Sponsored by The Tire Rack
Old 09-30-2010, 01:42 AM   #1
carsalbuja
My Ride: 2000 323ci
Predictions plaese!! 265/30/19 19x9.5 offset 35 would it rub??
hey guys so im getting ready to mount tomorrow this new set of wheels i got! they are been power coated right anyways.. i made the little mistake of not trying them on before i customized the paint so after intense research on the forums i have a 50/50 chance of rubbing so i want to know what u masters predict would happen tomorrow
2000 323 ci stock suspenssion
fronts
19x8.5 225/35/19 offset 38 = it will NOT rub for a fact!
BUT rear....
19x9.5 265/30/19 offset 35
game on felas ! whats the predictions?? will it fit will it not? would i need fender rolling , im a f*^%^ and will need to buy new tires?? lol
thanks guys!
carsalbuja is offline   Reply With Quote
Old 09-30-2010, 12:53 PM   #2
SIN3
My Ride: Fitment Connoisseur
Send a message via AIM to SIN3
no on stock suspension. go with a 255.35 if you are doubt. 265 on a 9.5 is "Meaty". but if your are not dropped you have nothing to worry about.
2006 M3 Cabrio
2004 ZHP Cabrio
/stanceworks\
"keep it clean, keep it OEM+"
SIN3 is offline   Reply With Quote
Old 09-30-2010, 01:27 PM   #3
electric130
My Ride: 2002 330i
i have 235's on 8.5 and 255's on 9.5 and they looked stretched a bit. i will probably go with 245 and 265 next time. that would look square. but to the OP's question, i'd say you're fine on stock suspension, but if you're dropped, it's hare to say without knowing the drop.
J.R.
electric130 is offline   Reply With Quote
Old 09-30-2010, 02:12 PM   #4
VMRWheels
VMRWheels's Avatar
My Ride: Anything with VMRs!
fronts
BUT rear....
thanks guys!
9.5 +35 with a 265 on Coupe WILL rub for fact. I am currently running a 9.5 +33 on a 255/30/19 and it rubs a lot, even with fender rolling and a slight pull. This is with OE camber.
If you plan on adjusting camber, the 255 can work, but definitely not the 265 without some major camber.
-Charles@VMRWheels
Tracy @ VMR | Wheels
Winter Wheel/Tire Sale!
Old 09-30-2010, 09:37 PM   #5
carsalbuja
My Ride: 2000 323ci
-Charles@VMRWheels
Charles u are the man! , i mounted them and sure enought every tight curve i took i felt that rubbing...... anyways im thinking about 3 options which one do u think won't rub (sometimes i do have 4 people in the car or travel with a lot of logadge!) oh and i just want to keep stock cambers and stock aligment due to a big problem i had with my e39 and decided to not ever ever mess around with that stuff lol i wouldn't mind rolling fenders but thats about it. anyways..
#1__ 255/30 19
#2__ 245/30/19
#3__ 245/35/19
Thanks alot!!
Old 10-01-2010, 03:01 PM   #6
VMRWheels
VMRWheels's Avatar
245/35 would be a better choice. Since this fitment is quite aggressive, 245's may still give you problems if you do not have rolled fenders and a full cabin of passengers.
-Charles@VMRWheels
Old 10-06-2010, 07:00 PM   #7
beamah
My Ride: 99 328 sedan
great info as im lookin to get 19's 9.5's too, but wouldn't a 245 be really stretched on 9.5's??
also what size tire would be flush and meaty with 19x8.5 +35 all around? 255 35 fronts and maybe 265 30 rear dropped with coilovers front and rear rolled, fit nice?
beamah is offline   Reply With Quote
Old 10-06-2010, 07:18 PM   #8
electric130
My Ride: 2002 330i
yes, 245 on 9.5 would be stretched. i have 255 on 9.5 and it's stretched. if you lay the rims on the ground, nothing touches except the rim. that's stretched. i wish i would have gotten 265 at least for 9.5. my stock rears were 8.5 and 245 was almost square, but not quite. i think 255 on 8.5 and 275 on 9.5 would be square.
J.R.
Old 10-07-2010, 03:26 PM   #9
VMRWheels
VMRWheels's Avatar
Hi,
245's are quite stretched on a 9.5" wheel.
235 will be flush and square with a 8.5 +35 fitment. What rear width and offset will you be running? Either way, 265's are a bit too aggressive for a Sedan.
-Charles@VMRWheels
Old 10-07-2010, 06:06 PM   #10
beamah
i was thinkin about 265 rears with an 8.5 35+ ET, should that clear? or 255?
Old 10-07-2010, 07:20 PM   #11
electric130
My Ride: 2002 330i
i've got 255 on 9.5 ET +45 and they clear. 265's on ET+35 might rub, especially if you're lowered at all.
J.R.
Old 10-08-2010, 01:18 AM   #12
beamah
^on a 19x8.5+35 265 rears with a good fender roll on coilovers. ?
Old 10-08-2010, 01:32 AM   #13
Don B
My Ride: 325i (RHD)
I was running 255 30 19 on a 9.5 ET42 rim and rubbed.
Don B is offline   Reply With Quote
Old 10-08-2010, 05:46 AM   #14
electric130
My Ride: 2002 330i
with 8.5, the stock offset is +50 and tires are 245. so you're adding 20mm to the width, and pushing the whole wheel 15mm towards the outside. split the width difference half inside half out, and you've got 25mm that your wheel is closer to the fender. thats a whole inch. my VMR V710's are 8.5 +35 up front, but i'm running 235's. the tire looks decent. it's stretched, but no too bad. so with 8.5 +35, 235's should be fine in the rear.
J.R.
Old 10-08-2010, 12:37 PM   #15
beamah
Ahh gotcha thanx!
Old 10-08-2010, 02:10 PM   #16
VMRWheels
VMRWheels's Avatar
265's are outside the recommended width range for a 8.5" wheel. 255 should be the widest you run on a 8.5" wheel.
-Charles@VMRWheels
Old 10-08-2010, 07:25 PM   #17
beamah
^gotcha
Old 02-10-2017, 04:07 PM   #18
Ne70
My Ride: E46 323ci
hello there;
im runing
235/35/19 in the 4 tyres with 8.5 front and 9.5 rear
I have a CI
I recently bought new rims
8.5
9.5
with 35mm
today the tyres are flushed and I dont like that still
I'm planing buy for the rear 255/35
do you think is going to ruber the fenders?
I also have HR springs, so it's a little bit dropped
current 235/35 is not touching the fenders at all
Ne70 is offline   Reply With Quote
offset, problems, rubbing
