Are kidney grille tabs able to be quick fixed? - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 03-18-2017, 08:41 PM   #1
OnTheFence
My Ride: 2001 330i (and 530i)
I hate when I pop the hood and the kidney thing almost falls out.
It looks like a failed repair. Any quick fix for the broken tab?
Are they worth replacing? I only want the OEM look.
OnTheFence is offline   Reply With Quote
Old 03-18-2017, 08:56 PM   #2
jfoj
My Ride: 330CiC, M5, X5, E93
Silicon sealer/adhesive in key spots is a good option.
Old 03-18-2017, 08:56 PM   #3
Spannerhead
Save the Manuals!
Spannerhead's Avatar
My Ride: '02 330i/5 slicktop
No quick fix for the tab itself but you may be able to zip tie the grille back in place, depending on the failed tab. I was able to.
Replacement kidney grilles are relatively inexpensive.
Current: '02 330i/5 '10 Mazda5 '72 240Z
Past: '85 GSL-SE '95 540i/6 '95 525i/5 '86 635CSi/5 '88 JZA70 '86 4K quattro '85 RX-7 S
Spannerhead is offline   Reply With Quote
Old 03-18-2017, 10:26 PM   #4
fumigator
My Ride: 2000 328Ci
You can apply tape from the back to hold in place till ready to replace. One was like that when i got the car. Later the other fell out on a stop. No clue it was coming.
Sent from my SAMSUNG-SM-G930A using E46Fanatics mobile app
fumigator is offline   Reply With Quote
Old 03-18-2017, 10:37 PM   #5
Hamsocne
My Ride: 2002 330Ci
I used picture hanging wire as a temporary fix. It couldn't be seen from the front and held the grills in tight. Just wrapped the wire around the grills and then through holes in the underside of the hood. Twist to tighten and you are good.
I can find pics if needed.
Hamsocne is offline   Reply With Quote
Old 03-18-2017, 10:42 PM   #6
Kpriest
My Ride: 2005 325i
It is possible using zip ties or wire to secure the grille but replacement is the best option.
A Genuine BMW grille is around $60 for the facelift model. I had to replace mine after attempts to secure the grille with broken tabs.
New grille simply pushes in from the front of the hood and snaps into place.
Kpriest is offline   Reply With Quote
Old 03-19-2017, 08:18 AM   #7
OnTheFence
In my photo, there seems to be epoxy on the hood part of the grille.
Is the hood damaged as well as the grille tab?
Could a new grille not be the entire problem since the hood part it clips into is also broken, right?
Old 03-19-2017, 08:36 AM   #8
jmo69
My Ride: 03 325xi 98 328is
Compare it to the other side after scraping the epoxy off the metal tab.
][/2003 325xi auto Stahlgrau almost modless, just lots of new parts. 1998 328is 5sp lowered, X-brace, Sparco strut brace, HIDs and almost everything blacked out
jmo69 is offline   Reply With Quote
Old 03-19-2017, 09:25 AM   #9
All2kool
My Ride: 2002 325Ci
I fashioned hooks out of a coat hanger. Worked like a charm.
ID:	651952   Click image for larger version
All2kool is offline   Reply With Quote
Old 03-19-2017, 09:57 AM   #10
Knight
My Ride: '05 330Ci | '01 325i
Double-sided mounting tape (up to a 30lb hold rating) works wonders.
Knight is offline   Reply With Quote
Old 03-19-2017, 10:48 AM   #11
hitbyastick
My Ride: 2002 325i
Not the Genuine ones! Them sh*ts is costly. The inexpensive ones are the matte/gloss black which are fine if that's the look you're into. I'm all about the OE look so they won't work for me. I ain't buyin' new OEs until I break down and say OK I'm buyin' new OEs.
What I did was to lodge pieces of EVA foam (the stuff they used for the midsoles of 1970's jogging shoes) in between the broken tab on the grille and the metal tab on the hood where the broken tab was supposed to click into. I obtained the foam among packaging materiel I got when I bought a PC power supply. Works like a charm- hasn't come loose and I've done several thousand miles of 105 mph interstate travel in heavy crosswinds etc. No need to drill holes, use goops or zipties, etc. Just jam some foam in there.
Erryboddy got a plan till they get punched in the mouf - Mike Tyson
hitbyastick is offline   Reply With Quote
Old 03-19-2017, 02:00 PM   #12
Kpriest
My Ride: 2005 325i
It depends on what you call expensive. You can get Genuine BMW OE replacements for $50-$65 depending on if it is prefacelift or facelift. I went this route because I did not want to have to rig up a holding device. Fix it right and check it off the list for another 12-15 years.
I found my prices on FCP Euro and ECS Tuning which offer free shipping over $50.
Old 03-19-2017, 02:04 PM   #13
All2kool
My Ride: 2002 325Ci
I am an OEM look guy as well and I replaced mine from EBay for under $60. I had ordered them before I came upon the coat hanger hook fix.
Old 03-19-2017, 09:25 PM   #14
hitbyastick
My Ride: 2002 325i
FCP shows the Genuine grilles are $80 apiece. $160 for the set. I consider that expensive. I'll probably end up buying a pair eventually just not motivated to do so right now especially since my kludge worked out.
Old 03-20-2017, 08:27 AM   #15
RetreatWI
My Ride: 2002 330cic
I did the same thing with the foam. I used rectangular pieces from a thick yoga mat.
RetreatWI is offline   Reply With Quote
Old 03-20-2017, 01:29 PM   #16
Stingray230sx
My Ride: 01' 330ci-96' FZJ80
yea, especially when they are just gonna get brittle and break again smdh.....
Stingray230sx is offline   Reply With Quote
Old 03-20-2017, 01:29 PM   #17
Wochoa
My Ride: 2003 BMW 325ci
I just used clear caulking for like window installation etc. $7.00 and your set at your local hardware shop.
Wochoa is offline   Reply With Quote
Old 03-20-2017, 06:58 PM   #18
VerrKol
My Ride: '01 330ci
I got mine for 30 or 40 bucks each on Amazon. It looks identical to the OEM chrome.
VerrKol is offline   Reply With Quote
