Old 04-25-2013, 04:34 PM   #1
trj
My Ride: 325Ci
DSC and brake light issue(codes included)
So, a week ago when I did my rear shocks/springs and RTABs, the DSC and brake light illuminated in yellow after about 20 miles drive.
My guess was, since I did the RTABs the alignment must have been off and once I get the alignment it will be alright.
Checked the codes with PA soft:
ABS* -> 5E40/E0 - Steering angle sensor Signal not plausible, Offset.
LEW -> 09/CF - No CAN message (ASC)
This week I got my front coilovers done and got alignment yesterday.
The alignment is good, but the brake and DSC lights are still ON (yellow).
Clearing the codes and reset the steering angle values.
LEW code went off, but the ABS code still remains.
Steps I did:
-Of course, tried to clear codes using PA soft. Unsuccessful.
-Full lock from left to right and right to center. Unsuccessful.
-Removed the battery for sometime. Unsuccessful.
-Restarted the ABS unit. Unsuccessful.
The steering wheel is straight and the car drives straight.
Is it a coincidence that the sensor went bad immediately after the RTAB install?
Or shall I get someone with INPA or GT1 to clear it? As PAsoft definitely didnt succeed. Although, it looks like people were successful in clearing the code in e39s.
Old 04-25-2013, 04:38 PM   #2
duramax
My Ride: 2002 BMW M3
dsc
speed sensor maybe
duramax is offline   Reply With Quote
Old 04-25-2013, 04:40 PM   #3
trj
My Ride: 325Ci
Originally Posted by duramax View Post
speed sensor maybe
^ not sure man.
I will remove the wheels tomorrow and check if I can the speed sensors cleaned. But it seems like its a myth. Doesnt hurt to try.
The only sensors I unplugged were the two on the driver's side rear.
And they are plugged in properly.
Old 04-25-2013, 04:52 PM   #4
duramax
dsc
I can almost bet its a speed sensor, I have extras if you need one
Old 04-25-2013, 04:53 PM   #5
trj
My Ride: 325Ci
Is there a way I can test which one is bad? I mean if not physically damaged?
If anything is damaged I will definitely hit you up for the ones you have.
Not sure if the M3 and 325 use the same sensors.
Old 04-25-2013, 04:59 PM   #6
duramax
dsc
Im not sure on how you can do a test maybe someone will chime in and help with that, and the speed sensors are not for the M3, I bought them thinking they were the same and sure enough they are not so they fit the regular 3 series.
Old 04-25-2013, 05:14 PM   #7
jaymemaurice
Location: Anchorage Alaska or Kitchener, Ontario, Canada
My Ride: 01 330ci, 03 Passat
speed sensor maybe
No, speed sensors give you a different code. There is a procedure for checking the steering angle sensor. There is a way to see it's current value in INPA (like testing a windows joystick) and a way to adapt it (like calibrating a windows joystick).
Also, speed sensors can be read individually in INPA.
Why would you take things apart when you can simply have the car plugged in and read?!
Rain Sensor Retrofit: Here
Coupe Headline Replacement: Here
jaymemaurice is offline   Reply With Quote
Old 04-25-2013, 06:00 PM   #8
trj
My Ride: 325Ci
Thanks guys. The codes cleared up.
After I calibrated the steering angle sensor I went for a drive. After about 50 miles the lights went off. Will run the scan again later once I get home to see if there are any hidden codes.
So for anyone with this code pop up. Get am alignment, calibrate the steering angle sensor and drive for sometime.
Old 04-25-2013, 06:08 PM   #9
duramax
dsc
glad you got it fixed, how do you calibrate the steering angle sensor
Old 04-25-2013, 06:27 PM   #10
trj
My Ride: 325Ci
If you go in the LEW section in Pasoft. You have an option to reset or something similar.
Once you have your alignment done, keep your steering wheels and front wheels straight. And calibrate using the Pasoft or INPA.
It should take care of it unless the sensor is broken.
Old 06-23-2013, 07:24 PM   #11
YAN-3
My Ride: '88 M3 & '05 325i
Thanks for the info!
I just did my coil overs, brakes lines and bushings/ball joints and had all three lights come on.
Will be doing alignment tomorrow or Tuesday and then take it out for a drive and see if they clear up.
YAN-3 is offline   Reply With Quote
Old 07-19-2013, 08:24 PM   #12
rizwan1377
My Ride: 04 M56,LC 100,RX300
Send a message via AIM to rizwan1377 Send a message via MSN to rizwan1377 Send a message via Yahoo to rizwan1377
I have the similar issue but the light came on after i did the wheel alignment. I tried to reset it with Pasoft but its not resetting. Please help me with this. Thank You
rizwan1377 is offline   Reply With Quote
Old 07-19-2013, 08:48 PM   #13
YAN-3
So after alignment, and 300+ miles, all three (DSC, BRAKE, ABS) stay on. I calibrated the steering angle via PA Soft and tried the 50mile again... Still light on. Gonna swap sped sensors as the front driver side is active error code and then will report back.
Old 07-19-2013, 09:02 PM   #14
rizwan1377
Re: DSC and brake light issue(codes included)
I only have the dsc & brake (yellow in color). And dont have any codes for speed sensor. I will take it back the shop again and see if they can fix it.
Sent from my Galaxy s4.
Old 07-19-2013, 10:34 PM   #15
YAN-3
Whatever the result please post it here.
Old 07-28-2013, 10:58 AM   #16
dkuchta
My Ride: 325cic
Any luck with this?
dkuchta is offline   Reply With Quote
Old 11-12-2013, 09:26 AM   #17
YAN-3
guys i know this has been a while, but i finally got around to replacing my wheel speed sensor. put the car back down on the ground, pulled out of the driveway, and as i drove past two houses down the street, the ABS light turned off, then the yellow BRAKE and shortly after the DSC light. all within driving less than 1/4 of a mile. so happy and glad i didnt have to use the scan tool or drive 50miles like mentioned in other threads.
Old 10-02-2015, 05:15 PM   #18
2002BMW
My Ride: 2002 BMW 325Ci Coupe
Pa Soft Tool S/W Calibration
I am trying to Calibrate the Steering Wheel Angle but can not find the reset button in the PA Soft Tool:
Anyone Know how?
2002BMW is offline   Reply With Quote
Old 11-23-2015, 08:01 PM   #19
darman1484
My Ride: 2001 330i
Anyone Know how?
Same issue and I don't see how to reset it with PA Soft either. There was another post about resetting it http://forum.e46fanatics.com/showthread.php?t=1024742, but my hex already has my VIN (because I never changed the actual part), so I am not sure how to tackle this.
darman1484 is offline   Reply With Quote
Old 11-02-2016, 04:57 PM   #20
bradleyhenry94
My Ride: 2001 BMW E46 M3 6MT
what did you use to recalibrate? PASOFT, GT1, INPA?
bradleyhenry94 is offline   Reply With Quote
