2002 330CI DISA Valve Missing Flap - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 03-19-2017, 03:18 PM   #1
bobaloo6
My Ride: 2002 330CI
Sorry guys I'm a newbee! just realized that after posting this there was already a thread almost exactly the same, same questions etc. Should have checked more thoroughly.
I would still be interested to know if anyone can explain why the missing flap seemingly has no effect on how the car runs?
Hello All,
I just joined the forum today, however I have been using it as a non member for a while and love the great base of knowledge and information it provides.
I recently purchased a 2002 330CI (158K miles) about 6 months ago. I have never owned a BMW before and I absolutely love this car. I cant see myself driving anything but a BMW in the future. The car is in excellent shape and judging by the way it runs and drives I believe the one owner took excellent care of the car. No leaks, new clutch etc. I had it checked by BMW mechanic and he gave me the assurance that it is in excellent shape as well. The car looks and runs beautiful!
The only thing about it that bothered me, but was not a big problem, is the idle was a little rough when the engine was cold at first startup. Once the engine reached temperature, no problem , you sometimes can't even tell if the car is running the idle is so smooth. I am very meticulous about small details, so after reading posts on the forum and watching videos I found a lot of information that this could be caused by a dirty ICV valve. I finally had a chance to check the ICV valve out today and I am quite shocked at what I found. I never got to removing the ICV valve, when I was removing he DISA valve to get at it, I found there was no control flap on the DISA valve!
Holy crap! I looked inside the manifold as good as I can through the DISA valve hole but couldn't find anything.
So sorry for the long story but I wanted your guys opinions. I am hoping this was the previous owner/mechanics decision that they found this damaged during maintenance, removed the damaged pieces and didn't want to replace it $$$. Since the car runs fine without it. However, my concern is, if this is not the case and the piece is inside the manifold somewhere, I'm thinking its a disaster waiting to happen. I will definitely replace the valve but do you think I should have a mechanic open the manifold to see if the flap and holding pin is indeed somewhere inside? I am pretty sure this a silly question and should be done, but I was wondering if you guys had ever seen this, what would you do in this situation and why does the car seem to run so well without it?
Any thoughts on this would be appreciated.
Thanks!
bobaloo6 is offline   Reply With Quote
Old 03-19-2017, 03:29 PM   #2
jfoj
My Ride: 330CiC, M5, X5, E93
If the rear pin is missing, someone likely removed the flap and pin.
If the rear pin was still in the frame, then I would be looking for a flap in the intake.
Old 03-19-2017, 04:56 PM   #3
BaliDawg
Keepin' it real stock
My Ride: E24 E32 E46 E39 E84
You can search for the detailed explanation of how the DISA operates, but essentially it switches the intake runner between short and long tubes. It is closed most of the time except under midrange RPMs starting around 4000.
///Mmmmmm...
BaliDawg is online now   Reply With Quote
Old 03-19-2017, 06:53 PM   #4
shoman24v
My Ride: 2002 330i 1999 328is
I doubt there's any reason to remove the manifold. If the pin got sucked in your motor would be done.
Replace the DISA valve. You're probably only thinking the car is running well.
When I purchased my 330 a couple months ago it already had a bad DISA. No big deal, right? But when I removed the DISA to replace it the pin fell out and landed on the flat plane in the manifold
2002 330i - 5-SPD 91k | 1999 328is - 12+ years of ownership, 221k (170k by me) 5-SPD, Factory M Aerodynamic Package, No Sunroof
shoman24v is offline   Reply With Quote
Old 03-19-2017, 07:27 PM   #5
jfoj
Replace the DISA, it is there for a reason. It will help with driveability, performance and fuel economy.
The rear DISA pin only falls in to the intake when removing the DISA. So if the pin it not in the rear of the cage, someone removed the pin and flag.
DO NOT consider and aftermarket replacement, BAD IDEA. Search and you will see.
Old 03-19-2017, 07:37 PM   #6
jmo69
My Ride: 03 325xi 98 328is
If the vacuum pot is still good you can get the G.A.S. kit, but without the flap it's pretty hard to test.
][/2003 325xi auto Stahlgrau almost modless, just lots of new parts. 1998 328is 5sp lowered, X-brace, Sparco strut brace, HIDs and almost everything blacked out
jmo69 is offline   Reply With Quote
Old 03-19-2017, 07:40 PM   #7
jfoj
It should be able to be tested even without the flap, but you have to use your head and understand what is required to test the diaphragm.
Old 03-20-2017, 09:26 AM   #8
ChadTsunami
My Ride: 2004 BMW 330i ZHP
How long do the DISA valves typically last? And is there a way to remove an old DISA without having that pin fall out?
ChadTsunami is offline   Reply With Quote
Old 03-20-2017, 09:48 AM   #9
BaliDawg
Probably 60k miles, but it varies. I would at least check the DISA every 20k-30k miles or so; it's easy enough to remove.
The pin will only fall out when removing your DISA if it's really far gone. It sits horizontal so just slowly and carefully remove the DISA. There's not enough space for the pin to fully come out when the DISA is installed.
///Mmmmmm...
Old 03-20-2017, 01:50 PM   #10
jfoj
I would say the DISA O-ring does not last very long, while my E46 was still under the 48 Month/50k Mile Bumper to Bumper Warranty the DISA was replaced, mainly due to a leak in the O-ring.
But I would say most DISA's may make the 80k-100k mark depending on how the car is driven. But the DISA O-ring may only last 40k miles.
The more the engine is started the more the DISA probably gets exercised.
