Old 03-18-2017, 02:03 PM   #1
Westcoastswe
My Ride: -03 320ci convert
DSC light on when driving
Occationally 2 lamps are lit on the dash, see attached picture. It happens when drivning. OBD2-reader doesn't give any error code. DSC isn't disabled by me. A re-start of the engine and the lamps aren't lit.
What is triggering this to happen, what needs to be replaced? Thought my broken rear springs had something to do with it, but error still occur after new springs installed.
Driving a 320ci convertible, -03.
http://forum.e46fanatics.com/picture...ictureid=40416
Westcoastswe is offline   Reply With Quote
Old 03-18-2017, 02:52 PM   #2
All2kool
My Ride: 2002 325Ci
Without a code present, it's a guessing game.
I got the Christmas Tree of lights (SES/DSC/EML) three times and all three times it was for a 'P1500 - Idle Control Valve Stuck Open'.
All2kool is offline   Reply With Quote
Old 03-19-2017, 07:50 AM   #3
markusmarkus
My Ride: 2001 330Ci
The symbol on the right indicates that your brake pads need to be changed or that the brake fluid is low. The dsc light could be a bad wheel speed sensor.
Old 03-19-2017, 12:36 PM   #4
Hani
My Ride: 02 330i, 00 323i,
Originally Posted by markusmarkus View Post
the symbol on the right indicates that your brake pads need to be changed or that the brake fluid is low. The dsc light could be a bad wheel speed sensor.
+1
Hani is offline   Reply With Quote
Old 03-20-2017, 12:59 PM   #5
m54
My Ride: 325ci
Did you get an alignment after you installed the rear springs?
Steering wheel off center?
m54 is offline   Reply With Quote
Old 03-20-2017, 02:03 PM   #6
shanneba
My Ride: 2003 330Ci
A basic OBDII reader would not normally be able to access the BMW DSC / ABS and other systems to get the codes.
You need an ODBII interface with the software that does have the ability to access all the other systems in the car.
Join BMWCCA
Old 03-30-2017, 01:33 PM   #7
Westcoastswe
Hi, back again. This time w/ 2 fault codes;
5E20 Pressure Sensor 1 Fault
5E24 Pressure Sensor 1/2 Implausible
I've read that 5E24 is a consequence of the 5E20 fault. Do you agree?
Haven't managed to figure which part number I need to replace in order to sort the 5E20 fault, is it
1. a pulse generator ABS (e.g. Part number 34526752683 for rear sensor). If yes, how do I know which one to purchase, a renar sensor or a front left or front right?
2. a totally different part. If so, please help me with a part number (driving a bimmer with following last 7 of VIN: PK76308)
Old 03-30-2017, 02:23 PM   #8
NZ00Z3
My Ride: 2002 318ti
The pressure sensors are on the side of the brake master cylinder.
If you are going to be working in that tight space, better to replace both at the same time.
Remember brake fluid eats paint for breakfast so work out your task procedure to minimize the amount of fluid being dropped or left dripping.
NZ00Z3 is offline   Reply With Quote
Old 03-30-2017, 02:41 PM   #9
Westcoastswe
NZ00Z3, Thanks for directing me to the right sensor/-s.
Anyone that knows of a DIY for replacing DSC pressure sensor?
dsc, pressure sensor
