version
ID:	652047   Click image for larger version
ID:	652048   Click image for larger version
Old 03-20-2017, 09:10 PM   #29
Overboost
Binary is in my DNA
Overboost's Avatar
My Ride: 2002 325i
I see an error on the IKE screen. I thought you mentioned there were no errors?
No Fear
Old 03-20-2017, 10:12 PM   #30
Jagdtiger
My Ride: 05 330CI
That is new it wasn't there about 4 days ago. i'll get you what the error is though.
EDIT The error in the ike is this and it was in the shadow. 8c [140] voltage supply, terminal R faulty I cleared it.
Old 03-21-2017, 09:42 AM   #31
Jagdtiger
My Ride: 05 330CI
Still no clue whats up with the dme or if that is even a problem.
Old 03-21-2017, 10:08 AM   #32
BaliDawg
Post the whole log file. That will show everything including the error codes on each ECU.
///Mmmmmm...
Old 03-21-2017, 10:16 AM   #33
Jagdtiger
My Ride: 05 330CI
Hey dawg if you are gonna be around later ill get the logs for you im at work now.
Old 03-21-2017, 07:12 PM   #34
Jagdtiger
My Ride: 05 330CI
BaliDawg here is the log for today.
Old 03-21-2017, 07:56 PM   #35
BaliDawg
See all those error codes in the ECUs complaining they cannot talk to the IKE? He's borked that's for sure. I would try to write back its memory from a saved copy.
///Mmmmmm...
Old 03-21-2017, 08:00 PM   #36
Jagdtiger
My Ride: 05 330CI
Alright i'll give that a go and see what happens.
Old 03-21-2017, 08:06 PM   #37
Jagdtiger
My Ride: 05 330CI
BaliDawg you sir are a saint that done the trick my friend!! Thank you for helping me out with this I really appreciate your effort.
(EDIT) I'm not sure why but I tried that same thing days ago and it did not work. It did this time which I don't care why it didn't the first go around. It works now that is all that matters.
