Old 03-03-2008, 05:12 PM   #1
blackie2
My Ride: 2001-330i/2004-4runn
Question Oil level is fine but Oil Sensor light comes on anyway
My oil sensor light came on during my drive to work in this morning, about 45 miles one way, so I got a quart of oil before going to the office. I didn't put any oil in it as I wanted to check the level when the engine was cool. So I did that at lunch and my oil level was fine. I did a search on the oil sensor that comes on temporarily but mine just stayed on. I drove home and oil sensor warning light didn't come on at all. Would this indicate a bad sensor or could it be something else?
blackie2 is offline   Reply With Quote
Old 03-03-2008, 05:36 PM   #2
Tangent_
My Ride: '01 330i, '11 Z435i
Normal oil light behavior:
Comes on red - Low oil pressure, shut off engine NOW!
Comes on yellow after shutting off car - A little low on oil. Add oil soon
Comes on yellow while driving - Significantly low on oil. Add ASAP!
Comes on yellow a few seconds after starting and then goes off after several seconds - Defective sensor. Check oil level manually until replaced.
If yours came on while driving, stayed on, and didn't recur after manual check that the level is OK I suspect that the sensor has one foot in the grave.
http://forum.e46fanatics.com/signaturepics/sigpic70081_4.gif
Tangent_ is offline   Reply With Quote
Old 03-03-2008, 08:31 PM   #3
Bailey228
My Ride: 99 323i Alpine White
Bad sensor... it's common, and it went on mine as well. No biggie, simple fix.
The right to speak freely does not guarantee the right to be taken seriously.
Bailey228 is offline   Reply With Quote
Old 03-04-2008, 07:51 AM   #4
blackie2
followup
thanks
Old 04-03-2008, 10:12 AM   #5
riznphoenix
My Ride: 2001 330i
Is it something I can fix myself?
riznphoenix is offline   Reply With Quote
Old 04-03-2008, 10:15 AM   #6
garbs
My Ride: 2000 323Ci
Have same issue, where can one get this so called sensor!!
TIA
garbs is offline   Reply With Quote
Old 04-03-2008, 11:38 AM   #7
NoVaDreier
My Ride: 2001 325i
Here is one source for the oil level sensor and the gasket.
NoVaDreier is offline   Reply With Quote
Old 04-03-2008, 03:00 PM   #8
Alex323Ci
My Ride: M3 & 323Ci (sold)
i just did mine this weekend. just remember the 3 hex nuts are 8.5 Nm torque and not 18lbs-ft as posted here which is way to much.
Old 04-03-2008, 03:01 PM   #9
GRIDLOCK
My Ride: E36 / E46
Have an EVAP code? Replacing gas cap did not fix? Give me a holler, I can do a smoke test for ya.
GRIDLOCK is offline   Reply With Quote
Old 04-03-2008, 03:35 PM   #10
Kmoy2002
My Ride: 2002tii, 540i, 330i
Didn't know that the light can be so informative
Kmoy2002 is offline   Reply With Quote
Old 05-06-2008, 11:23 PM   #11
RotaryBzzz
My Ride: E36 M3 : E46 330i
here is the part slightly cheaper @ RMeuropean @ $83.20 shipped:
http://www.rmeuropean.com/SearchResu...=16&Search.y=8
RotaryBzzz is offline   Reply With Quote
Old 05-07-2008, 12:05 AM   #12
Dan99
My Ride: 2001 330xi
try reseting it on the dashboard.
Dan99 is offline   Reply With Quote
Old 05-07-2008, 12:24 AM   #13
felip
My Ride: 330ci
how do you do that? i'm getting the yellow oil light at start up then it goes away dinan told me it was the sensor.
felip is offline   Reply With Quote
Old 05-07-2008, 12:36 AM   #14
Dan99
My Ride: 2001 330xi
Here's the diy for it, but it varies from the car's production date:
http://www.my330i.com/lof.php
-check the bottom of the page (last step)
Old 05-07-2008, 01:34 AM   #15
brewster240
My Ride: 02 325it, 95 m3
do you drive a lot of short trips?
if so it could be a condition caused by airated oil, and/or moisture in the oil.
when was the last time you had it changed?
if you dont want to spend the 100+ on it, next time you do an oil service, pull out the sensor, and blow it out with some compressed air. looked for build up in it etc. dry it out good, reinstall.
see if that helps. if it doesnt, replace it, but at least maybe you can save some money.
good luck.
brewster240 is offline   Reply With Quote
Old 12-20-2011, 07:58 PM   #16
jeepo23
My Ride: 2008 X3, 6 Speed
good luck.
Hate to revive and old thread like this but better than starting a new topic..
Do you have any more info on your statement about driving a lot of short trips? I find my oil light comes on after turning off the engine during random times. ie..
I drive to work in the morning all fine shut of car - no light.
I leave work drive home turn of car - no light.
Drive home to work roundtrip is a total of ~8km.
I leave later on that night and do a longer drive, engine warms up better i turn off car i get the light.
next day no oil light at all..
It does not seem to be consistent at all. Seems like when the engine gets hot it triggers it on shut down. I just added oil to it today and it was in the halfway mark between the two dips on the stick and just as I drove home from the mall and turned it off the light came on..
I know its not leaking that much as I hardly notice it on the ground when I leave where i park.
jeepo23 is offline   Reply With Quote
Old 12-20-2011, 10:15 PM   #17
Sweetness
My Ride: '01 325i
LMAO...
And Where is the sensor located???
2001 325i ZCW, ZPP
Titansilber Metallic, Black Interior
The 160,000 mile, clean daily driver
Sweetness is offline   Reply With Quote
Old 12-20-2011, 10:18 PM   #18
bimminge46
My Ride: 323Ci, 89 325i ETA
Do you have any more info on your statement about driving a lot of short trips? I find my oil light comes on after turning on the engine during random times. ie..
Find the leak, fix it. [Most likely SOLVED]
E30 in progress.
bimminge46 is offline   Reply With Quote
Old 12-21-2011, 06:18 AM   #19
jeepo23
Yah, I did poke around in there and I'm pretty sure my OFH gasket is gone so come spring I will be changing that out as I can see the mess it has created back there.
But I just find it hard to believe this stupid light keeps getting triggered and I don't see any noticeable oil on the ground.
Old 03-18-2017, 06:37 PM   #20
helkenndg
My Ride: 04' 325CI, 08' 335i,
Sensor light failed me 20
Fello
helkenndg is offline   Reply With Quote
