Old 03-19-2017, 11:45 AM   #1
Speeddragon
My Ride: e46 323 Sedan
clunking, bonking and shaking [323]
The last problem to tackle on my e46 is a clunk/bonking sound.
I have read many threads online but most of the topics are a little different than mine.
First I had a really hard clunk and my differential back bushing was worn. I replaced it, the other bushings/rubbers from the differential where still in very good condition according to the BMW specialist.
When I am driving and switching gears I notice a clunk coming from the back. This is the most hearable when going to the 3th or 4th gear.
Switching gears when high in RPM in a sportive way minimizes the sound.
Most people notice this problem the most between 1/2. But the thing that is different with my car is:
When I drive 40km/h(24mp/h) in 3th gear and I release the clutch really fast I hear the clunk a few times, like something is shaking and touching an other part.
What I have checked or replaced:
-Sub frame mounts: left side was repaired in the past but no cracks visible now.
-Guibo: replaced
-Drive shaft center bearing: was still fine (don't know if it is mounted with 2mm preload but the mechanic is a BMW specialist that worked for a dealer for 20 years)
-Gearbox bushings: still fine
-Clutch replaced, mechanic said flywheel was still good to go, wasn't the best but it wasn't totally worn.
-Differential bushings: 1 replaced, rest checked
-exhaust: mounted fine (and it's a darker clunk)
-I have no clutch delay valve, it's a 1998 so it's never been in place
I really don't know what to do next, I am starting to irritate myself too much from it.
Speeddragon is offline   Reply With Quote
Old 03-19-2017, 11:51 AM   #2
ZacharyMikel
My Ride: 2004 330i 6MT ZHP
I've experienced symptoms like what you're describing and I thought the sound was coming from the rear. It was actually my front sway bar end links, they were totally loose. I would at least check them.
Sent from my Nexus 6P using Tapatalk
ZacharyMikel is offline   Reply With Quote
Old 03-19-2017, 04:43 PM   #3
Speeddragon
Thanks for your reply, will check that soon..
Old 03-19-2017, 05:33 PM   #4
jmo69
My Ride: 03 325xi 98 328is
My 98 e36 had a cdv, don't know why yours wouldn't.
HERSHIS
2003 325xi auto Stahlgrau almost modless, just lots of new parts. 1998 328is 5sp lowered, X-brace, Sparco strut brace, HIDs and almost everything blacked out
jmo69 is offline   Reply With Quote
Old 03-19-2017, 06:14 PM   #5
TobyB
My Ride: 2004xit, 2001ci
If your car is a 98, maybe check the top rear shock mounts.
E36s had a real problem with them, so maybe your very early E46 could?
Just a guess,
t
TobyB is offline   Reply With Quote
Old 03-20-2017, 03:59 PM   #6
Speeddragon
@jmo69
When looking up my vin in the parts catalog it shows the cdv but doesn't give you a part number.
Some european topics on european bmw forums say that their new bought car didn't have them either, so I don't know.
Old 03-20-2017, 04:39 PM   #7
Alex323Ci
My Ride: M3 & 323Ci (sold)
^your early 323i doesn't have the CDV from what I recall. not all E46s got them. my USA 2000 323Ci didn't have one either.
having it or not isn't causing your issues anyway.
would have to hear/see your issue to make a better diagnosis. but some "clicking" can be slack in the driveline and even more so your halfshaft axle's cv joints.
