Differential swap 3.07 to 3.46 Help!!! - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 03-20-2017, 12:06 AM   #1
RedDawn
My Ride: 99 323i
OK so my question is can I use a 3.46 differential from a 325i automatic or 323i automatic and bolt it right into my 323i with manual transmission. I don't have the budget right now to experiment or I would but, it seems a lot easier and a little cheaper to find a 3.46 that came out of an automatic car, and also the automatic 323i is geared to 3.46 and if I could just bolt it right up I just may be able to smile again. Facts will be appreciated! thanks
RedDawn is offline   Reply With Quote
Old 03-20-2017, 12:09 AM   #2
04yfz
My Ride: A car
Yep it's a plug and play set up if you use a non 330i diff. I actually have a 3.46 diff out of an auto 323i I'm parting out, Pm me or shoot me a text if you can't pm. 732-705-7005 (yes it's a real number lol).
04yfz is offline   Reply With Quote
Old 03-20-2017, 04:56 AM   #3
JCastillo
My Ride: 2000 BMW 323CI
Nice... i will definitely be doing this too
Sent from my SAMSUNG-SM-G935A using E46Fanatics mobile app
JCastillo is offline   Reply With Quote
Old 03-20-2017, 11:30 AM   #4
goodmanr
My Ride: 01 325i Sprt&PremPkg
You can use the diff from a 330i but the input flange will need to be changed. Just use the one from your old diff.
goodmanr is offline   Reply With Quote
Old 03-20-2017, 01:27 PM   #5
Alex323Ci
My Ride: M3 & 323Ci (sold)
here's a bunch of info on this that'll probably help
http://forum.e46fanatics.com/showthr...ferential+swap
Old 03-20-2017, 05:22 PM   #6
TobyB
My Ride: 2004xit, 2001ci
err, it's not that easy. There's no way to reset the pinion preload properly, so you run a real risk of having the 'new' diff fail pretty
quickly due to the pinion being either too loose or too tight.
Yes, a new crush sleeve and seal and some care gets it back together again, but it's at least a 3 banana job. Far easier to find the right flange.
t
TobyB is offline   Reply With Quote
Old 03-20-2017, 05:28 PM   #7
Alex323Ci
t
it's not that hard. it's a swap over, much different than installing new gears inside and setting up. you mark the nut and pinion tip. count turns off and position, then repeat when installing on.
Old 03-22-2017, 11:38 AM   #8
RedDawn
My Ride: 99 323i
Best news I've heard all day!
Old 03-23-2017, 11:53 PM   #9
TobyB
So you can trust that the pinion flanges are the same thickness?
I'm coming from previous generations, where it was variable...
t
Old 03-24-2017, 03:14 AM   #10
Alex323Ci
yes.
